H-D sportster 883 -98
Discussion in 'Motorbike Technical Discussion' started by Lennart, Aug 8, 2006.
  1. Lennart
    Lennart Guest
    Hi, Problem with the gearbox on my sportster, when the engine gets warm
    i'ts difficult to shift to the next lower gear.
    I can't go further down with the gearshifter I have to release the clutch a
    little bit and then it sounds awful as the cogs grasps into each
    other.Sometimes I have a neutral between 5 and the 4 gear and 4 and 3 gear
    but no light indication on the panel. Someone who has any idea whats
    wrong? Is this a common problem ? I have exchange the oil, but the problem
    still exists.
    Regards Lennart
  2. What brand and weight of oil are you using?
    Ted
    Ted Mittelstaedt, Aug 9, 2006
  3. Lennart
    Lennart Guest
    H-D "special formula sporttrans" used on all 71 and later xl and xr models.
    Lennart
    Lennart, Aug 9, 2006
  4. Try draining and refilling with plain old 10W-40 from the auto shop. Make
    sure it does not say "energy conserving" on the bottle. A lot of wet clutch
    problems like this that people have reported on various bikes have been
    solved by switching to a different oil.
    Ted
    Ted Mittelstaedt, Aug 11, 2006
  5. Lennart
    Lennart Guest
    Ok, thanks for the tip I'll try that !
    Lennart, Aug 12, 2006
