So, I've just gotroundto fitting the new head bearings [1] in this 86 GPz550 and I believe the only reference I have (the HBOL) tells me to: 1) Torque the first adjuster nut (castellated ring) down to 29 ft/lb [2] 2) Check the steering moves smoothly end_to_end and with no tight / loose bits. 3) Back off said nut till it's fairly slack. 4)Tighten it back up until you *just* start to feel some resistance in the steering movement. 5) Fit the other nut/ring and lock them together .. etc Now 2-5 seem pretty reasonable but I'm not sure of the point of 1) (assuming it's correct in the fist place). Is it to ensure all the races are fully seated? [1] I can't remember ever changing taper roller headset bearings before. [2] HBOL talks of making a torque wrench from a 'C' spanner [3] and spring balance. Luckily, car mechanic mate happened to have some special 4 pronged 'tool' for some car lower ball joint or summat that I thought might fit (and it did, perfectly) and a 35mm 1/2" sqdr socket to suit. ;-) [3] A couple of double ended C spanners on their way from the net.
