GPZ600R Won't Start - Compression Issue
Discussion in 'Motorbike Technical Discussion' started by Rabbit, Apr 7, 2011.
  1. This is Krusty. Accuracy is optional.
    The Older Gentleman, Apr 9, 2011
    #41
  2. And that qualifies you to speak about engines incredibly more
    sophisticated and with massively higher specific power outputs? With the
    best will in the world, I've heard loads of people pontificate "because
    they know about cars".
    Loads of people have told me that the bike I'm thinking of buying, and
    which I can see has been bodged, has been serviced by their dad who
    "knows all about motors"[1].
    Even if it does, the point is one of simple probability. You can
    half-remember *one* vehicle which had some sort of issue in the last
    decade.
    This ng gets loads of people complaining that their bikes don''t start
    after (usually winter) lay-offs. And I can't remember one that *wasn't*
    fuel related, though there may have been one.
    Now, winter can bollox carbs in a surprisingly short time. I left one of
    my bikes parked outside in January 2010. I'd been using it as a daily
    commuter, and it ran perfectly, every day. Went on holiday. Came back.
    Would it start? Would it buggery. It had sat in two weeks of the
    nastiest winter we've had here for many years. I tried everything.
    Heating the plug, new plug, fresh fuel, you name it. Got it going in the
    end and it ran as rough as feck. I ended up stripping down the carb and
    cleaning it and rebuilding it *properly*, and all was well.
    What had happened to the carb while it had been standing for a mere
    fortnight? No idea. I'd guess at something condensing in the carb and
    then freezing, but really, I've no idea. All I knew was that the problem
    wasn't going to be the head gasket )although there's a tiny weep from
    it) nor the compression, nor the ignition, nor anything *except* the
    carb.
    And here's you asking him to check the oil, check the type of oil,
    suggesting checking hydraulic lifters, saying that it has two dead
    cylinders when it doesn't, suggesting the valve stems may be carboned up
    and stopping the valve from closing, suggesting plugs may be carbon
    tracked (when did that last happen on any Jap bike other than a
    two-stroke??), and all kinds of similar, highly unlikely, things when
    the most likely problem area is...
    .... the carbs.
    Could be a duff fuel tap as well, but that's so easy to check.
    Incidentally, let's move onto the compression issue. The OP now says it
    "ran fine the last time it was out". On ukrm a while back we had a bod
    who had such incredibly low compression on *all four* of his cylinders
    that I (and others) told him that the dealer couldn't have been checking
    correctly. I can't remember what the readings were, but they were way,
    *way* lower than the lowest reading on the one possibly-problematic pot
    that this engine has.
    I mean, you don't get compression failure on *all* cylinder
    simultaneously unless something catastrophic has happened.
    And then he admitted, shame-faced, that he'd accidentally run the thing
    on diesel. OK, that'd do it.
    Decades ago, I neglected the shims on a GS Suzuki (I was skint and just
    couldn't afford to pay a dealer and didn't then have the nous to DIY).
    Turned out it had compression that was damn near atmospheric, but it
    still ran. One cylinder with a tested compression of 30-48psi, even
    assuming that figure is accurate (I've nothing to say it isn't)....
    Is
    Not
    Going
    To
    Be
    An
    Issue
    Here.
    [1] Or, almost as often, who "knows all about bikes" because he had a
    BSA in 1960.
    #42
  3. Rabbit
    Rabbit Guest
    Cheers for all the excellent posts.
    Some more details:
    1) When I said it would occasionally plutter, smoke and then run fine
    the smoke was black, not too thick and didn't hang around for a while.
    It is generally after riding for more 5 minutes, during which it runs
    fine. This is only happens occassionally but I can't see to see any
    major patter, just generally within 5-20mins after starting.
    2) I have tried starting it on a closed trottle.
    3) When cleaning out the carbs I made sure of cleaning out all the
    starter jets and passeways.
    4) When I said it ran fine the last time it was out it did indeed run
    fine. The last time I took it out was to a garage to check out the
    shock. It ran fine there, the mechanic said it ran well when he took
    it for a test drive the next day, and it ran well the following day on
    my journey back home. Then, due to snow, it put away until January.
    5) The carb slides all moved smoothly when I reinstalled them but will
    check when the airbox is off again.
    6) The fuel tap is fine, have tested.
