GS 1200 engine noise
Discussion in 'UK Motorcycles' started by Nige, Apr 21, 2007.
  1. Nige
    Eiron Guest
    Irving Berlin!
    How do you expect us to get such an obscure reference?
    1984?
    Eiron, Apr 22, 2007
  2. Nige
    Nige Guest
    It's not obscure, it's very well known. It's from Lock, Stock & Two
    Smoking Barrels.
    1984 indeed!
    'Chill Winston.......'
    Nige
    Subaru WRX (54)
    Land Rover Discovery II (2001)
    BMW GS1200 (2007)
    Honda CBR900RR Fireblade (1997)
    Nige, Apr 22, 2007
  3. Nige
    Eiron Guest
    Can I claim a whoosh there? Or doesn't it count if Nige completely
    misses the point?
    Anyway, Two Smoking Barrels is pretty obscure to someone who only
    watches weepies and romantic comedies. :)
    Eiron, Apr 22, 2007
  4. Nige
    Nige Guest
    You don't have to claim it, I'll give it to you.
    Nige
    Subaru WRX (54)
    BMW GS1200 (2007)
    Nige, Apr 22, 2007
  5. Nige
    Nige Guest
    You slip your car clutch all the time, but i did think about it.
    Nige
    Subaru WRX (54)
    BMW GS1200 (2007)
    Nige, Apr 22, 2007
  6. Nige
    Nige Guest
    Been out on it again today & It's fine, I must have got used to the
    smooth engine of the blade.
    Rides 100%.
    As you were.
    Nige
    Subaru WRX (54)
    BMW GS1200 (2007)
    Nige, Apr 22, 2007
  7. And worth even less. You don't understand how wet and dry clutches work,
    do you?
    The Older Gentleman, Apr 22, 2007
  8. Nige
    Nige Guest
    I fully understand the dry clutch myself, but if you don't mind, could
    you explain the differences?
    Nige
    Subaru WRX (54)
    BMW GS1200 (2007)
    Nige, Apr 22, 2007
  9. Nige
    How about a Quota?
    <runs away *very fast*>
    Pip Luscher, Apr 22, 2007
  10. Wet clutches are multi-plate, whereas most dry clutches (Ducati is an
    obvious exception) are single plate.
    Problem with a single-plate car-type dry clutch is that it tends to be
    found in shaft drive bikes with longitudinal cranks (Guzzi, BMW) and,
    like a car, is between engine and gearbox. This means the engine/gearbox
    unit has to be separated to replace it.
    Wet multi-plate clutches use lots of friction plates and pressure
    plates. Oil helps keep them cool. Downside is that if they get abused,
    they will contaminate the oil. With modern oil filtration, this isn't a
    problem. They're also very easy and cheap to replace.
    Contrary to what leo is saying, both wet and dry clutches need to be
    slipped because that's how all clutches *work* and both will suffer (or
    not) to the same extent.
    Dry multi-plate clutches are built up like wet multi-plates are a little
    bit lighter and, crucially, they don't suffer from any oil drag so they
    transmit a tiny bit more power, which is why they're frequently used in
    racing bikes. Downsides are a build-up of dust (worn plate, which would
    otherwise be carried away by the oil) and (in Ducatis, anyway) a hell of
    a lot of noise as the plates jangle merrily away with no oil to dampen
    the din.
    They're, if anything, even easier to replace than wet multi-plates.
  11. Nige
    Nige Guest
    Yep, I get this bit
    I have seen one in bits & wondered why there where so many plates.
    I did the first couple of years of my 381 C&G. It's car biased & did
    know that to engage & disengage drive smoothly you need a 'clutch' it
    would be a bit odd without one.
    Cheers for that, much appreciated.
    I get it now.
    Nige
    Subaru WRX (54)
    BMW GS1200 (2007)
    Nige, Apr 22, 2007
  12. Nige
    Beav Guest
    Not nearly as many as "Mike the Bike" (a bloke I know)
    In the last 2 years he's bought an SV 1000, a 650 Honda thumper "supermoto
    type thing" (Dominator?) a 'Blade, a Kwak W650, a Kwak VN 800, 2 Bandit
    12's, a CBR 600RR, A CBF 1000 and a BMW 1150GS.
    All brand new apart from the Dominator and all sold apart from the Beemer.
    Beav
    VN 750
    Zed 1000
    OMF# 19
    Beav, Apr 22, 2007
  13. Nige
    deadmail Guest
    Only the once? I've lost count of the number of clutches I've replaced
    but then again I have tended to run stuff that's seen a few years, miles
    and owners and I tend to do all of my own work where I've the time.
    I've never really thought too much about why multiplate tbh, but would
    assume it was to offer a bigger surface area over which to spread the
    load.
    deadmail, Apr 22, 2007
  14. Ding. The torque transmitting area of a multiplate clutch is surprising.
    Grimly Curmudgeon, Apr 22, 2007
  15. Indeed. I should have mentioned that.
    The Older Gentleman, Apr 23, 2007
  16. This was the faulty GS I reported a few weeks ago, so he's already aware
    of it. Probably still give him a stiffy though.
    mike. buckley, Apr 23, 2007
  17. Well, the latter, really. Obviously there are times when you have to
    slip the clutch, but it's far better to rely on corect engine revs and
    gear choice to avoid having to do so.
    Your instructor is talking out of his (or her) arse.
    Not really. See above.
    The Older Gentleman, Apr 24, 2007
  18. Trickling along at walking speed - most first gears I've found are just
    a bit too tall to allow it without the engine snatching and banging a
    bit and being on the verge of stalling. Some slight clutch slippage
    there is sometimes necessary.
    Best just to burn a darkie, scream to the head of the queue and shout,
    "See ya at the crematorium, folks!".
    Grimly Curmudgeon, Apr 25, 2007
  19. Nige
    Right, you mean in heavy traffic? Yes, I suppose so, on some bikes,
    although I'd tend to think of that as just repetitions of 'moving
    off', IYSWIM.
    Indeed.
    _______
    Ace, Apr 25, 2007
  20. Yebbut even in heavy traffic only a gurl would filter that slow.
    steve auvache, Apr 25, 2007
