Handlebar(throttle) grip covers glue recommendations
Discussion in 'Texas Bikers' started by The Family, Jun 6, 2004.
  1. The Family
    The Family Guest
    My throttle grip, that was installed less than a year ago, has just
    come loose. Very strange initial feeling before you understand
    what's really happening.
    They(the new grips) were installed at Two Wheel World, and I
    saw the guy use some glue, that I presume came with the grips.
    I can see the remaining throttle slide is plastic, and I assume the
    grip inside is plastic also, so what kind of glue do I seek to repair
    this bond, without causing such a hold the grips can never be repl-
    aced again?
    Thanks - Gary
  2. The Family
    The Family Guest
    I looked, more carefully, at the inside of the grip, and it appears
    to be more like a rubber compound than plastic.
    My wife, the only one in the house with hair spray(actually the only
    one in the house with hair), says you're pulling my leg.... Personally,
    I think you may be correct, but speaking specifically of the sprays
    of old that were in the aerosol containers. Today, many sprays
    exist that may not have that "sticky" complement any longer.
    I'll see what I can dig up around here, and do a "sticky" test. At
    least it's readily available.
    Thanks for the tip Jack, I'll post my findings.
    Gary Walker
  3. The Family
    Bill Walker Guest
    He's not "pulling your leg" at all.. That "hair spray" trick works better
    than almost anything that you can use.. Takes a little longer to dry than
    super glue and is wet enough for the grip to slide one easily.. When it
    sets, there is plenty of bind on the grip and when you want to replace it,
    it will break loose with a little pressure.. Try it.. LOL.. Tell the wife to
    go get another spray can of "Hair Net" or whatever they call it these days..
    Good Luck..
    Your friend in Irving
    Bill Walker
    Bill Walker, Jun 6, 2004
  4. The Family
    The Family Guest
    I didn't really think Jack was pulling my leg, that's just what my wife
    said. However, how many grips has she ever installed?
    Gary
    The Family, Jun 7, 2004
  5. The Family
    Nemesis Guest
    Nemesis, Jun 7, 2004
  6. Go to the drug store and buy yourself a can of Aquanet and make sure
    it says that it's the best of all holds on the market.
    Aquanet is the best thing going.
    Then loan the rest of the can to your wife so she can tend to her
    stockings that have runners and hold fabric while it goes through
    sewing machines. There's all sorts of uses for that stuff...but don't
    bother with the yuppie gucci designer sprays!
    from Nettalk Live here is Jovan Philyaw, Jun 7, 2004
