Ground anchors. Make or Buy?
Discussion in 'UK Motorcycles' started by steve auvache, Aug 23, 2005.
  1. Ok, so I are thinking of pre-empting the thieving cunts and putting in a
    ground anchor of some description.
    Now I have got a fair bit of space to pay with and can have something of
    real FOAD dimensions to act as a deterrent and thought that something of
    the ride-in variety along the lines of the ones you use to park push
    bikes in might do the job nicely.
    Are such things available retail or do I have to offer beer tokens to
    someone with a scaffold pole and a welding set to make one?
  2. Zan (CBR1000F) - www.zanziba.prodigynet.co.uk/Pictures wrote
    Yes, and? There is **** all I can do to stop them desiring my bike and
    thinking they can make an easy profit from it or charging me for the
    privilege of not pressuring the police to stop others doing the same.
    Thusly I suspect that in future I shall have to do something to slow the
    cunts down if not actually stop them. Ground Anchors are acceptable
    technology in this respect.
    No garage and I don't like disk locks. I don't like locks at all, they
    are a battle lost.
    The rust and the head lock.
  3. steve auvache
    Dan L Guest
    Not quite the same I know, but I have something similar to this:
    http://www.mandp.co.uk/productInfo.aspx?catRef=500835
    Being a "Sold Secure" item could also have a good effect on your insurance.
    I use a "Magnum" chain too, plus the shed [1] is alarmed.
    [1] The wooden outbuilding where the Zephyr lives, not the Zephyr itself.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R (Going)
    Dan L, Aug 23, 2005
  4. steve auvache, Aug 23, 2005
  5. steve auvache
    You can buy similar things with big side-plates to stop the scumbags
    removing the wheel spindle. Dunno where from though.
    Krusty, Aug 23, 2005
  6. In uk.rec.motorcycles, steve auvache amazed us all with this pearl of
    wisdom:
    I read in one of the bike mags a few years ago that an engine block
    makes a good anchor, threading a chain through one of the cylinders.
    Failing that, I'm sure I've seen a big FOAD yellow thing that you
    reverse the bike into and it encloses the back wheel and locks the bike
    solid to the ground. It's the one that's on a funny tilt because of the
    angle of the bike when it's on the side stand but I really can't
    remember who makes it <picks up last month's copy of Bike>... Nope can't
    see it in there either.
    Whinging Courier, Aug 23, 2005
  7. Krusty wrote
    </p>
  8. Whinging Courier wrote
    Yeah right. Nice hot bike, nice cold fingers, I can see that being a
    winner. Though it doesn't have to be a wheel that gets anchored, a bit
    of lateral thinking and there must be lots of places around the frame
    that could be used. Be bike specific though probably.
    </p>
  9. steve auvache
    R obbo Guest
    If you get a lump of channel and some concrete I'll come over and burn a
    hole through it so you can thread a FOAD chain though the thing if you mount
    it in the ground properly.
    I got all the gear on the van all we need to do is organise a day when I am
    over Flatlands to I can do the job.
    Beer tokens etc etc
    R o b b o
    Trophy 1200 1998
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    R obbo, Aug 23, 2005
  10. R obbo wrote
    Not yet as it happens but the front garden is scheduled for
    redevelopment this winter so I can supply the hole and have it filled
    with fresh concrete. Channel??
    Chain through the ground sounds really rather cool. I like that. What
    opinions does the panel have about the sort of dimensions which might
    appeal to Auntie Carole? A couple or three big hoops like they have on
    the docks has a sort of aesthetic appeal. Anybody know of any dockyard
    breakers?
  11. steve auvache
    Macie Guest
    Macie, Aug 23, 2005
  12. In uk.rec.motorcycles, steve auvache amazed us all with this pearl of
    wisdom:
    'Sperfume, innit.
  13. steve auvache, Aug 23, 2005
  14. Whinging Courier wrote
    Actually I have an idea forming and have got this far:
    http://www.kellysearch.com/gb-product-4616.html
    but it needs refining.
    Does anybody what is the name of those figure 8 type chain link mooring
    ring things that ropes get put round?
  15. steve auvache
    Guy Fawkes Guest
    Three points.
    1/ security is relative, there is no such thing as thief proof, the
    tougher you make something the tougher the tools the thief will use,
    right up to a BOC oxy-acetylene portapak or even a JCB, but in reality
    all you need to do is make sure that YOUR shit is a LOT harder to get
    (at) than the neighbours', OK, this can be a bit of an arms race but it
    really isn't that difficult to be the least thief friendly house on a
    street, Plod are really helpful if you take the time to consult them.
    2/ security has to be useable, in reality that means you won't be using
    19 different devices to secure your bike, all of which have to be
    disabled in a certain order and given time limit, you'll be using one,
    and it will be a key operated lock. The absolute WORST place you can
    either buy or get advice on these things is a bike shop, the ONLY place
    is a genuine locksmith, what you need is square section chain (square
    section is bolt cutter proof because of the area presented to the
    blades) as heavy duty as possible, £30 will get you enough, make sure
    you loop it THROUGH THE FRAME ideally under the carbs too and over the
    gearbox, secure it with a PROPER STRAIGHT SHACKLE security padlock with
    less than 1mm gap when closed on the chain, and a roller pin so you
    can't cut it either, again, about £30, anyone in the M5J30 area I can
    introduce you to a bloke who sells this stuff, you want a laugh take in
    your £80 to £120 bought in a bike shop security chain and lock and
    watch him defeat it in ten seconds and almost complete silence...
    3/ ground anchor, bikes are great for thieves, they come complete with
    two low friction wheels and handlebars to steer them while you push
    them around the corner onto the waiting trailer and tarp or tail lift
    panel van, a six foot wrecking bar will defeat 99% of ground anchors in
    seconds and almost silently, the HD chain just gives the wrecking bar
    something to purchase on... in this respect there is NO substitute for
    weight, go to your local scrap yard and buy an old flywheel from a big
    diesel, something weighing around 1/2 a ton if possible, embed THAT in
    your driveway (with its own ground anchors if you like) and all of a
    sudden your prospective bike thief is going to need hydraulic shears
    and a power pack, a gas axe, or a HIAB, there are sure to be lots of
    other bikes around about that are FAR easier to steal.
    HTH etc
    Guy Fawkes, Aug 23, 2005
  16. steve auvache
    Dan L Guest
    "Mooring Bits"
    Dan L (Oldbloke)
    Dan L, Aug 23, 2005
  17. steve auvache
    Guy Fawkes Guest
  18. steve auvache
    Dan L Guest
    Dan L, Aug 23, 2005
  19. Guy Fawkes wrote
    Point taken but.
    Frankly I was surprised more than anything else that they took the
    bandit. Now I have to take counter measures and I want them to fucking
    work.
    On the positive side I don't own the type of bike that the local scrotes
    would want to nick for a ride round the park so that is one subset of
    Thieving Low Life out of the equation.
    As too the rest, rust is obviously no deterrent so there is one excuse
    for maintaining a grubby bike I have lost.
    The big issue I have with it all is who am I defending against? It was
    easy for them but it was easy for who? Was it the sort who travel with
    oxy and foad bolt cutters expressly for the purpose or was it the local
    pikeys and a few beers?
    The pikeys I can defend against. A red flashing led, a ground anchor
    and extra illumination should stop them.
    Hey ho, me tree needs a haircut anyway and as a part of the counter
    measures package it is very cheap.
  20. Dan L wrote
    No, that is a Bollard. I am thinking of what is essentially a bit of
    chain, the sort of thing you see Brunel next too. Oval, with a bar
    across the middle.
