hard kicker
Discussion in 'Motorcycle Technical Discussion' started by Michael Killenbeck, May 7, 2005.
  1. I have a '79 Sportster 1000 with a kick start and a S&S Super B carb.
    Problem is it's a real pain to kick over when it's been sitting for more
    than a hour or so. Sometimes 20+ kicks! After it's been running it
    start on two or three kicks. I cleaned the carb, changed the plugs,
    checked the point gap and the timing. Still a pain to get going. Any
    suggestions?
  2. Michael Killenbeck
    wws Guest
    How's your battery?
    wws, May 7, 2005
  3. The battery seems fine meter reads 11.5 volts.
  4. Michael Killenbeck
    wws Guest
    Too low.
    12.7(minimum)should be 13 or better.
    wws, May 7, 2005
  5. I'll charge it and see what happens, thanks.
  6. "Michael Killenbeck" <>
    wrote in message
    SNIP
    Let it set for a couple hours before you test it.
    Testing right after it comes off the charger MIGHT
    give a false reading. Also if the battery checks
    out Ok then you need to check your charging
    system...I have a DUMB question, just how old is
    that battery? I've 4+ years on the one in my wing
    and it's still strong BUT just like a cage after 4
    years I expect it to fail any time now.
    Keith Schiffner
    RCOS #7
    Assistant to the Assistant Undersecretary of the
    Ministry of Silly Walks.
    "terrorist organization" is a redundancy
    Keith Schiffner, May 7, 2005
  7. Next time you get that bad puppy fired up and warmed up so it will
    idle, squirt some WD-40 at the throttle shaft seals. S&S carburetors
    are known for
    leaky throttle shaft seals, and, if the engine is sucking *air* through
    leaky seals, it will idle faster when you spray WD-40 at the seals, and
    you will know you have to replace the seals, or buy a modern Japanese
    carburetor...
    Harleys have enough problems with low vacuum in the intake tract as it
    is, without having *air leaks* right at the throttle butterfly of a
    copy of some obsolete carburetor...
    Japanese Mikuni or Keihin carburetors are so much improved over those
    primitive old-fashioned carburetors, only a die-hard would put up with
    them----or somebody who understands what Harleys are all about and know
    what is happening...
    I don't hate Harley Davidsons or Harley riders and I'm not trying to
    put anybody down. This is just what is happening when a Harley is hard
    to start...
    Harley Davidson has used that trademark narrow angle V-twin design for
    about 100 years, but many riders just don't seem to understand what it
    is that's "better" about a V-twin...
    Better than what? A V-twin is better than a single cylinder engine
    because it has twice the number of cylinders and it runs a bit smoother
    than a single. If you can get one cylinder to fire, the other will get
    dragged along faster and it will start firing, too
    Big single cylinder engines are hard to start because vacuum in the
    intake tract downstream of the slide is low, and vacuum doesn't build
    up fast when you're kicking an engine over. The fuel flowing through
    the idle jet that's supposed to start the engine hardly gets started
    through the intake tract when the vacuum stops and whatever fuel might
    get started flowing quickly settles out on the "floor" of the intake
    passages...
    So on the first few kicks, the engine is getting a weak mixture, and
    maybe a few kicks later, it's getting a mixture that's too damned rich,
    because repeated starting attempts pick up that gasoline that has
    pooled on the floor of intake tract...
    Owners of big single cylinder engines learned to turn the idle SPEED
    screw all the way down for cold starts. That would increase vaccum
    downstream of the throttle slide, so a richer mixture would be drawn
    into the engine sooner. They would start the engine, warm it up while
    nursing the throttle to keep the engine running, and then readjust the
    idle speed when the engine was warm enough to idle. They learned to do
    this *every time* they started the engine after a few days of not
    riding...
    They also learned the proper way to use the choke. Full choke, NO
    throttle, ignition retarded, kick the engine several times until it
    started popping a little. Then they would open the choke part way, give
    the engine a little throttle and kick and it would usually start up...
    Instead of a real choke plate, a lot of old British bikes had a
    "tickler" in the float bowl. The tickler rod pushed the float down,
    holding the float valve open. This would flood the carburetor so the
    engine wouldn't need to make so much vacuum to draw fuel up into the
    throat...
    Having a mechanical ignition advance and retard lever was a good thing,
    too.
    If the rider tried to kick start the engine with the ignition advanced,
    it might backfire and push his leg up in the air and hurt him...
    Harley Davidson's have used primitive carburetors for years. Some of
    the rider stick to old, obsolete designs because of tradition, because
    they think it makes the bike look "cool" to have an old-fashioned side
    draft carb
    like the old Tillotson's we suffered with in the 1950's. My 1949
    Whizzer motorbike had a Tillotson and it was very hard to start.
    Besides the problem of low vacuum in the intake tract, there is the
    problem of firing order. The Harley engine fires a-ONE! and a-TWO! and
    a BLUB BLUB, and repeats, with a lot of degrees of crankshaft
    revolution between intake strokes. Vacuum in the intake tract drops
    off, gasoline settles to the bottom of the intake passages, waiting
    there to be sucked up by the next intake strokes and flood the
    cylinders....