    7) I have had the bike tuned on a dyno before and it is these settings
    that I returned the carbs to (double checked on disassembly), not what
    is in the manual.
    8) I filled the float bowls by putting tank on prime and opened the
    screws at the bottom of the float bowls.
    9) I have replaced the spark plugs.
    I will try the following:
    a) Fully unscrew the idle adjuster and try to start.
    b) As above but with full choke applied.
    c) I'll take out the airbox and hand choke the carbs.
    d) Investigate air leak at rubbers - unscrew idle screws out further.
    Should start but will get poor idle when warm
    e) Reduce spark gap and try again.
    I'll let you know how I get on.
    Rabbit, Apr 9, 2011
    #43
  4. Rabbit
    ` Guest
    Are you in the UK, or Canada?
    Two possible causes would be (1) the float valve doesn't always seal
    properly due to gum and varnish or debris coming down from the gas
    tank, and (2) some mechanic has improperly adjusted the idle mixture
    screws.
    The latter is a very common error amongst shade tree mechanics. They
    expect that the idle RPM will increase as they turn the idle mixture
    screw more and more counterclockwise.
    After about 3 full turns, the idle screw has *NO* further effect to
    raise the idle RPM, it has the *opposite effect*, the idle RPM
    decreases because the mixture becomes *too rich* and the engine
    stalls.
    The newbie mechanic then tries to adjust the idle speed screw and this
    casues the throttle butterflies to uncover a pattern of three
    acceleration transition ports that aren't supposed to be uncovered at
    idle.
    When the newbie blips the throttle to check for correct throttle
    response, the engine gets extra gas through the transition ports and
    the idle RPM hangs up at 4,000~5,000 RPM and may take 30 seconds to
    fall back down to the specified idle RPM.
    A motorcycle with a rich condition like that cannot be ridden safely,
    the engine keeps driving it into corners and up to stop signs.
    When the engine gets warm, the idle RPM will rise up and hang there,
    and the newbie mechanic guesses that maybe there's something wrong
    with his throttle cable.
    The newbie mechanic may be smart enough to turn the idle speed knob
    back down, but by that time he's lost track of what he did wrong,
    which was when he opened the idle mixture screws too far.
    I can usually find the factory idle screw setting from looking at
    parts lists, but it's not in the online parts diagram for the 1986
    Ninja 600 at www.powersportspro.com.
    Nor does the parts list tell me what size the pilot jet is.
    But a typical pilot jet for an engine that size would be around #30
    and I would start with the idle screws set around 1.0~1.25 turns out
    from lightly seated and check for throttle response upon blipping the
    throttle and I would observe whether the RPM hung up when the engine
    warmed up.
    The engine should start on full choke, no throttle, regardless of what
    the idle screw settings are because the cold enricher system
    *bypasses* the idle mixture system.
    If the engine starts on the choke with the idle speed screw turned out
    the way out, you'll have to hold the throttle open to get it to run as
    you re-adjust the idle speed upward.
    Then, when the engine is warm, adjust the idle mixture screws if the
    engine won't idle or if the idle speed hangs up upon blipping the
    throttle or when the engine gets hot.
    As I explained above, you don't want to open the idle mixture screws
    too far.
    The normal procedure is to turn the idle mixture screws *IN*, not out,
    and adjust the idle speed *DOWN* not up.
    http://www.powersportspro.com/pages...ki/ZX600-A2_Ninja_600_(1986)/CARBURETOR_PARTS
    http://partstream2.arinet.com/Image...HNSKUVMQ2&aria=jqPY9vw5KHLzIQCm6WDPOw2&ariz=1
    16014 16014-1029 SCREW,PILOT ADJUST | CN
    16014A 16014-1054 SCREW-PILOT AIR | CA,US
    92063A 92063-1008 MAIN JET,#100 | CN,US
    92063B 92063-1009 MAIN JET,#105 | CN,US
    92063C 92063-1009 MAIN JET,#105 | CA
    92063D 92063-1115 JET-MAIN,#102 | (RACING USE ONLY)
    92063E 92063-1116 JET-MAIN #108 | CN,US
    92063F 92063-1117 JET-MAIN #112 | CN,US
    92064 92064-1119 JET-PILOT
    `, Apr 9, 2011
    #44
  5. Rabbit
    paul c Guest
    That all makes sense to me, at least for an engine that has no other
    problems. Just want to mention that I suggested turning out the idle
    mixture screws solely to see if that would help the engine start in
    which case a manifold boot air leak would be easier to notice. I should
    have mentioned I meant that as only a temporary measure. As you say,
    it's not pleasant to ride with an engine that's set too rich.
