Hagon
Discussion in 'UK Motorcycles' started by Dan L, Mar 18, 2007.
  1. Dan L
    Dan L Guest
    Namely Hagon Nitro Adjustable Twinshocks and progressive fork spings.
    I know for a fact that one of the Zeph's rear shocks is fucked, so are
    therefore considering doing the rear end with Nitros and the front end
    with progressive springs.
    2 questions:
    1. Hagon: Good, bad or indifferent? (their chap at the bike show seemed
    like a jolly nice bloke).
    2. Anyone fancy a spot of spannering assistance and setting uppage?
    Chars
    Dan L
    http://thebikeshed.spaces.live.com/
    1996 Kawasaki ZR1100 Zephyr
    BOTAFOT #140 (KotL 2005/6)
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  2. I'll come and watch and pass spanners as part of my ongoing 'learn how
    to do it' quest.
    Work in progress, Mar 18, 2007
  3. Prints post for blackmail purposes.
  4. Dan L
    Dan L Guest
    Work in progress coughed up:
    Heh, you can make the tea and bacon sarnies, woman.
    <fx runs for cover and hopes SWMBO isn't lurking>
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  5. Dan L
    SD Guest
    Please tell me you're joking.
    | ___ Salad Dodger
    |_\_____/_| ..88045../..23727.../..31893.
    SD, Mar 18, 2007
  6. Dan L
    Dan L Guest
    SD coughed up:
    Heh, the rear shocks should be a piece od piss, it's the fork springs
    which concern me cost they involve oil and 'ting.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  7. Dan L
    Dan L Guest
    Heh, she's been making Caribbean rum cake today.
    By Christ it's fucking potent.
    "have another slice dear, after all, it is mother's day"
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  8. Dan L
    Dan L Guest
    Dan L coughed up:
    +f, -t
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  9. Dan L
    SD Guest
    Okay, I'll let you off, then.
    | ___ Salad Dodger
    SD, Mar 18, 2007
  10. Dan L
    Dan L Guest
    SD coughed up:
    Thanks.
    Any tips (fancy wielding a spanner maybe mista?)
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 18, 2007
  11. Dan L
    SD Guest
    Do the shocks one at a time.
    Get all the weight off the front forks before undoing the top nuts.
    I've got enough on my plate as it is, at the moment.
    | ___ Salad Dodger
    SD, Mar 18, 2007
  12. Dan L
    Big white chief, him speak wisdom.
    Pip Luscher, Mar 18, 2007
  13. Dan L
    Moon Badger Guest
    IME, good. I haven't used the Nitro range, but have been a satisfied
    customer of theirs for years. I have used their fork springs and both the
    classic twin shocks and the mono unit ( not at the same time ) on a range
    of bikes and have never had cause for complaint.
    If you have the front end apart, another worthwhile upgrade is the RaceTech
    Cartridge Emulators. They take a bit of setting up, but combined with Hagon
    suspension at both ends makes a marked improvement to the handling.
    Moon Badger, Mar 18, 2007
  14. Dan L
    You have manual(s), right? Check in the book(s) what fork oil you
    need and vitally, how much and how the quantity is calculated: actual
    amount dribbled in, how far from the top, that sort of thing. I've
    taken a few jobs like this on, then found there to be /no/ info on oil
    available, which makes the whole thing a bit of a lottery. Forearmed
    is bloody handy when doing a job needing four arms.
    I think Hagon springs at both ends and new oil in the front will
    transform your bike from the lardy, tired old barge it currently is
    into ... well, just a lardy old barge, mate. New lease of life.
    Pip, Mar 19, 2007
  15. Dan L
    Dan L Guest
    Pip coughed up:
    Hagon actually supply a cannister of oil with their progressive
    springs, which is handy.
    Heh, my take exactly. It's handling has become somewhat erratic over
    the last year, and I have already regassed one of the rear shocks
    (although they're not designed to be regassed). Anyway, Hagon Nitro's
    are very shiny, reason enough to buy 'em.
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 19, 2007
  16. Dan L
    Hagon are overpriced IMO. I was looking at their Nitro range to
    replace the ageing OE shocks on my Guzzi [1] but think that a set of
    bespoke Maxton shocks are not a great deal more and offer better VFM.
    Fork springs are pretty easy and with luck and careful examination of
    the exploded diagram should be replaceable without too much
    difficulty. If you want to come down south I can do it.
    [1] I'm so hard I ride that Guzzi 'like what I do' on 30 year old
    shocks.
    Only because I broke the last set of 20 y/o Konis:
    http://sweller.dynalias.org/images/koni2pieces.jpg
    Hooray for me.
    sweller, Mar 19, 2007
  17. Dan L
    Dan L Guest
    sweller coughed up:
    Hmm, I had brief correspondance with Maxton last year, can't remember
    what their price was so will check it out.
    Heh, I have the workshop manual, however a blat down South might be
    enjoyable, will keep you posted, and thanks for the offer.
    Faark!!
    Dan L
    X-FOT#000
    DIAABTCOD #26
    BOMB#18 (slow)
    OMF#11
    Dan L, Mar 19, 2007
  18. Fixing Dan's bike.
    **** off you, I'm assistant spanner monkey on this one, stop nicking
    my learning opportunities.
    Get your own shocks and forks to play with.
    http://www.peselectro.com/
    Work in progress, Mar 19, 2007
  19. I've had similar happen to Marzocchis (sp) and a set of OE ones rotted
    right through under the pretty rubber boot that covered the top mount.
    Grimly Curmudgeon, Mar 20, 2007
