harley manual
Discussion in 'Australian Motorcycles' started by F Murtz, Nov 19, 2010.
  1. F Murtz
    F Murtz Guest
    Would a service manual for a 2008 softail work for a 2009 flhr road
    king, or are the engines different?
  2. F Murtz
    atec77 Guest
    SImilar brand tractor so it should be near enough
    atec77, Nov 20, 2010
  3. F Murtz
    F Murtz Guest
    Thanks, I rung a dealer after I posted and he said same engine different
    mounting.
    F Murtz, Nov 20, 2010
  4. F Murtz
    JustBiggus Guest
    You tie the rope to the same point on it before throwing it off the
    bow.
    JustBiggus, Nov 20, 2010
  5. F Murtz
    Toosmoky Guest
    Cases are different, Softy has a balance shaft and a solid mounted
    engine, the Road King has a rubber mounted engine and no balance shaft.
    Toosmoky, Nov 20, 2010
  6. F Murtz
    atec77 Guest
    Never having owned anything but knuckles pans and sportys I have to
    wonder at "balance shaft"
    Kinda makes me smile
  7. F Murtz
    F Murtz Guest
    Snot mine, it's the son's.
    F Murtz, Nov 21, 2010
  8. He has woken up
    so, when are you going to?
    George W Frost, Nov 21, 2010
  9. F Murtz
    F Murtz Guest
    No thanks I will stick with my 28 year old R100.
  10. Ahh well,
    I guess there is no hope for you
