Handy Hints.
Discussion in 'UK Motorcycles' started by Eiron, Feb 7, 2005.
  1. Eiron
    Eiron Guest
    1. Don't replace your old petrol pipes with black cotton-braided
    pipe from the car spares shop, no matter how cool it looks.
    The braid hides the perished rubber and doesn't show the leaks
    until they start gushing.
    2. Occasionally turn the petrol tap to "prime" while fettling
    so you can smell any leaks rather than discovering that your boots
    are soaked when stopped at traffic lights.
    3. Don't buy a Vauxhall. My naughty water pump seized, snapping the
    timing belt and breaking the tensioner pulley off the oil pump casing.
    Replacing the oil pump requires the sump to be removed, which
    requires the engine to be removed....
    Eiron, Feb 7, 2005
  2. Eiron
    Chris Soanes Guest
    Ow. I'm guessing that coupled with the possible bent valves/piston
    damage the things a write-off then? This happened to my dad (well, the
    water pump bit) on his diesel astra. Since then I always replace the
    water pump when doing a cam belt change. For the sake of 40 quid, it's
    worth it.
    Tiff, master of the art of untimely advice.
    Chris Soanes, Feb 7, 2005
  3. Eiron
    Eiron Guest
    No apparent valve-piston interference. Such a low compression ratio
    that there is oodles of clearance. They could have used the old
    sidevalve engine and still got the same performance.
    Eiron, Feb 7, 2005
  4. Eiron
    Catman Guest
    How true. Happens with all the fuel lines on the older Alfas.
    See above.
    www.cuore-sportivo.co.uk
    Catman, Feb 7, 2005
