Greetings folks. I am having some difficulties starting my old GPz lately. After it sits long enough to cool off (3-4 hours @ 15 Celsius) it is almost impossible to start. Thus far I have, changed the plugs (old ones looked fine) made and installed new plug wires (old ones were a bit corroded where they screw in to the terminals), cleaned the carbs (they were spotless) checked the compression (148-152-150-149) installed a new battery, measured the resistance of the coils (within specs) to no avail, checked the petcock ( works fine), and checked for air leaks at the carb boots (none). It will kick once immediately upon the first hit of the starter button, with the choke applied, as though it was going to start, then just crank forever.. The first time it happened I just cranked the heck out of it (sorry starter but had a buddy impatiently waiting to go for a ride) till I had to boost it to continue, still nothing, then I did the unthinkable and used some <I know its bad> quickstart and eventually it caught and started and ran fine.Once its running it runs like a new bike, although it surges a bit at idle, that is, the idle sometimes, not always, fluctuates between 1500 and 2000rpm, other times it idles smoothly at about 1500. The next time it happened it was a bit cooler out in my garage, about 6 degrees Celsius, so after an unsuccessful 2 or 3 minutes or so of cranking, I put the cover on the bike, placed a small heater underneath and let it warm for an hour...damn thing sparked right up.This bike can't be that cold blooded (can it?). My friend has a ZL1000, essentially the same engine, his bike sits outside and it sparks right up every time. Help! I'm pulling my hair out here, any ideas/comments/suggestions?????? Tom B 1983 GPz550 1984 KZ1105 1985 GPz900
