Halogen lights for Bandit 600
Discussion in 'UK Motorcycles' started by rennison, Sep 13, 2003.
  1. rennison
    rennison Guest
    Just got meself a T-reg Bandit 600S. Anyone know if it's feasible to fit a
    halogen lamp to the headlight ?
    Ta.
  2. rennison
    Tim Guest
    Err, hasn't it got such bulbs already?
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm at dsl dot pipex dot com
    Tim, Sep 13, 2003
  3. rennison
    jsp Guest
    I don't know about that, but you can fit more powerful bulbs.
    If you're new to the Bandit, I would suggest you go and have a look at
    sukbog:
    url:www.sukbog.co.uk
    and subscribe to their mailing list (web based).
    Hmmm, my Bandit was T reg. I wonder....
    John
    SV650
    Black it is
    and naked
    jsp, Sep 13, 2003
  4. rennison
    rennison Guest
    Will do - cheers.
  5. rennison
    Alan.T.Gower Guest
    I fitted 100watt jobbies into my son's bandit.
    Alan.T.Gower, Sep 14, 2003
  6. rennison
    rennison Guest
    Blimey - now that *is* helpful.
    rennison, Sep 14, 2003
  7. rennison
    Martian Guest
    That's a mighty powerful poo!
    Martian, Sep 14, 2003
  8. rennison
    jsp Guest
    1. I haven't. you could ask the people on sukbog - someone there has
    done most things to a Bandit
    2. post replies at the bottom or you'll be flamed to hell and back.
    John
    SV650
    Black it is
    and naked
    jsp, Sep 14, 2003
  9. rennison
    Brian Garner Guest
    Oops. Apologies to all. I havent got used to this group yet.
    Head hung in shame.
    Brian
    Brian Garner, Sep 14, 2003
  10. rennison
    The lens is glass. Well, it was on my '99 Bandit 12S, anyway.
    AFAIK, all headlight lenses are glass - in any case, should it be
    plastic, the distance from lens to bulb should be great enough to
    avoid the lens melting from the additional heat given off from an
    uprated bulb. I've put 100 Watt main, 80 Watt dip bulbs in my last
    three bikes with no adverse effects.
    That's sound advice. They BOGgers know their stuff.
    That, too, is sound advice ;-)
    You will. You've taken the first steps.
    Pip, Sep 14, 2003
