Had a go on my Daytona...
Discussion in 'UK Motorcycles' started by Christofire, Dec 18, 2004.
  1. Christofire
    Hmm. I went for the other choice. You just have to ride like there is
    ice on the road all the time, and avoid all heroics if possible.
    Muck, Dec 18, 2004
    #41
  2. Gertrude's got crash bungs - under her footplates.
    Christopher Des Clayes, Dec 18, 2004
    #42
  3. Christofire
    Stritchy Guest
    I've only got a bike because I can't afford a car as well.
    Was sorely tempted with Bear's Jag :eek:(
    Stritchy, Dec 18, 2004
    #43
  4. Christofire
    If I do get a car, it'll be a Land Rover, another old military one I think.
    Muck, Dec 18, 2004
    #44
  5. Christofire
    Ben Blaney Guest
    Oh dear.
    Ben Blaney, Dec 19, 2004
    #45
  6. Christofire
    If they're same as the type used to hold in steering locks then whack the
    head with a chisel to make a screwdriver slot (it needn't be too deep)
    and using a screwdriver they should come out nice and easily.
    Although why the mirrors have snap off bolts defeats me.
    sweller, Dec 19, 2004
    #46
  7. Christofire
    Ben Guest
    Have you seen the price of sports-bike mirrors? Like 80 odd quid a
    pair for OE ones.
    Plus there is additional bending damage to the fairing and sub-frame
    if they stayed in place.
    Best thing I always thought were Suzuki's indicators on flexible
    stalks. They don't appear to have them on the newer bikes.
    Ben, Dec 19, 2004
    #47
  8. Christofire
    Salad Dodger Guest
    Blimey, that's a bit cheap, innit?
    | ___ Salad Dodger
    |_\_____/_| ..73063../..17250.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Dec 19, 2004
    #48
  9. Christofire
    MattG says...
    No problem, it's surprisingly easy to line the holes up with the
    mountings.
    Lozzo, Dec 19, 2004
    #49
  10. Christofire
    Stritchy says...
    Chris has the choice, he owns a little Renault 5 as well.
    Lozzo, Dec 19, 2004
    #50
  11. Christofire
    Christofire Guest
    Christofire, Dec 19, 2004
    #51
  12. Christofire
    Christofire Guest
    <noted>
    I'll probably send it anyway as it'll come in handy. Cheers Andy.
    #52
  13. Christofire
    Christofire Guest
    I'd love the mirror. <emailed>
    #53
  14. Christofire
    Heh, I've never been one for heroics, but I may give it a little try on
    the FZR. I know that handles well, so any slow riding is down to me.
    Muck, Dec 19, 2004
    #54
  15. Christofire
    It's fortunate that you didn't crack any engine side covers. Doesn't
    look too bad though.
    Muck, Dec 19, 2004
    #55
  16. It was somewhere around Barstow, on the edge of the desert, when the
    Blimey. Narcissism is alive and well in ukrm.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 19, 2004
    #56
  17. It was somewhere around Barstow, on the edge of the desert, when the
    Looks as if the sticky-out bits are made of toffee. Whether to avoid
    serious injury to rider/pillion/ped or simply to guarantee replacement
    orders for Triumph is unknown.
    I recall lobbing older bikes down the road - bits didn't bend all that
    easily and when they did they were easily straightened for the most
    part. It looks as if most low-speed offs these days would leave the
    rider stranded with an unrideable bike.
    GS 850 x2 / SE 6a
    #57
  18. Christofire
    Christofire Guest
    After reading much of the advice in this thread it did give me
    something to chew over. I was getting close to thinking "well, it
    needs new bits, lets get on with it", but I'll have another think about
    what I need, what it's going to cost, and there's a few things have
    turned up that I need to check tomorrow.
    With all this in mind, today I set about dismantling and tackling some
    of the obvious and easy jobs. Left dip headlight was out, and apart
    from being a bit nadgery it should be easy enough.
    The front fairing was coming off anyway, so that wasn't too much of a
    drag. A few troublesome fastners, but nothing a bit of gentle
    persuasion couldn't overcome. On removing that I was confronted with
    the headlight unit and a mass of stiff, well taped wiring loom. A
    quick check in the book says "remove these three nuts to remove the
    headlight unit". Ho ho ho. To get access to two of said nuts you've
    got to remove a fairing bracket or nothing will get near it. There's
    not enough room for a spanner, and with the fairing bracket in place
    you can't get to it with a box spanner or a small socket. The bracket
    is fixed with torx screws.
    Well ha-ha Mr. Triumph, I've already got some torx bits for my
    multi-tool-esque screwdriver. With those dispatched I set about the
    nuts, and of course one is seized. At this point my mind harks back to
    one of Pip's tales of headlight changing and doing it in-situ. I
    wonder if I could do the same (but without ending up with a headlight
    unit full of bulbs and assorted instruments used to try to remove said
    bulbs).
    I resolve to remove the whole bolt stem and that works. So, the final
    nut is underneath and has about 15 degrees of movement on a spanner.
    Again, victory is mine - I got the ratchet spanner set from halfords
    ages ago (currently on offer - 40ukp at my local one) and after a while
    the nut is loose. Some more persuasion sees the headlight unit in my
    hands. Check the bulb and the filament looks as knackered as the one I
    took out of the SOC the other day, so off to halfords for a new one.
    A while and some horrific christmas shopping traffic later, new bulb
    in, I connect it up and try the lights. It doesn't work. Bugger -
    I've got a duff bulb, I'll have to fight back through the traffic.
    Hang on - I'll just test it in the RHS one to see if it is the bulb.
    Bulb works. Hmm. Test the old bulb, it works. Arse. A cuppa and a
    wiring diagram later, and it's either the wiring or the dipped bulb
    relay. As the other light works it must be the wiring. Well, I can't
    see how I'm going to sort that, so I check the relay.
    Which is lying just out of it's socket in the rear seat unit...
    #58
  19. Christofire
    _Ginge Guest
    Tough break mate.
    What I'd consider doing in your position is losing the plastic and
    converting it into a Speed(ier) Triple.
    But then, I quite like unfaired bikes.
    _Ginge, Dec 19, 2004
    #59
  20. Christofire
    "Christofire" <> struggled to ejaculate:
    ****, that hurts, doesn't it?
    Nemmind, you have a spare bulb now.
    Pip, Dec 19, 2004
    #60
