GSX-R 600 starting procedure
Discussion in 'Motorbike Technical Discussion' started by Don Fearn, Apr 16, 2006.
  1. Don Fearn
    Don Fearn Guest
    My son just got a '97 GSX-R 600 but it came without an owner's manual,
    so we don't know how to get it fuel for starting.
    My son says the guy who sold it to him said the gas in the tank was
    bad, so he had it running for a short while by spraying starter fluid
    into the intakes. We drained the old fuel and put fresh fuel in the
    tank and reconnected the fuel line and the vacuum line to the correct
    places, but it's still not getting fuel. Since this has a
    vacuum-actuated fuel shutoff, I expected there to be a petcock with
    pri-on-res so we could prime the carburetors before trying to start
    it, but there isn't any such thing.
    What do we need to do to get the carbies primed?
    Thanx,
    -Don
  2. Don Fearn
    FB Guest
    You can disconnect the fuel hose from the petcock and squirt gasoline
    down into the float bowls from a plastic squeeze bottle. If you want to
    quickly clean out the idle jets, which are probably plugged, you can
    mix the gasoline about 4 to 1 with Berryman's B-12 Chemtool Choke and
    Carburetor Cleaner.
    You can buy B-12 in aerosol form or in liquid form. It's less than
    $3.00 for a 15-ounce can of
    B-12 at Walmart.
    You should get into the habit of running 3 or 4 ounces of B-12 through
    a full tank of gasoline a few times a year to keep the carbs cleaned
    out. It's a blend of xylene, acetone, and methyl alcohol and it
    dissolves hydrocarbon gum and varnish quickly without harming rubber or
    plastic parts inside the carbs.
    One thing that you need to know about constant vacuum carbs: they do
    not have a real choke.
    There is NO choke plate. There is a bypass passage that sucks gasoline
    right out of the float bowls when you move the "choke" lever to the ON
    position.
    (If you have the rubber boots between the air box and the carbs removed
    in order to spray ether in the carbs, you can hand choke the carbs.
    But, who wants to do that all the time?)
    Since your engine generates very little vacuum when your're cranking
    with the starter, trying to "help" the engine by opening the throttle
    works against you. You get even less vacuum.
    The starting enrichener cannot suck gas out of the float bowl.
    So, the best bet is to leave the throttle handle alone. Just push the
    button, and if the idle jets are clean and the idle RPM is set
    correctly, the engine should start and fast idle without touching the
    throttle twist grip.
    FB, Apr 16, 2006
  3. Don Fearn
    Don Fearn Guest
    You were spot on, Mark. What fooled me was that the bike wouldn't run
    at all. In my (previous) experience, carbs that needed cleaning ran
    poorly, but would at least start.
    That wasn't an option in this case; the fuel system was so full of goo
    that fuel wouldn't even flow to the bowls when I put up an IV bag of
    gasoline for it to draw from.
    The carbs are now off, disassembled, de-gooed, and awaiting
    reassembly.
    Thanx for some good advice. (We probably would have figured that out
    anyway, but it's always good to have another opinion or two . . . .)
    -Don
    Don Fearn, Apr 17, 2006
