Has anbody ever tried Leak Proof fork seals?
Discussion in 'Motorbike Technical Discussion' started by Albrecht, Apr 12, 2007.
  1. Albrecht
    Albrecht Guest
    Last time I thought about replacing fork seals, I asked the parts guy
    at the Screwzuki $teaker$hip if he had Leak Proof fork seals on hand.
    He didn't have them, so I postponed the replacement.
    This is what Leak Proof claims:
    Leak Proof Fork Seals
    All Leak Proofâ„¢ Seals are made in the USA and include a Manufacturer's
    Lifetime Guarantee. Sold in pairs. Teflon-coated to reduce seal drag
    by up to 80%. Pro-Moly Fork Seals Superior to other moly fork seals
    with a thin coating of moly which wears off. Made of a special rubber/
    moly blend that results in a permanent 20% reduction in stiction for
    smoother action and less wear on sealing surfaces. American Classicâ„¢
    Fork Seals Patented ‘Pressure Balanced’ design floats in the seal
    cavity adjusting to varying pressure spikes under all conditions for
    longer life and less drag.
    http://www.motohaus.com/html/seals/leakproof intro.htm
    In 1970 Leak Proof Fork Seals were introduced to the Motorcycle
    industry - at first only a few applications were available, mostly for
    dirt bikes. The popularity of these fork seals also created a huge
    demand for seals for the ever popular street bikes. Leak Proof Seals
    responded by making fork seals for more and more makes and models of
    motorcycle.
    So popular were Leak Proof Seals that at one time they were OEM
    replacement seals for Triumph and Husqvana.
    Now, over 25 years later, Leak Proof Seals manufacturers fork seals
    for virtually every motorcycle made!
    Advanced Design From Hydraulics Technology
    Leak Proof Seals patented 'PRESSURE BALANCED' design performs unlike
    any ordinary fork seal. Made of state-of-the-art material, the seal is
    allowed to float in the seal cavity, adjusting automatically to
    varying pressure 'spikes' under all conditions, thus resulting in
    longer seal life and substantially less seal drag (stiction).
    'Push Fit' Installation
    Leak Proof Seals feature easy 'PUSH FIT' installation unlike stock
    seals which are 'PRESS FIT' and often require special tools to remove
    and install. Leak Proof Seals are pliable and can easily be installed
    with just the forefinger and thumb, making it problem free for the
    shop mechanic or do-it-yourself consumer. Detailed instructions are
    included with every kit.
    Lifetime Guarantee
    Provided that the seals have been correctly installed and the
    associated fork components are in serviceable condition, each and
    every set of Leak Proof Seals is backed by our LIFETIME GUARANTEE.
    Inventory And Packaging
    Because Leak Proof Seals cross reference to many makes and models,
    dealer inventory can be kept to a minimum while covering a large
    number of motorcycles. For example, 20 of our most popular Leak Proof
    Seals part numbers cross reference to over 200 OEM part numbers of the
    four Japanese manufacturers. They are simply a must for the multiple
    brand dealership!
    Leak Proof Re-Invents The Fork Seal
    With the Competition Dirt and Street rider in mind, we have developed
    the new Leak Proof PRO-MOLY fork seal. Originally, we took our basic
    Leak Proof Seals and applied a thin coating of moly. While this
    process has helped reduce stiction, the moly coating was susceptible
    to wear and would eventually wear through. Now, we have produced a
    material consisting of a rubber/moly blend which provides permanent
    moly performance lasting the lifetime of the seal. This results in
    over 20% reduction in stiction over the stock seal.
    Our PRO-MOLY line is also backed by our unique LIFETIME GUARANTEE and
    is packaged in four colour, bright neons. We have selected our 25 most
    popular dirt and street seals for production in our unique moly blend.
    Leak Proof Seals
    Performance under Pressure
  2. <snip>
    Jeez, just post a url next time....
    All seals will leak eventually, some time. God's immutable law. I find
    it hard to believe that aftermarket ones will be significantly better
    than units fitted as OE, but if they're cheap and available, why not
    try them?
    chateau.murray, Apr 12, 2007
  3. Albrecht
    Gene Cash Guest
    I tried them on my RZ-350 and my VF750S Sabre. They worked, and yes,
    they were easier to install, which is why I became interested in them.
    They never leaked and they never came back out, so I guess that would be
    a positive sign. I was worried if they were that easy to install, then
    they might be easy to blow out.
    However, after all my leaky seal problems is when I started using fork
    gaiters, so that may also have helped things not leak.
    -gc
    Gene Cash, Apr 12, 2007
  4. Albrecht
    Gene Cash Guest
  5. Albrecht
    Albrecht Guest
    I usually don't post an URL, unless I am going to discuss the subject
    at length.
    Some users on other groups find amusing web sites in their idle
    surfing, and they post
    links in messages with enigmatic subject lines.
