GS500E Vibes
Discussion in 'Australian Motorcycles' started by Black Bart, Jan 30, 2004.
  1. Black Bart
    Black Bart Guest
    Just took a Suzuki GS500E for a test spin and found it to be
    extremely vibey. A twin will have some vibes by nature of the
    motor type, but this just seemed really excessive and it was
    bad at all speeds.
    Having not ridden another example to compare, I was wondering
    if this is normal.
  2. Black Bart
    Black Bart Guest
    P.S. I suspect a possible counterbalancer issue.
  3. Black Bart
    Stuart Thyer Guest
    Could also be a tuning issue, carbs out of balance 'could' produce a similar
    feeling. Having said that, I've never ridden a GS500. Try test riding
    another one!
    Stuart T
    Stuart Thyer, Jan 30, 2004
  4. Black Bart
    Dave Mojo67 Guest
    Maybe you could try countersteering to counter the counterbalancing.
    :p
    Dave Mojo67, Jan 30, 2004
  5. Black Bart
    conehead Guest
    I rode one a few years ago and thought it was quite smooth. I _had_ just
    ridden there on a 660-single though.
    conehead, Jan 30, 2004
  6. Black Bart
    tgare Guest
    I had a GS450 for a few years and towards the end when the motor hit 65 000
    km it started tio rattle more but overall a good reliable strong motor and
    never vibrated unless pushed hard so be picky what you get.
    Tim
    GSXR6 03
    tgare, Jan 30, 2004
  7. Hi Guys,
    There will always differences between any two bikes due to production
    tolerances, but the tune of the engine will have a large factor.
    I presume that the GS has two carbies, and they might need balancing.
    Sometimes too much pre load makes the vibes seem worse, as the frame
    dissipates the vibe energy into the fork springs, and is damped by the fork
    oil.
    Unless the bike is brand new and therefore stock standard, there may be
    extra preload washers etc. placed under the fork cap by a previous owner,
    assuming the GS does not have adjustable forks, to increase preload, but it
    would need to be really screwed down to be that bad.
    Rob
    Getting Slower & Slower !, Jan 30, 2004
  8. Black Bart
    Black Bart Guest
    Everything I've read about then says they're meant to be fairly smooth.
    The bloke has recently put new rings and camchain in so
    the balancer may not have been put in properly. It's also
    been "retired" for the last two years so the carbs may just
    need balancing.
  9. Perhaps the air filter was dirty.
    Postman Pat
    Pat Heslewood, Jan 30, 2004
  10. Black Bart
    GB Guest
    Nah mate, shafties can't mono.
    G
    GB, Jan 30, 2004
