GPZ900R troubles
Discussion in 'Australian Motorcycles' started by BT Humble, Nov 29, 2008.
  1. BT Humble
    I realised today that I hadn't started my GPZ900R in a couple of
    months, so I gave it a try and flattened the battery.
    After giving it a few hours of charging and much cranking it started,
    but was only running on the leftmost 2 cylinders (i.e. the sidestand
    side). I switched it off and thought about the situation for a while,
    put the bike on the centrestand and voila - it started as soon as I
    touched the button and ran on all 4 cylinders.
    I'm suspecting that I have a problem with either carburettor float
    heights or the fuel plumbing between the tank and the carbies. Does
    anyone have any other ideas as to where I might profitably probe?
    I'm also thinking that this means that the nice bloke who charged me
    $1100 for servicing earlier this year didn't probe anywhere nearly as
    deep into the fuel system as he said he did...
  2. BT Humble
    [shrug] I'd drain the carbs and check the tap for grunge and the vacuum-line
    for leaks and then probably give up and go watch TV.
    Knobdoodle, Nov 29, 2008
  3. BT Humble
    Nev.. Guest
    what's going on, Clem? not even a vague reference to his cranking?
    http://tinyurl.com/6dy6pk
    Nev..
    '07 XB12X
    Nev.., Nov 29, 2008
  4. It's a classic problem with these bikes.
    Kevin Gleeson, Nov 29, 2008
  5. BT Humble
    Heh heh; I'm feeling guilty since he was so kind as to offer me the GPZ when
    the Trumpy shit itself.
  6. BT Humble
    Update:
    Today I went to take it for a test ride (prior to heading off to
    Thredbo tomorrow), and from start-up it was only running on 3
    cylinders (actually more like 2.75 - #1 wasn't firing at all, and #4
    had a weak spark).
    Since both the #1 and #4 cylinders are driven from the same coil, I
    replaced it with a used one from a GPz750 ($40) and new plug leads and
    caps ($5 each). It's running much better now, although I'll bet that
    the fuel starvation issue will still be hanging around.
    I suppose you've got to expect these type of things from high-mileage
    23-year-old bikes though.
    BT Humble, Dec 29, 2008
  7. Not when they are Japanese. : )
    Fraser
    Fraser Johnston, Dec 30, 2008