    paul c, Apr 9, 2011
    #45
  6. Rabbit
    paul c Guest
    I find his technical advice to be routinely pertinent. Over the last
    five or six years it's been pretty obvious to me that he is the resident
    expert on carbureted fuel problems. There have been a few other
    regulars, such as Mark O and Rob K who also give sensible advice on a
    variety of mechanical/electrical topics. I mean actionable advice,
    without a lot of hand-waving or editorializing.
    paul c, Apr 9, 2011
    #46
  7. Rabbit
    Keith Guest
    IGNORE this idiot...he's so stupid he couldn't pour piss out of a boot
    with the directions printed on the bottom in large block letters.
    Keith, Apr 10, 2011
    #47
  8. Rabbit
    Keith Guest
    They aren't dead you dipwad...you are starting to sound as smart as
    Krusty.
    It should...
    Keith, Apr 10, 2011
    #48
  9. Rabbit
    Keith Guest
    You know that, I know that but the GM mechanic doesn't think so...then
    again the worst mechanics I've EVER met worked in dealerships. Most
    were incompetant at best.
    Keith, Apr 10, 2011
    #49
  10. Rabbit
    Keith Guest
    TYVM...I do my best.
    Keith, Apr 10, 2011
    #50
  11. Rabbit
    Keith Guest
    Uh, news flash chid molester...he's taller than you. You are taller
    than me...but I can kill you with one hand behind my back and not even
    feel a twitch of emotion or give a shit. Now do **** off you piece of
    shit.
    Keith, Apr 10, 2011
    #51
  12. Rabbit
    Keith Guest
    BULL SHIT...he just cuts and pastes without attribution from other web
    pages. But he, go ahead, keep thinking he's smart...but that just
    makes you even dumber than he is.
    Keith, Apr 10, 2011
    #52
  13. Rabbit
    Keith Guest
    No, not it isn't hard to get them full to the proper level and it sure
    doesn't take 10 attempts to start to do that. But hey, you obviously
    went to krusty's ass sucking school of motorcycle exspurtease.
    Keith, Apr 10, 2011
    #53
  14. He can copy & paste. He has no practical experience, and he's also the
    bod who advised a poster to rip out his ignition system when it was
    patently obvious it was the carbs that were at fault.
    As the poster admitted later, when he fixed them.
    The Older Gentleman, Apr 10, 2011
    #54
  15. Rabbit
    ` Guest
    You're a lying sack of shit. It was your sock puppet's own idea to
    remove his coils for testing.
    `, Apr 10, 2011
    #55
  16. Indeed, and as we've proved before by pointing people to the relevant
    postings, you encouraged him to do it.
    Next!
    #56
  17. Rabbit
    Keith Guest
    and you once again avoid admiting encouraging said actions much less
    your own misguided and bad advice on the entire matter. Admit it...you
    know nothing about anything that matters. Motorcycles, beer and pussy
    being the only things in the world that matters. Being a nonriding,
    perscription drug abusing pedarastic zoophile that makes it rather
    obivous that your advice is best only observed for it's "What not to
    do" factor.
    Keith, Apr 11, 2011
    #57
  18. Rabbit
    Keith Guest
    Fine. The smoke came of of the coils of my ariel atom*...should I
    clean the carb and relube the wheel bearings and see if that will help
    it start?
    *Note, I wouldn't mind owning an Arie Atom if for no other reason than
    I could trade it for old suzuki parts.
    Keith, Apr 11, 2011
    #58
  19. Rabbit
    walt tonne Guest
    Holt's Piston Seal was popular in the "heyday" of British auto and
    motorcycle
    production. Squirt a shot of that gummy red stuff into the plug
    openings, crank
    motor for a couple of minutes, take off.
    walt tonne, May 1, 2011
    #59
  20. Rabbit
    TOG@Toil Guest
    Yeah, *right*. Up there with Instant Rebore (which was applied in the
    same way) as one of the great Snake Oil rip-offs.
    TOG@Toil, May 3, 2011
    #60