    I could spend my whole day, sniffing their trail, without gaining any
    useful knowledge whatever.
  6. Albrecht
    Albrecht Guest
    I dunno. Maybe?
    www.motohaus.com may not be Leak Proof's own website. Motohaus.com
    also hosted an overly-active motorcycle e-mail group that I once
    subscribed to. I used to delete 300 unread e-mails from them every
    day.
    Leak Proof seals were listed in the 2006 Tucker Rocky catalog.
  7. But you did ;-)
    The Older Gentleman, Apr 12, 2007
  8. Albrecht
    Roger Hunt Guest
    wrote
    I tried some "leak proof" (no idea if it is the same outfit) fork seals
    years ago, and they were so bloody tight around the stanchions the front
    suspension wouldn't move.
    Waste of time and money.
    Roger Hunt, Apr 12, 2007
  9. Albrecht
    James Clark Guest
    Do you do it any other way?
    James Clark, Apr 12, 2007
  10. Albrecht
    Albrecht Guest
    Given the choice between verbosity and vagueness, I prefer the former.
  11. Albrecht
    Wudsracer Guest
    <snip>
    I've had bad results from leakproof seals, both in dirt bikes (tried
    several times on various dirt bikes from early '80s to 2000 models)
    and street bikes (late '80s.) Leakproof seals have invariably
    started leaking earlier than the more "conventional" fork seals.
    They were all installed correctly.
    The best, and longest lasting, fork seals that I have used are the
    Japanese NOK fork seals. They are generally more expensive, but well
    worth it.
    If they are not available for your bike, you might try the
    inexpensive K&S fork seals. I have had pretty good service out of
    them; but not nearly the same service as from NOK seals.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
    Wudsracer, Apr 13, 2007
  12. Albrecht
    Roger Hunt Guest
    Wudsracer wrote
    Roger Hunt, Apr 13, 2007
  13. Albrecht
    Mark Olson Guest
    Wudsracer wrote
    Mark Olson, Apr 13, 2007
  14. Albrecht
    Albrecht Guest
    I think you have it backwards. TOG wants to debate for the sake of the
    game, rather than discuss the objective merit of supposedly "leak
    proof" fork seals,
    which he has never used.
    If my web browser is set to display the format of this group in
    English, the threads are called "Discussions". If I set my browser to
    display the format in Spanish, the threads are called "Debates".
    "Debate" sounds more like an invitation to argue, but, when I read
    Spanish language newsgroups, I find that the participants are usually
    quite well behaved, compared to the participants of English language
    groups.
    Discussion and debate are words with similar meanings.
    To "discuss" something involves taking the subject apart and analyzing
    it.
    Discussions should take place without ad hominem attacks.
    To "debate" also involves analysis of the subject, but it goes further
    than analysis. Debate involves apparently logical rhetoric and
    maneuvering to somehow cause one debator to accept the other debator's
    viewpoint.
    Many debators believe that somebody should somehow "win" the debate.
    But two debators often have a clash of logic and rhetoric and part
    with neither side having changed their original point of view.
    What actually happens, is that the "loser" in the debate considers
    better arguments and tries to "win" the next discussion, because he
    firmly believes in certain ideas.
    Somebody once said that ideas were neutral, but rigidly-held beliefs
    caused wars...
    Yes, I most certainly did introduce the topic with a succinct
    question. That's the way interesting technical discussions are often
    started.
    And I posted Leak Proof's claims to see if anybody could argue
    directly with
    their ideas about fork seals. I have never used Leak Proof fork seals,
    so far as I can recall.
    I did NOT want to get into meta-discussion over how this group should
    be used or who should be allowed to offer their experience or
    knowledge of the subject, or how long-winded the post should be.
    I wanted to hear from people who had actually used Leak Proof seals.
    So far,
    I've heard from about three people who've used them, two responses
    were negative, and one response indicated that fork gaiters may have
    kept leakage from occuring by excluding road grime.
    If you have ever used Leak Proof fork seals and want to share your
    experience, then please do so.
    Albrecht, Apr 13, 2007
  15. Albrecht
    Albrecht Guest
    "Advanced Design From Hydraulics Technology
    is
    longer seal life and substantially less seal drag (stiction)."
    The above statement from Leak Proof made me wonder if fork oil
    wouldn't just weep past the outer perimeter of the seal as it
    "floated" in the seal cavity.
    Did you ever observe any such leakage?
  16. Albrecht
    Wudsracer Guest
    First, before I reply, I hope that you all will indulge me a short
    "side note".:
    This is a very good and instructive group. I've started posting here
    to hopefully pay back some of what I have gained by lurking in the
    background. The assembled knowledge and experience here is truly a
    resource.
    I originally started looking in here when the flame wars and drivel
    got to be to much for me to find all the tech content that I crave on
    rmd, which is still my "home group" and primary group.
