halogen bulb wiring
Discussion in 'Australian Motorcycles' started by Zebee Johnstone, Feb 8, 2004.
  1. I've poked at it, but I'm not sure...
    so when you have a halogen bulb with it's 3 prongs
    Which is high, which is low, and which is earth?
    Zebee
  2. Zebee Johnstone
    Stevo Guest
    Assuming you are talking about a standard 'H4' bulb, if you look at the bulb
    carefully, you will see the two filaments, which are connected to a common
    pin at one end that should be the LHS of the parallel vertical pins, the
    other two pins will have lower resistances, the lowest being hi beam (other
    vertical pin) and the other then is low beam (horizontal).
    Remember to not touch the glass of the bulb with your fingers (or any other
    part of your body)...
    Stevo, Feb 8, 2004
  3. Zebee Johnstone
    Stevo Guest
    I meant 'different' --------------------^
    Stevo, Feb 8, 2004
  4. Zebee Johnstone
    sharkey Guest
    From the back of the bulb:
    low
    __
    earth | | high
    -----sharks
    sharkey, Feb 8, 2004
  5. Zebee Johnstone
    Lushy Guest
    NOw we all know something new
    Lushy
    Lushy, Feb 8, 2004
  6. Zebee Johnstone
    Theo Bekkers Guest
    "Lushy" wrote
    Not all of us. Certainly not Sharkey.
    Theo
    Theo Bekkers, Feb 9, 2004
  7. Nice troll.
    Hammo
    Hamish Alker-Jones, Feb 9, 2004
  8. In aus.motorcycles on Mon, 09 Feb 2004 23:00:32 +1100
    You really should calm down the paranoia. I think trolling's a childish
    attention getting device, and don' do it.
    It weas a genuine question, I'm wiring the Yam and need to know.
    Zebee
    Zebee Johnstone, Feb 9, 2004
  9. Zebee Johnstone
    sharkey Guest
    Nice meta-troll.
    -----sharks
    sharkey, Feb 9, 2004
  10. In aus.motorcycles on Mon, 09 Feb 2004 21:17:09 GMT
    Are there non-nice trolls? And would the meta be a non-nice meta-troll
    or a nice meta non-nice troll, and is a nice meta-troll a non-nice meta
    non-nice troll?
    Zebee
  11. Zebee Johnstone
    sharkey Guest
    Uh, Zebee? I'm just going to go make a cup of coffee. Hopefully
    this post will have expired before I get back and my brain explodes.
    -----sharks (too early)
  12. I think Zebee's been drinking your coffee!
    Pisshead Pete, Feb 9, 2004
  13. My head hurts ....
    ANAESTHETIC!!!!!!
    Kevin Gleeson
    Technical Director
    Blue Rocket Productions
    Hobart, Tasmania, Australia
    www.blue-rocket.com.au
    Kevin Gleeson, Feb 10, 2004
  14. Bwahhahahahahahahahahaha!
    I don' do it either Mon, I is a Rasta, aye!
    Hammo
    Hamish Alker-Jones, Feb 11, 2004
  15. Is that the best you can up with, Hippy?
    Sharkey likes Zebee, Sharkey likes Zebee...
    Hammo
    MRI scan can prove it!
  16. You need to work on your nomenclaturrreee.
    Hammo
  17. With the Rohypnol?
    Hammo
