Guzzi brakes update
Discussion in 'Classic Motorbikes' started by entwisi, Jul 25, 2006.
  1. entwisi
    entwisi Guest
    Eventually had time to play last night, turns out the fluid in the whole
    system was so dirty it was untrue. The sediment was actually blocking the
    feed from the res to the cylinder itself so as you pumped it no fluid was
    being drawn in to replace it. I ended up stripping the master cylinder
    down completely to clean it out. now it is pumping fresh fluid I've
    started bleeding it. It bled fine to the nipple on the flow valve. The
    rear brake did seem to be taking ages to get fluid but what I did notice
    was that if I pumped the pedal a few times then released it I got a nice
    steady stream of bubbles in the res. If I pumped it about 10 times I even
    got a nice little fountain of fluid breaking through the surface of the
    fluid in the res.
    Anyway, hopefully tonight I'll get it finished.
  2. entwisi
    entwisi Guest
    All finished including the front r/h caliper changed new fluid.
    Brakes now a cart load better than they were, I can easily lock up the
    front wheel now.
    next jobs, change engine oil and rear bevel drive oil.
    entwisi, Jul 30, 2006
  3. entwisi
    I managed to lock up my Quota's front wheel once. Addenbrookes
    Hospital had X-rays to prove it.
    Oil filter?
    Unless sumping's stopping you, of course...
    Pip Luscher, Jul 30, 2006
  4. entwisi
    entwisi Guest
    Oil filter is part of doing the oil itself in my eyes.
    entwisi, Jul 31, 2006
  5. entwisi
    Ah. A Quota's filter change is only required every third service.
    Pip Luscher, Aug 2, 2006
  6. entwisi
    entwisi Guest
    Right!
    Problem is I don't know when it was last done so I'll do it anyway.
    Any reason why I shouldn't use Castrol Magnatec oil? (bought 2x 4.5L's for
    £15 off a bloke whos dad does something in the industry)
    entwisi, Aug 3, 2006
  7. No reason at all, knock yourself out.
    Grimly Curmudgeon, Aug 3, 2006
  8. entwisi
    Yeah just has all that addative shit to block up small oilways....or is
    that Urban Miff
    Hog, Aug 4, 2006
  9. entwisi
    So long as it's 40w monograde goat fat.
    platypus, Aug 4, 2006
  10. IRTA monotreme.
    Austin Shackles, Aug 5, 2006
  11. entwisi
    Grease me up, big boy. And I'm a bit heavier than 40w...
    platypus, Aug 5, 2006
