Grr. Lozzo, get your book out.
Discussion in 'UK Motorcycles' started by deadmail, Mar 10, 2007.
  1. deadmail
    deadmail Guest
    So... I go to leave work on Thursday evening at about 10. I'm tired and
    need to be at Heathrow by 8.20 the following morning.
    Get in my car, turn on the ignition and the 'information display' tells
    me "Check LowBeam". No need to tell me that, there's no fucking lights.
    Look at a bulb (but it's dark) and it isn't obviously blown. Look in
    the boot and I don't have any H1 bulbs. Bollocks.
    Well, **** everyone I'll drive home on main beam.
    Look at it this morning and it seems that *both* headlight bulbs had
    blown. Wow.
    Look in the garage and I've only got 100W H1 bulbs. Heh. That'll do.
    Put them in the car, switch on, no warning- good. Switch on the lights
    and they don't illuminate. Put a meter across one and there's no
    voltage. Check fuses. Fine.
    Disconnect one bulb and the other lights. Reconnect and switch on, no
    it won't light. Disconnect other bulb and connected one lights.
    Search harder and find one 55W bulb. Put this in the offside and it
    works.
    WTF? The car's got some square-headed current sensing circuit that's
    fucking with my right to blind other motorists. Fucking cunts designing
    it. Whilst I'm ranting why the **** would they put the date on the
    'computer' in mm/dd/yy format? We're fucking European not American.
  2. deadmail
    deadmail Guest
    I'm almost tempted to use relays to bypass it... but... if I do this I'm
    pretty sure that the difference in impedance between the bulb and the
    relay coil would set-off the "check low beam" message.
    Maybe I just ought to get a set of HID low beams for it.
    I'd rewire the accessory socket...
  3. deadmail
    JB Guest
    Google for 'LKM' (LichtKontrolModul). Dead easy repair. Emial me iof you
    need it repaired.
    JB
    JB, Mar 10, 2007
  4. deadmail
    deadmail Guest
    Thanks, but everything's working now.. just not how I'd like.
    I'm rather pissed I can't have a 100W dip because of the car's control
    system deciding that 8A is too much current.
    Unless I misunderstand and I can somehow reset the upper limit?
  5. deadmail
    JB Guest
    You don't need 100W lamps if you use Osram Silverstar or Philips Vision Plus
    lamps. These are the correct wattage but produce _at least_ 40% more lumens,
    often as much as the advertised 50%. The 100W will overheat and kill the
    optics anyway, even if the LKM didn't melt down first (which it most
    certainly will). I've repaired about 30 of those bloody things. Quite a
    lucrative sideline too :>)
    No, you can't.
    JB
    JB, Mar 10, 2007
  6. deadmail
    deadmail Guest
    E34 seemed quite happy with it but I've given up on the idea with the
    e38.
    Regarding 'killing the optics'; what do you mean?
  7. deadmail
    JB Guest
    With the E38, just get a retrofit package from ebay using the D1 or D2-based
    xenon metal halides. Worth every penny.
    On the 'projector' low beams on E32(some)/E36(some)/E38, the aspheric lenses
    are mounted in a moulded polymer frame. The extra infrared energy from the
    100W lamps can melt and distort this frame and totally alter the optical
    performance of the unit. Also with some of these untis, (not the early Bosch
    ones but mainly the later ones produced by another German manufacturer ZVG),
    the ellipsoidal reflectors themselves are aluminised polymer too. These are
    destroyed in very short order when 100W lamps are fitted.
    JB
    JB, Mar 10, 2007
  8. deadmail
    Doki Guest
    Bit of a thread hijack - do you know of any problems running 100W bulbs in
    conventional hella lamps with metal reflectors (MK2 Golf)?
    Doki, Mar 11, 2007