    And, since the single primitive carburetor is feeding BOTH cylinders,
    one cylinder will always try to ROB the other cylinder of the weak
    mixture it has just inhaled. It will try to suck that fuel back out of
    the intake tract. I remember watching my outlaw biker neighbor try to
    kick start his chopper. He was a member of the Galloping Gooses MC. He
    came out in his sneakers and took the right sneaker off and put on a
    pole climber's boot and laced it up and started kicking that big twin
    until he was sweating and out of breath. I was amused, so he said to
    me, "You wanna come over here and show me how it's done?" So I jumped
    over the fence and went over and tried to kick the engine over. I
    couldn't even budge the kick starter against compression, with a lean
    mixture in the cylinders and the ignition
    couldn't be retarded. If that engine had backfired on me, it would have
    kicked me to the Moon...
    krusty kritter, May 7, 2005
  8. Thanks for all the info.
    Michael Killenbeck, May 8, 2005
  9. You're welcome, Rusty...
    A long time ago, in a universe far, far away, I was a dirt bike racer.
    I had a little Yamaha 250cc 2-stroke single, and I didn't know how good
    I had it, until a guy at work learned that I raced dirtbikes in the
    desert and he wanted to come along too...
    He had a Greeves MX-5 250cc 2-stroke single and I had lusted for the
    Greeves when I first saw one, I thought it was as ugly as an English
    Bulldog and that ugliness gave it character. But I couldn't afford one
    at the time and the Yamaha Single Enduro caught my eye. Yamaha was
    offering a
    Genuine Yamaha Tuning Kit that included a ported cylinder, high
    compression head, expansion chamber and a larger VM-30 Mikuni
    carburetor to replace the small VM-26 carb the bike came with...
    My friend's Greeves was equipped with an Amal concentric float
    carburetor. The claim to fame of the concentric float carburetor was
    that lean angles didn't affect it like the old Amal Monobloc carbs that
    would cut off the gasoline supply at high lean angles...
    That wasn't such a bad deal if a 2-stroke engine loaded up and fouled
    the spark plug. The rider could lean the bike all the way over to one
    side and the float would shut off the flow of gasoline to the carb...
    I watched world champion motocross racers doing that on their CZ's when
    they would foul out a plug...
    My friend couldn't do that lean it over bit with his Amal Concentric
    carb though. He was stuck with a motorbike that had a
    Frankenstein-designed kick starter lever that would break his foot if
    he kicked the engine all the way through with his foot properly
    positioned on the pedal. If he put his foot at an angle on the pedal
    and kicked the engine over, his foot might slip off the pedal and it
    would hit him hard in the calf...
    And the damned Amal Concentric was still primitive, all it had was an
    idle screw, a main jet and a needle jet. He would keep fouling spark
    plugs trying to start the engine, and when he would finally get the
    engine started, he would want to ride the bike immediately...
    I kept telling him to rev the engine up and blow out the excess rich
    mixture, but he wouldn't do that, because the damned transmission would
    only shift gears at *idle*. He expected that moronic English Bulldog of
    a Greeves to actually idle like some Honda 4-stroke...
    He was one of the most stubborn people I've ever met, he really had to
    suffer to learn...
    But the Mikuni carburetor on my Yamaha was much improved over the Amal
    carbs the Japanese had studied and originally copied. The Japanese
    engineers cleverly cross-drilled the needle jet with emulsion air
    holes, and they did the same thing to the idle jet, it had emulsion
    holes too...
    Those tiny little holes allowed air to mix with and "emulsify" with the
    gasoline, so the fuel was broken up into tiny mist particles that the
    engine could burn ever so much easier than the big rain drops of
    gasoline the Amals were feeding to the Greeves engine...
    I loaned my spare VM-26 Mikuni to him and a selection of extra jets. I
    told him that a VM-30 would probably be just fine for his Greeves, but
    he asked around and others told him that he could use a VM-34 with no
    problems, so that's what he finally bought. He was very happy with the
    much-improved Japanese carburetors, and one day he really surprised me,
    he finally admitted to himself that his frame was bent, just like I'd
    been telling him for about 2 years. He got the frame straightened so
    his good-running Greeves didn't run down the road like a puppy dog...
    Several years later, I happened to see a big Suzuki 750cc street bike
    that was for sale, and I also noticed the owner had a Greeves MX-5 for
    sale, too. I was curious about the Greeves and asked the guy about it.
    He told me what he wanted for it, and I told him that I was really
    interested in the Suzuki. He said he would *give* me the Greeves, if I
    bought the Suzuki.
    I turned him down on the free Greeves. It might have made a good post
    for a mailbox, if the kids didn't steal it...
    krusty kritter, May 11, 2005
  10. Michael Killenbeck
    Nemo Guest
    Are you sure that will still work? WD40 replaced the butane as propellant a
    while back. The new propellant is non flammable.
    Ed Cregger
    Nemo, Aug 8, 2005
  11. Michael Killenbeck
    John Johnson Guest
    If you're talking about the richening of the mixture, and subsequent
    increase in idle speed, this should still work. AIUI, the effect results
    from blocking the air leak and could be accomplished by spraying _any_
    liquid onto the relevant parts. WD 40 is cheap, convenient, and won't
    cause any strangeness inside the engine if it leaks in. Mind, the
    volumes of water that we're talking about likely wouldn't either...
    Later,
    John
    John Johnson, Aug 8, 2005
