Gynaecology
Discussion in 'UK Motorcycles' started by Tosspot, Jan 18, 2007.
  1. Tosspot
    Tosspot Guest
    Thats what I've been practising trying to change a snapped throttle
    cable on the Trophy. The alternative is fairing off, tank off, airbox
    off, carbs off. Just to change a fucking cable. Shop quoted roughy 25
    squids for cable, 50 squids pickup, and an hour or so labour, giving
    125-150.
    Bollicks to that, I thought, picked up the cable and started spannering.
    What a fucking malarky to secure the cable outer to the carb body.
    What the **** was wrong with a threaded body and a lock nut eh? Go on,
    tell me! Fucking Triumph engineers.
    Oh well, done now, and if I ever the chance, a second career.
  2. Tosspot
    Nice precis of my Harley experiences.
    Indeed. Spannering and writing about ir.
    Pip, Jan 18, 2007
  3. Tosspot
    Pete Fisher Guest
    I thought you might have had trouble with the twistgrip end. The carb
    end is pips on the Nordie (no not you, the lad's favourite expression
    for easy) simple threaded bits with lock nuts. Bit of a fiddle getting
    the nipples in to the quadrant but pretty simple. The arrangement at the
    twistgrip is another matter entirely. Really awkward keeping everything
    in place as you put it back together. The book of lies is no help as it
    only has an illustration for the Saturno which has a single conventional
    pull up throttle slide carb.
    | Pete Fisher at Home: |
    Pete Fisher, Jan 18, 2007
  4. Tosspot
    I'm not going into any detail about this. You'll have to wait until
    it comes out proper-like; but 'trouble' doesn't even enter into it ;-)
    Pip, Jan 18, 2007
  5. Tosspot
    Tosspot Guest
    <waits with baited breath>
  6. Tosspot
    Moon Badger Guest
    Took the engines out of my X7s today. Put the running engine in the MOTted
    chassis and stripped the top end of the seized engine. Phew, no bits of
    piston made it to the crank :)
    Total time to remove two engines, refit one and remove head/barrels and
    pistons on another?, 3 hours. Half an hour of that was donking about
    synchronising the carbs and oil pump.
    Next, strip, clean and rebuild the carbs from the seized engine. Yup,
    clogged main jet in the side of the holey piston. Bit of what looked like
    snot. Probably stale petrol goo just before it turned into varnish.
    Time taken?, an hour and a bit.
    Sometimes, just sometimes I really like farting about with old bikes. Old
    strokers hide few horrors that require automotive gynaecology.
    Moon Badger, Jan 18, 2007
  7. You been eating cheese again?
    Dr Ivan D. Reid, Jan 18, 2007
  8. Tosspot
    I can tell when somebody's taking the piss, you know.
    And it's 'bated', btw.
    Pip, Jan 18, 2007
  9. Tosspot
    peter Guest
    Indeed in the days of air-cooled MX engines it was fairly common to see
    at least a top-end strip and rebuild between practice runs at twop day
    hill climb meetings. Not unknown even with the modern liquid cooled
    jobs. The advent of the new breed of liquid-cooled four stroke singles
    : KTK, Husqvarna and Husaberg mainly has generally made that a thing of
    the past. Either they never blow up or they do so in spectacular
    terminal fashion.
    I used to carry a spare cylinder, piston and ignition charging coil for
    the Rotarini when I was road racing that.
    Primitve, but effective it was. You could even swap the disc valve for
    something more or less hairy quite quickly.
    peter, Jan 18, 2007
  10. Tosspot
    Not a smoker, but I read a lovely story about two lads who campaigned
    a bike-engined lightweight car ("cyclecar") up Shelsley between the
    wars. For ultimate bhp they would start the thing, warm it up in the
    paddock and then just before they had to go for the start, drain the
    oil out. Less drag, see.
    Having it running for less than two minutes, even on full chat up the
    hill appeared to do no appreciable damage to the JAP motor. A push
    from the top, back down the hill and dead stick back to the paddock,
    then they'd take the top end off. If they'd got the gearing /just
    right/, there would be a little light piston crown polishing to be
    done, to remove the marks where the valves had just kissed them.
    Them were the days, eh?
    Pip, Jan 19, 2007
  11. Tosspot
    Pete Fisher Guest
    The exhaust valve of my Husky kissed the piston going down the first
    straight at Gurston the year I acquired it. Problem was it was of the
    French kiss variety. The valve probed way too amorously and literally
    lost its head.
    Still are in some ways. I really love the speed hill climb atmosphere.
    Mechanical improvisation to the point of lunacy and machine control
    approaching genius from the riding gods. Mostly performed on not much
    more than a shoestring budget so far as the bikes are concerned at
    least.
    Pete Fisher, Jan 19, 2007
Similar Threads
Loading...
