gsxr 750 head swop
Discussion in 'UK Motorcycles' started by paz, Feb 22, 2004.
  1. paz
    paz Guest
    has any one fitted or knows if a head from a 750m will fit a 750l, any
    associated problems, valve clearances etc etc ?
    paz, Feb 22, 2004
  2. paz
    Petel Guest
    If the valves are the same length and you use the original camshaft,check
    the shims,I`d have thought not.
    Measure the valve-head dia. if the latter is bigger you might have a problem
    with them hitting the piston crown if it has insufficient cutaway.
    *note* I have never done this particular swap so don`t blame me if it goes
    tits-up;-)
    Just some things to look out for.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    http://homepage.ntlworld.com/peteh1/website/index.html
    Petel, Feb 22, 2004
  3. paz
    Previously on usenet, Petel said...
    I am pretty sure the L and M motor is the same unit. I had an L model
    many years ago, and the M was only slightly different in bodywork.
    Lozzo, Feb 22, 2004
  4. The 1100M head had shims instead of screw&locknut tappets.
    I don't know if the 750 changed at the same time.
    The 750M probably had bigger carbs than the L too.
    Old Fart at Play, Feb 22, 2004
  5. paz
    DangerScouse Guest
    Petel says...
    The 750L is tappets, the 750M is buckets and shims.
    Lesley
    ZXR400SP
    SBS#11[with oak-leaf cluster]
    BOTAFOT#101A UKRMHRC#12
    BONY#54P BOB#18
    Un-cork me to reply
    DangerScouse, Feb 22, 2004
  6. paz
    DangerScouse Guest
    Lozzo says...
    The M model was when they changed from tappets to shims, so it is
    different.
    Lesley
    ZXR400SP
    BONY#54P BOB#18
    Un-cork me to reply
  7. paz
    Petel Guest
    Sig.sep. left in.
    Ta for clearing this up..it`s a grey area now made black and white.
    Petel .
    02 M2 Buell.
    C90-ZZR.
    Petel, Feb 22, 2004
  8. There is a website with most of the known swaps - but I'm buggered if I
    can find it. Somebody here posted it last year; it might pop up again.
    GS 850 x2 / SE 6a
    FUB KotL OSOS#12? UKRMMA#19
    Grimly Curmudgeon, Feb 22, 2004
  9. paz
    Muck, Feb 22, 2004
  10. Grimly Curmudgeon, Feb 22, 2004
  11. paz
    paz Guest
    thanks for your comments all, i know the bore & stroke are the
    same,carbs are the same, not sure if the valves will take out the
    pistons though ?
    paz, Feb 23, 2004
  12. Maybe your news server dropped the message with the site address in
    it...
    http://hometown.aol.com/ffastcbr/motorswaping.htm
    It seems fairly comprehensive.
    If the cam lift is the same, you probably won't hit anything. Dry bolt
    the head on (with and old head gasket) with a bit of plasticine on the
    crown of a piston and rotate a cam to open a valve. Bring the piston up
    to tdc and see how much clearance you have by the mark in the
    plasticine.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Feb 23, 2004
