Have I done something really numpty?
Discussion in 'UK Motorcycles' started by malc, Apr 26, 2010.
  1. malc
    Why should you need to? If I had a touring bike that required me to
    replace those items and was designed so they could be replaced
    regularly and easily I'd be getting shot of it asap.
    Lozzo, Apr 27, 2010
  2. malc
    Only if the bike is in gear. If the bike in in neutral with the stand
    down it will start if the kill switch is in the run position, even with
    the clutch out. I know this because I start mine like that at least
    four times a day, and used to do the same on all my other Kawasakis.
    I don't know of any bike that cannot be started in neutral with the
    stand down, as long as they are in neutral. Some require the clutch to
    be pulled in, but not Kawasakis. The clutch switch on a Kawasaki only
    works when the bike is in gear and the stand is left down - as the
    clutch is fed out the switch will cut the ignition
    Lozzo, Apr 27, 2010
  3. malc
    Jim Guest
    This is why you should occasionally use the kill switch to stop the
    bike, so that the neurons associated with remembering that it exists are
    kept exercised.
    Jim, Apr 27, 2010
  4. malc
    Malc Guest
    Thanks. Longford Road eh? Avoiding me obviously ;-) I should have
    thought about asking earlier.
    Malc, Apr 27, 2010
  5. malc
    Providing the neutral light is illuminated, it seems.
    I had to disable the clutch switch on the Bandit when the choke was
    sticky and required manual assistance - not having two left hands I
    couldn't hold the choke on and the clutch in simultaneously when
    sitting on the bike. The clutch switch had to go and I really don't
    miss it.
    Pip, Apr 27, 2010
  6. malc
    Malc Guest
    Ok if you wouldn't mind. I'll drop you an email.
    Malc, Apr 27, 2010
  7. malc
    rick Guest
    I've done that as well. Used the kill switch 'cos I stopped on a steepish
    hill and would have had to use ninja co-ordination to swap from front to
    back brake. Spent 10 minutes checking the effin' fuse box etc., when I tried
    to restart the bike and it wouldn't.
    Even more embarrasing when I'd just spent half an hour with an even older
    gimmer than me explaining how modern Triumphs were so much more reliable
    than the sort of things he used to ride.
    rick, Apr 27, 2010
  8. malc
    Nige Guest
    Heh, it sure did, i never use 'em to be honest, unless i'mm doing
    killswitch backfires :)
    Nige, Apr 27, 2010
  9. malc
    Spark plugs are a service item on most bikes. The VFR needed to be
    partially dismantled to even have sight of the things. Valve
    clearances on boxers could be done, even by me, in half an hour. On
    the VFR, you needed to remove fairing panels, fuel tank, radiator, and
    purchase Honda service tool 07GMA-ML70100. Similarly, carb balancing
    was a breeze on the BMW, but best left to grown-ups on the VFR.
    I had a bit of an issue with water in the fuel tank on the BMW. It
    was a matter of moments to pop off the float bowls, pour the fuel back
    into the tank and discard the dirty water in the bottom of the bowl.
    A similar problem on the VFR would have required a recovery truck.
    The barrel, piston and cylinder head replacement was due to me
    exceeding the recommended service interval on the exhaust valve
    (60K). Replacing the damaged items with secondhand bits from
    Motorworks cost me less than, say, replacing a cam belt on your
    average modern car would have. On the VFR, a dropped valve would have
    seen the brute parted out. The barrel, piston and cylinder head on
    the BMW are not actually service items themselves.
    platypus, Apr 27, 2010
  10. malc
    Yep, every 16,000 miles usually. That's usually when the airbox etc
    needs to come off to do carb balancing and valve clearances anyway so
    it's no big deal to do plugs at the same time. If my bike was in
    constant need of new plugs I'd be getting shot of it.
    Lozzo, Apr 27, 2010
  11. And ShiteOldBoxers had a red lead coating on the inside of the tank, so
    the things didn't rot away like bastard Ducati tanks.
    OTOH, the red lead coating could break up and clog the carbs, which was
    why I fitted inline filters on mine, plus carried a couple of spare ones
    in the toolkit....
    The Older Gentleman, Apr 27, 2010
  12. malc
    That's some really extreme and devious perving - breaking your prong.
    Takes all kinds, though.
    Pip, Apr 27, 2010
  13. malc
    And the tanks are available in plentiful, reasonably-priced supply.
    platypus, Apr 28, 2010
  14. malc
    'Hog Guest
    <sucks teeth>
    While tempting fate I'd have to say that a properly prepared (unfaired)
    SOAirhead is the most reliable bike one could run and the easiest to repair.
    'Hog, Apr 28, 2010