    (I have been posting there since 1996, and have between 6 & 8K posts
    there in that time period, from different profiles. Not all of it is
    worthwhile reading, but I have nearly always tried to take the high
    road in my discussion participation.)
    Each of the principle posters here has posted information which has
    helped me, both in my former business and in my pastime (obsession)
    for keeping both my bikes and my friends' bikes in good working order.
    From the first paragraph of this post, one can easily surmise that i
    don't care much for flame wars or what I consider to be petty
    bickering.
    Not knowing everyone, it is hard to tell where the line is between
    friends ragging on friends and simple petty trollish bickering.
    I'm bringing all this up, because lately I have seen more and more
    antagonism filter through the posts here. It worries me, as I want to
    keep getting all the resources from this group that I can possibly
    get.
    I want this newsgroup to stay healthy and grow.
    Even though I can see everyone's (I mean everyone's) point in what
    they say, that doesn't mean that we can't agree to disagree in a
    congenial manner.
    Why can't we all just throw out (contribute) the info that we can
    share, and then pick it apart in a logical, factual, and constructive
    manner, without animosity.
    Personally, a lot of my information is from what others have shared
    with me. A lot of it comes from my personal experiences from 45 years
    of riding and working on my own bikes. (I am currently 54 year of
    age.) A whole lot of my info comes from running a general motorcycle
    and atv shop for nine of the last ten years, and asking questions from
    a lot of industry resources. The shop was primarily an off-road race
    shop for dirtbikes and atvs, and a franchised GasGas dealership. We
    also did some street bike repair, when we were talked into it, and the
    shop work was slow.
    (We closed the business last June 1st. All that is left of the shop
    is some remaining inventory and the bulletin board from the web site.
    http://www.smackovermotorsports.com/bb/index.php )
    Nevertheless, I realize that I don't (and never will) know anywhere
    near everything, and also realize that not everything that I think I
    know is completely true. It is just the truth as I have come to
    believe it to be.
    I really like it when someone can correct me when I am incorrect,
    and help me know what is correct.
    Repeating myself, I want to thank each poster for the help that they
    have (unknowingly) given me in the past in my capacity as a lurker.
    I make this statement/plea to the group to please not let BS get in
    the way of keeping this newsgroup the quality resource that it has
    been to me.
    Please pardon my long winded off-topic ramblings, and please take this
    in the constructive way it was intended.
    Now, to answer your questions.
    On the different dirt bikes I have installed the leakproof seals,
    they have always "weeped" at the sealing surface; and in one case a
    seal blew out of it's seating area altogether. I think that the
    momentum the seal gained by moving, just continued when the forks
    bottomed ('87 430 WR Husky) and took out the keeper ring/clip with it
    on the seal's way up the fork leg. That was the last time that I used
    them on a friend's dirt bike.
    I had better luck with the Leakproof seals on my old XV920RH ('81
    Euro model) forks. Still, they started weeping and then leaking
    within one year after installation. The OEM fork seals worked
    perfectly for 6 years.
    Except for the above mentioned incident where the fork seal traveled
    up and out of it's seating area, I have not observed any leakage
    around the outside of any Leakproof fork seals. (The range of movement
    that the Leakproof seals require is only about 1/8", if I remember
    correctly.)
    I stand by my recommendation of NOK fork seals.
    Good Riding to You.
    Wudsracer/Jim Cook
    Smackover Racing
    '06 Gas Gas DE300
    '82 Husqvarna XC250
    Team LAGNAF
  17. That's not what I said, though, is it?
    So nothing to do with being made to look a fool again (wasn't it
    something to do with your interpretation of what fibreglass was?) and
    hoping nobody will notice your new persona, then?
    The Older Gentleman, Apr 13, 2007
  18. Which is fairy nuff.
    In many, many instances I find that OE is best. Seals, exhausts,
    cables....
    There are exceptions - suspension is a good instance, especially on
    budget bikes. Brakes, sometimes. Bearings - almost always available
    elsewhere, to the same quality, and cheaper. Electrical items.
    But for serious stuff, it's always wise to assume that the manufacturer
    knows better than you do.
  19. Albrecht
    Albrecht Guest
    I don't know what fiberglass is? Hah!
    Pay close attention now. I was laminating fiberglass for aerospace
    vehicles when you were still making model airplanes. Some of the
    fiberglass that I laid up in 1968 went to the Moon and back in 1969.
  20. But it wasn't a thermosetting plastic? (Or whatever it was pointed out
    to be?)
    Look, cheer up, chill out. Morphing constantly is the hallmark of a
    troll, and you ain't that. You're knowledgeable - with the distressing
    tendency to make howling errors and then try to walk away from them. Get
    over that hump, and your utility rate will increase a hundred-fold.
    The Older Gentleman, Apr 14, 2007
