GT380 engine won't start
Discussion in 'Motorbike Technical Discussion' started by tokenhire, Jul 5, 2007.
  1. tokenhire
    tokenhire Guest
    I have a 75 Suzuki GT380 that one fine morning would not start off the
    kick or when I tried to run-start it. Instead when I popped the
    clutch, the engine just hummed to a slow stop and never caught.
    The points were replaced with a Boyer Bransen electronic ignition. I
    took the cap off and could spin the ingition disc which did create a
    nice pop out of the exhaust pipe. I'm told that I shouldn't be able
    to spin the disc by hand but there is very little resistance.
    Is there a pin or gear on that shaft to which the electronic ignition
    is attached that has let go?
    Anyone have any idea as to how challenging it is to remedy the
    problem? Can I do it myself (I'm the village idiot)? Do I need a
    profressional? Is there no hope and I should just find a new motor?
    Any thoughts would be greatly appreciated..!
  2. tokenhire
    tokenhire Guest
    I appreciate the pointers!
    There is a codder pin on the shaft that holds the ingnition system in
    place. That is intact. It's what allows me to turn the ignition and
    generate the pop. I presume it's something inside the motor along
    that shaft that has broken off or detached.
    An no, I am not an Arab. I do tan well for an Irishman though....
