GPz750 and Motad zorst
Discussion in 'UK Motorcycles' started by Otter, Nov 15, 2004.
  1. Otter
    Otter Guest
    Had to replace the original 4-2 zorst on the '83 GPz750 (non-turbot)
    at the weekend cos it had rusted in all the wrong places.
    Bought a Motad 4-1 as a replacement and, after buying some proper
    split collets and some exhaust gaskets, I fitted it at the weekend.
    First proper ride today and although it sounds okay there is an
    annoying flatspot at 6k.
    Has anyone any experience of rejetting for this particular setup?
    Otter, Nov 15, 2004
  2. Otter
    Is the right hand silencer still any good?
    sweller, Nov 15, 2004
  3. Otter
    Otter Guest
    Not bad. I've had to re-rivet the plate on the back - but apart from
    that - it's fine.
    Both middle down-pipes and the LH silencer are good
    I'm in south Northants.
    Otter, Nov 15, 2004
  4. Otter
    Otter Guest
    Agreed, that worked for my GPz550H2. Made the bike a lot more usable
    from much lower revs.
    Otter, Nov 15, 2004
  5. Otter
    I'm a bit stuck for a temporary jobbie on the turbo while I get a new
    twin turbo -> exhaust pipe sorted.
    Any chance of having yours if it measures up [1]?
    38mm dia and when in position the front clamp area is at least 17mm in
    front of the rearmost edge of the lower frame rail VIN - the GPZ 750 does
    have a VIN plate there?
    See this for what I mean:
    http://sweller.dynalias.org/turbo311004/photos/photo2.jpg
  6. Otter
    heh - I hope so.
  7. Otter
    By which I mean I'm getting a pipe made up that goes from the /single/
    turbo to two exhaust pipes. Not twin turbos; which is a shame.
  8. Otter
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, sweller
    Well, look, now you've had the idea...
    Nigel Eaton, Nov 15, 2004
  9. Otter
    Otter Guest
    It seems your pipe is a bit short.
    Mine seems to bend further around the frame
    http://img80.exs.cx/my.php?loc=img80&image=exhaust.gif
    (The jagged red line is where the pipe has rusted through)
    Otter, Nov 15, 2004
  10. Modern Motads are utter shite. When they ratcheted down the noise
    limits, Motad simply seemed to bung their pipes up more. Time was, 20
    years or so ago, when a Motad gave exactly the same power
    characteristics as OE. Not any more.
    After my experiences with a Motad and my old GT750, I'd never buy one of
    their systems ever again.
    (Statto - have you still got my ShiteOldGT?)
    The Older Gentleman, Nov 15, 2004
  11. Otter
    The Older Gentleman says...
    I don't have much choice for the CB250RS, no-one else makes one for it.
    The one it has is rotten as a pear and has been welded about 5 times. I
    think it's only about 4 1/2 years old. I first had it welded about 2 1/2
    years ago.
    Lozzo, Nov 15, 2004
  12. Otter
    Salad Dodger Guest
    characteristics as OE. Not any more.[/QUOTE]
    Oddly, the full Motad system on the Wing is more free-breathing than
    the chromed tissue paper original.
    Stainless too, meaning it doesn't corrode, but it's not very shiny.
    Oh, and around £550, rather than £1400+.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16931.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Nov 15, 2004
  13. Otter
    Statto Guest
    (Statto - have you still got my ShiteOldGT?)[/QUOTE]
    Yes. The Motad exhaust really has fucked up the power delivery.
    Fuckall below 3k revs, then power is finally delivered. Peakiness can
    be fun with the correct bike, but on a shite old shafty? It's slightly
    annoying when it's cold, dark and pissing down and all you want is to
    get home.
    Statto, Nov 15, 2004
  14. Otter
    Gawd knows what my FZR would be like if Motad ever made an exhaust for
    that. 3k? the rev counter starts at that.
    Muck, Nov 15, 2004
