Well that was almost a productive afternoon. Yesterday was a bumper day for deliveries. One from Amazon (early birthday presents - Let It Be...Naked on cd and Vernon God Little in paperback) and one from ART (belated christmas present to myself, a grey satin finish titanium race can) Ever since some tit knocked the bandit over, the brake light's been jammed on and the indicators haven't worked. Add that to the lack of illumination on the clocks, with the exception of the fuel gauge (which itself wasn't working) and I seem to have worked up a fair list of things to fix. So first things first, fitting the new can. All went disturbingly smoothly and 15 minutes after going outside, the engine's burbling away in a way that makes me consider dropping a note through my neighbours' letterboxes saying "Sorry"! :) So out comes the multimeter and the BoL and I set to work to try and work out what's causing the other problems. The fuel gauge is easy to fix - the connector under the tank is plugged together but the wires need a little wiggle. Sorted. Next up, the brake light. It seems when the bike was knocked over, the RHS footrest hanger bent slightly, causing the rear brake pedal to push against it and not sit fully home. Much grunting and swearing as I try and adjust the bloody switch in situ but either my fingers are too fat or the BoL leaves out some useful steps, like taking off the footrest hanger before pissing about with the rest. Another job done. Now for the indicators. Checking continuity from the relay to the switch, all seems well(ish). From one LHS indicator to the other, all seems OK. From one RHS indicator to the other, also well(ish), but I seem to have continuity from both 'poles' of the bulb mount on the rear to both on the front. I'm sure that's not right... Checking continuity through the switch, I seem to have a connection from the relay to both outputs, whether the switch itself is set to right, left or neither. Did I mention how much I fucking hate tracing electrical faults. At this point daylight's fading and I can barely see the wiring map, not to mention that I'm working out in the road and it's been threatening to piss down all day, so the panels go back on and I go for a quick spin up the A404 and round town with the new can. Suffice to say that I've yet to stick it on a dyno, but I'm with Blaney on this. The finish seems fine, the noise seems fruity as fuck and the way the front goes stupidly light when the throttle's whacked open in any gear suggests it certainly hasn't lost any horses. Don't suppose anyone's got a warm, well lit garage somewhere near Maidenhead and gets a kick out of holding one end of a multimeter probe against various bits of bike? No, thought not. Thanks anyway...
