Happy Dance
Discussion in 'UK Motorcycles' started by Monz, Aug 12, 2005.
  1. Monz
    Monz Guest
    The gixer is now the proud owner of two shiny new wheels with shiny new
    tyres on (makes mental note) I is officially a happy bunny again.[1]
    On the minus side whilst fitting new wheels and tyres noticed dirty great
    scrape on fairing :(
    [1] Removed wheels swapped all furniture (bearings, seals, disks and
    carriers) myself... quite chuffed.
    Monz, Aug 12, 2005
  2. Monz
    JB Guest
    How did you manage to get the bearings out without damage? I've always
    replaced any wheel bearing I've had to remove 'just in case' even if they
    still seemed to be ok.
    JB
    JB, Aug 12, 2005
  3. Monz
    What happened with your wheels then? Why did you swap them over? You did
    use thread locking compound on the disk bolts didn't you?
    Muck, Aug 12, 2005
  4. Monz
    dwb Guest
    <Waits for the "and then the front wheel just fell out" post>
    dwb, Aug 12, 2005
  5. Monz
    Monz Guest
    On the advice of a mechanic, patiently tapped them out using a rammer and a
    drift... he had a look at them before I put them into new wheels and said
    they were fine... dum dum duuuuuuum!
    Monz, Aug 12, 2005
  6. Monz
    Monz Guest
    See "Wanted GSXR1000K4 Wheels and Tyres" thread. And yes I did use
    threadlock :eek:)
    Monz, Aug 12, 2005
  7. Monz
    Monz Guest
    You are a little ray of golden sunshine, aren't you? :eek:)
    Monz, Aug 12, 2005
  8. Monz
    dwb Guest
    I just judge others on my own mechanical abilities!
    Anyway, you've proven you don't need (round) wheels on your bike to keep it
    upright, so I wouldn't be worried.
    dwb, Aug 12, 2005
  9. Monz
    JB Guest
    If you tapped them out by hitting your drift (rammer!) on the inner bearing
    race which the wheel spindle goes through, expect to have to replace them
    soon. This is an almost guaranteed way of destroying the bearing. You can
    *sometimes* get away with using an 'expanding collet' type of bearing
    extractor on wheel bearings where you can't get to the outer race.
    Sorry to be a bearer of bad news and all that, but your 'mechanic' should
    know better.
    JB
    JB, Aug 12, 2005
  10. Monz
    Ahhh... that'll be it.
    Muck, Aug 12, 2005
  11. Monz
    Monz Guest
    Ok... will ask him and quote your advice, he has been a 'bike mechanic' for
    20 odd years and used to mechanic for a F1 Superbike team so I took his
    advice not knowing any different.
    Thanks for the tip.
    a rammer = hammer
    Monz, Aug 12, 2005
  12. Monz
    dwb Guest
    If you picture a bright light reflecting off my head it might help, but
    otherwise I agree 100%.
    dwb, Aug 13, 2005
  13. Monz
    zymurgy Guest
    You and your bloody thread lock [1]. You worry too much ;-)
    The industial revolution survived without threadlock ffs !
    Cheers
    Paul.
    [1] The only threadlock I generally use on the bike is on sprocket
    bolts and big end bolts. These would be rather unpleasant to lose at
    high speed. Usually anything that absolutely has to stay on the bike
    will be staked, nylocked or split pinned on.
    zymurgy, Aug 13, 2005
  14. Monz
    I've found something else to worry about now. Copper grease and aluminum
    alloys in things like brakes. Apparently, the copper in the copper
    grease corrodes the aluminum alloy, which can't be a good thing where
    brakes are involved. So.... so I'm told, the thing to use is called
    Corrosion block grease[1].
    [1]Which I now have a tub of.
    Muck, Aug 13, 2005
  15. Monz
    Well, you don't usually sit out in winter, in the rain and have to deal
    with fucked brakes and the like do you. Those who do, and have done
    before may take this on board, they may not, I don't really mind either
    way. I just know my brakes are going to be easier to take to bits than
    theirs when the time comes.
    Muck, Aug 13, 2005
  16. Monz
    I'm not talking about riding, I'm on about working on the things mid
    winter in rain and snow.
    Well, I don't really notice tbh.
    Muck, Aug 13, 2005
  17. Monz
    Did you have to make a mounting plate up for those or did they just fit?
    Muck, Aug 13, 2005
  18. Monz
    Bear says...
    I don't understand how your 9R brakes survived 3 winters riding without
    being garaged and didn't seize, given the lack of care and attention
    they'd had. Those 6 pot Tokico calipers are shite and horribly prone to
    corrosion. My old 9R is now sporting a lovely pair of juicy, fat and
    very effective 4 pot Tokicos from a TL1000S.
    Lozzo, Aug 13, 2005
  19. Monz
    Muck says...
    Straight fit. No modification needed at all. All the mounting holes
    line up exactly, the brake hoses come in to around the same position on
    the caliper and at the correct angle etc. Just take the shite 6 pots
    off and bin them, and stick the vastly superior 4 pots on, bleed brakes
    and away you go.
    Lozzo, Aug 13, 2005
  20. Monz
    Cooool.. :) I just wish that you hadn't binned the 6 pots. I could have
    used those.
    Muck, Aug 13, 2005
