Grammar question
Discussion in 'UK Motorcycles' started by Champ, May 26, 2004.
  1. Champ
    Can someone easily define the correct usage of "myself", "himself",
    yourself" etc.
    I keep hearing people say things like "I decided to refer it to
    yourself", which I'm sure should be "I decided to refer it to you",
    but before I go postal abouit it at work I thought I'd seek a ruling
    here.
    Champ, May 26, 2004
  2. Champ
    dwb Guest
    dwb, May 26, 2004
  3. Champ
    Jeremy Guest
    It is a bloody annoying trait - dunno where it has sprung from but seems
    to be very common.
    Here's one for you: is it correct for people to use the expression 'for
    free'? To me it sounds like it should be either 'for nothing' or 'free
    of charge'.
    jeremy
    ['75 RD250A ] | ['02 Fazer 600 in blue]
    ____________________________________________
    jeremy dot ovenden at hazelweb dot co dot uk
    Jeremy, May 26, 2004
  4. Champ
    You are correct.
    Ace, May 26, 2004
  5. This would only work with a huge Orish accent.
    Nah. Much more fun to go postal about something you then
    turn out to be wrong about.
    William Grainger, May 26, 2004
  6. Champ
    Ginge Guest
    You are correct, go postal, or check yourself before you wreck
    yourself..
    Ginge, May 26, 2004
  7. Champ
    Champ, May 26, 2004
  8. Champ
    Only fun for others
    Champ, May 26, 2004
  9. Champ
    Tim Guest
    "you" is plural.
    Tim two#21, YGL#3 & BOTAFOT#84
    Due to the limitations of current email, the lip movements may be
    out of synchronisation as you move your finger under the text while reading.
    tim dot ukrm2 at dsl dot pipex dot com
    Tim, May 26, 2004
  10. It was somewhere around Barstow, on the edge of the desert, when the
    That's "ewes", shurely.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 26, 2004
  11. Champ
    TMack Guest
    SNIP
    No I am not plural.
    Tony
    TMack, May 26, 2004
  12. Champ
    Owen Guest
    Otherwise it would be "I decided to refer it to yourselves"...
    Blah, blah, blah...
    O
    1 Black, shortly to undergo extensive surgery.
    1 Red, undergoing lightweight surgery. -----
    1 Blue, for Power-Ranger baiting. | o |
    Numbers ... | o |
    Stuff ... | ooo |
    Life ... -----
    Owen, May 26, 2004
  13. In uk.rec.motorcycles, Jeremy said:
    "Gratis", "Nil charge" and "Nixxis" are three I use. I very rarely say
    "Free" because it sounds like "Three".
    Whinging Courier, May 26, 2004
  14. In uk.rec.motorcycles, Grimly Curmudgeon said:
    No, that's sheeps.
  15. Champ
    AndrewR Guest
    I'm reading "Watching the English" by Kate Fox ATM and she lists the "seven
    deadly sins"; seven words that middle-middle class people or lower use which
    mark them as being beneath the upper and upper-middle classes.
    Some of them ("dinner" when used to describe the midday meal, "sweet" used
    to mean the dessert course of a meal and "settee") I would have picked up
    on, but the other 4 ...
    Did anybody else here know that it's very middle class to use "pardon"[1],
    "lounge", "toilet" or "serviette"?
    [1] Jilly Cooper apparently heard her son tell one of his friends that,
    "Mummy says that 'pardon' is much worse word than '****'".
    AndrewR, D.Bot (Celeritas)
    Kawasaki ZX-6R J1
    BotToS#5,SBS#25,IbW#34, TEAR#3 (and KotL), DS#5, COSOC#9, KotTFSTR#
    The speccy Geordie twat.
    AndrewR, May 26, 2004
  16. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Whinging Courier
    Ah, but which sheep?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, May 27, 2004
  17. Champ
    "what?", "heap out", "bog", "sleeve".
    platypus, May 27, 2004
  18. In uk.rec.motorcycles, Grimly Curmudgeon said:
    "Flossy" :)
    Whinging Courier, May 27, 2004
  19. Champ
    AndrewR Guest
    Apparently using "what?" in place of "pardon" and "bog" instead of "toilet"
    are both acceptable to the upper-classes, the latter only if you are
    obviously being ironic.
    I meant "lounge" in the sense of a room in one's house, but "heap" might do.
    Kawasaki ZX-6R J1
    AndrewR, May 27, 2004
  20. In uk.rec.motorcycles, Simian said:
    "Summink to eat"
    "Afters", although my family says pudding and my Nan says sweet.
    "Eh?", "What?" But pardon if talking to someone with influence, which is
    hardly ever :)
    Lav, Bog, Khazi
