Handlebars Vibrating
Discussion in 'Motorbike Technical Discussion' started by manjo, Jan 24, 2005.
  1. manjo
    manjo Guest
    At about 3000 rpm, the handlebars on my 1995 Kawasaki Vulcan 1500A will
    start to vibrate for 1-2 seconds, then stop for 10-12 seconds, then begin
    vibrating/shaking again.
    If I hold the bars firmly with both hands, it's less noticeable. If I just
    rest
    my hands on the bars, they will vibrate more. When I go faster/increase
    rpms, the vibrations start and stop sooner, and feel stronger.
    I plan to do the following:
    1. Have the front tire I put on the wheel myself, spin tested by the
    dealer.
    2. Check the steering head for wear.
    3. Replace the fork oil (since I'll have the front end apart :).
    4. Probably go ahead and replace the front wheel bearing (2nd set of KAW
    bearing that have about 60k miles on them).
    Please let me know if there are any other parts to check and/or replace that
    might be causing the vibrations.
    All tips, suggestions, and comments welcome.
    Thanks,
    Manjo 1995 KAW Vulcan 1500A9
    manjo, Jan 24, 2005
  2. manjo
    OH- Guest
    It's easy to determine if the vibration is excited by engine or wheels
    and final drive - just test in different gears.
    Sounds like a long shot to me, but checking it is never wrong.
    Even longer shot, but has other merits.
    Use rubber sealed bearings even if that is not original fitment. Buy
    bearings at motorcycle dealer if you really like the owner, you
    can usually get better prices at a general bearing supplier. OTOH,
    100 000 km on a set of bearings is not bad.
    The engine ? Partly joking, partly not. Do check that the engine
    mountings are tight and any rubber dampers are fresh.
    Have you changed anything on the handlebars ? Longer mirrors,
    heavier grips, cup holder, windscreen added and supported from
    the bars ? Anything that changes the weight, length or stiffness
    can change when and how much things vibrate.
    OH-, Jan 24, 2005
  3. manjo
    manjo Guest
    Ron,
    http://www.barsnake.com/products/barsnake.html
    Pretty interesting and a well thought out product. This may be the last try
    to eliminate the vibration. I hesitate to get one now, only because the
    vibration is a new phenomenon, and has to do with something that has
    changed, like my installing the tire, myself.
    Thanks,
    Manjo
    manjo, Jan 24, 2005
  4. manjo
    manjo Guest
    OH- Excellent idea. Will test this first chance (just got 2 feet of snow
    here and I'm off the road for a long while).
    OH- I put the front tire on myself backwards, and had to take it off and
    remount correctly (arrow towards direction of travel, my dumb :).
    I replaced a set of 5.5" x 4.5" risers with a set of 4" x 2" more
    substantial risers.
    I'm using the same w/s and w/s mount; same mirrors and grips; no cup holder.
    Same bar mounted tach and speedometer.
    I'll put the bike up on the lift and see if there's any play in the steering
    head. I can then remove the wheel and take it to the dealer's shop for a
    spin test.
    Many thanks for the ideas and suggestions.
    Manjo
    manjo, Jan 24, 2005
  5. Check the motor mounts and retorque bolts.
    Do your changes one at a time so you know what effect each one has.
    If you did them all at the same time and wound up with a new problem
    you'd have a hard time sorting out which one caused it. (This assumes
    you're doing the work yourself).
    Start with the easy low cost stuff first.
    Why would you have the front end apart and how would that make
    changing fork oil easier ?
    Rob Kleinschmidt, Jan 24, 2005
  6. manjo
    manjo Guest
    I'll be doing the work myself. I wish I had some warm weather and time to
    do one thing at a time, and then road test the change. I'm sort of
    snowed-in/frozen-in here in MA, for the next several weeks. I'm going to do
    all the stuff needed to be done over the next couple of months. I can run
    the engine in the garage, I just won't be able to safely :eek: do any road
    testing for a while.
    Last time I changed the fork oil, the drain plugs wouldn't budge. So I took
    the forks off the bike, drained them, and then re-installed them for the
    refill. I have some new bars to fit to the bike, so the old ones will be
    disconnected, the front wheel will be off to be spin tested, and the
    steering head will be apart to check the bearings, so most of the grunt work
    will be done when I change the fork oil this time. Out of curiosity, I will
    try applying some heat to the plugs this time, just to see if they loosen
    up. They were probably secured with Locktite Red, which I hadn't considered
    last time.
    Thanks,
    Manjo
    manjo, Jan 25, 2005
  7. manjo
    John Johnson Guest
    [snip]
    you might be better off just taking the forks off again. My VFR also has
    drain plugs, and I used it on one leg, just to see what it was like, and
    then did the other leg by dropping it and disassembling.
    I felt that taking it apart (not all the way, just removing the cap,
    spring and spacer) was no more trouble, and made measuring the fork oil
    level much easier. Since it was 16k maintenance time, I also took the
    opportunity to measure my springs and generally clean things out.
    John Johnson, Jan 25, 2005
  8. Only reason I suggested this is that shotgunning a problem can leave
    you unbelievably confused when you do six things and then discover
    something new is screwed up. I guess if you work your way through
    methodically, you ought to be fine.
    Do you ever see this problem standing still in neutral or have you got
    to be moving ? Sounds like an engine/drivetrain vibration transmitted
    through the frame, but I guess it could be lots of other stuff too.
    Rob Kleinschmidt, Jan 26, 2005
  9. manjo
    OH- Guest
    Exactly the kind of change that can effect vibrations, for better or
    for worse or just plain different.
    Good luck !
    OH-, Jan 28, 2005
  10. manjo
    manjo Guest
    I was thinking about this recently, too (I've been out of town for a week
    and just got back to the NG).
    In the past, when revving the engine in neutral to sync the carbs, I have
    seen the tach (Drag Specialties, bar mounted) vibrate as I hit 3000 rpm.
    I've thought nothing of it other than a V-twin quirk. It could be that the
    vibration has gotten strong enough to be felt (or I'm just now conscious of
    it :).
    But must say that the vibration I feel NOW, is a pulsing vibration that
    comes and goes within a 12-15 second interval: everything feels fine, then
    the bars will begin to vibrate, and then subside to no vibration. The
    looser I hold the bars, the more accentuated is the vibration. If I drop
    down to 2500 rpm I don't feel anything in the bars.
    Best regards,
    Manjo
    manjo, Feb 5, 2005
  11. If it tracks a given RPM then I'd definitely look hard at the
    engine and bar mounts.
    My bike has a well known vibration at about 4000 rpm. The suggested
    fixe is to torque the engine mount to 64 ft/lbs, which is quite
    a bit more than you might expect.
    I'd also take a long look at the bar mounts, yokes and frame. Drag
    out the manual and a torque wrench and torque everything in sight
    to the actual spec. I'm getting a lot more conscientious about this
    lately and it seems to help. Also, if the bars or engine are rubber
    mounted for viration isolation I'd consider swapping the mount rubbers.
    Finally, the standard question: What was the last thing you did to
    it just before the problem started ?
    Rob Kleinschmidt, Feb 8, 2005
