GPZ600R Won't Start - Compression Issue
Discussion in 'Motorbike Technical Discussion' started by Rabbit, Apr 7, 2011.
  1. Rabbit
    Keith Guest
    Oh shut the **** up you idiot...
    Keith, Apr 8, 2011
  2. It's the carbs. Gummed up, and he didn't clean them properly. Or worse
    still, buggered them further in trying to clean them.
    The Older Gentleman, Apr 8, 2011
  3. Cruel but succinct and accurate.
  4. Rabbit
    ` Guest
    Try and make me shut up, you retarded midget.
    `, Apr 8, 2011
  5. Rabbit
    Rabbit Guest
    Firstly, thank you all for the replies. To give you some more details
    and to answer some of your questions:
    1) The oil level is in the middle of the range of LOW – HIGH.
    2) It is OK oil, not the most expensive and hasn’t been changed in
    about a year.
    3) It ran fine the last time it was out (and the time before that), no
    issues. It does occasionally die once warmed up or kinda bog down and
    won’t go past about 4kRPM ish. Then after a while it clears itself and
    all is fine again (accompanied by some smoke out the exhaust).
    4) I don’t believe it is stale fuel as I put brand new fuel in about a
    month ago when I cleaned the carbs out. I also fitted an in-line fuel
    filter at the same time.
    5) I’ve stripped GPZ carbs about 3 times over the years, when I
    suspect a fuel issue, and it has always run fine afterwards. This time
    it has not but I believe I’m competent at the job. I did a more
    thorough job than what I have seen mechanics do, which is a quick
    spray of all the bits with carb cleaner and air hose. They are CV
    carbs.
    6) When I cleaned out the carbs I completely disassembled them,
    cleaned out all the jets, passageways, etc will carb cleaner (the idle
    jets were clogged). This includes all the little passageways, float
    bowls, etc. Everything was very clean going back together, adjusted to
    the settings they were at previously. Everything that needed it was
    oiled (eg, throttle spring). Throttle butterflies were adjusted so
    that they all open at exactly the same time.
    7) I don’t believe leaving a bike on its side-stand will cause head
    gasket failure, that would be ridiculous. I thought it may be a
    contributing factor. Perhaps there was moisture around the engine that
    freezed/thawed over the sub-zero winter. I don’t know, just thought it
    might be a useful question.
    8) My method to getting it started: Iginition (got good spark with
    charged battery and new plugs), fuel (think this is OK due to new
    fuel, smell of fuel, cleaned out carbs, in-line filter and it won’t
    start n brake cleaner), so then looked at compression (found 2 low
    pressure cylinders).
    9) The valve clearances were adjusted by a garage about a year ago.
    10) Have checked the HT leads go to the correct plugs, even double
    checked with the wiring diagram.
    11) Had a strong spark on all 4 cylinders.
    Hope this helps. :)
    Rabbit, Apr 8, 2011
  6. Rabbit
    ` Guest
    Low oil level will not affect whether or not the engine starts.
    The quality of engine oil will not affect whether or not the engine
    starts.
    That tends to indicate a carburetor problem.
    Bluish white smoke coming at the exhaust indicates that the rings
    aren't sealing or that the valve guide oil seals are leaking.
    If the rings aren't sealing, the engine will smoke all the time.
    Valve guide oil seals leak so little oil it collects in the combustion
    chamber and burns off when the engine is first started.
    Oil smoke is thick and it hangs around for a while.
    White smoke that rises from the exhaust pipe and dissipates rapidly is
    either condensation of coolant leakage into the combustion chamber.
    If two adjacent cylinders have low compression that might indicate a
    leaky head gasket, and a leak down test would prove if that was the
    case.
    An engine will start just fine on stale fuel. I've started engines
    that had gasoline in the tank that was two or three years old.
    The volatile fractions that help keep carburetors clean and non-
    polluting also cool the combustion process and when the additives are
    gone the engine will ping when it gets really hot.
    One of the problems that confuses newbies is that CV carburetors don't
    have a real plate type choke. They have cold starting enricher valves
    which are opened when the "choke" lever or knob is moved to the ON
    position.
    The enricher valves are AIR valves which bypass the throttle
    butterflies.
    Air flow through the enricher passages causes enough vacuum to suck
    fuel directly out of the float bowls.
    But the throttle butterflies must be completely CLOSED when cranking
    the engine with the electric starter.
    One trick is to turn the master idle knob all the way
    *counterclockwise* so the throttle butterflies are not open the least
    little bit.
    The engine should start and idle on the fuel air mixture which comes
    through the cold start enricher circuit, even on a cold day, if the
    enricher valves are fully open.
    However, the starter jet is a hole in the bottom of the float bowl. I
    hope you squirted carburetor cleaner through all the starter jets in
    the float bowls.
    Like I said above, turn the master idle knob all the way
    counterclockwise and apply full "choke" and don't twist the throttle
    when trying to start the engine.
    Sometimes I've found it necessary to hand choke the carburetors by
    putting the palm of my hand over the inlet of each carburetor in order
    to get the engine vacuum to suck fuel up into the idle jets and idle
    passages.
    The last time I had to do that, the engine hadn't been run for 4 years
    and I removed the carbs and cleaned them thoroughly.
    There wasn't a lot of gum and varnish in the carbs, but the engine
    just wouldn't start until I hand choked each carburetor.
    `, Apr 9, 2011
  7. Rabbit
    ` Guest
    Go jump off of Tower Bridge, you stupid cocksucker.
    `, Apr 9, 2011
  8. Rabbit
    paul c Guest
    When you say it 'ran fine' at one time, I presume that it was generally
    startable and rideable, even though not as powerful as it would be with
    four good cylinders. Regarding points 3) and 6), it does seem that the
    immediate starting problem is related to air/fuel mixture which is
    pretty crucial (ie., roughly speaking, if the ratio is less than approx
    12:1 or more than 17:1, it will probably be impossible to start):
    a) Perhaps there are leaks in the intake manifold, especially if it's
    the rubber kind that deteriorates with age and also can easily get
    distorted with repeated carb removal and installation. Sometimes this
    results in the low speed symptoms mentioned in point 3). If so, the
    carbs might well have been adjusted rich in the past to make it run but
    the leak is just getting worse. If there is a manifold air leak you
    might find that turning the idle screws out even further will make it
    start, although it won't idle very well once it's warm - this would give
    further evidence of an air leak. Hard to find an air leak unless you
    can get the engine started. I'd also double-check that the enrichment
    circuit or choke (whichever these carbs use) is on. If there is a choke
    plate on the air side that could be checked visually, if enrichener
    passage you'd need to blow air or fluid through the carb orifices to be
    sure. If one or more carbs has an accelerator pump that might need
    checking to (usually service manuals say how). I forget the name but
    sometimes there's another device on carbs that shuts off fuel when the
    throttle is released at speed to avoid backfires.
    (Possibly a leak-down test could show a manifold air leak but I'm not
    sure it would be easy to notice in this case since we already have some
    leaking cylinders.)
    b) I would also double-check the idle mixture screws (slow jet) against
    factory settings (ie., number of turns out), if you can find a reference
    for that. Also make sure each one of the screws still has its spring,
    washer and o-ring intact. Similarly for the floats (ie., level).
    c) In spite of the apparent good visual spark, in case the ignition
    components are marginal/weak, I'd try to set the spark gap to the narrow
    side of the recommended range which might help in at least getting it
    started so that you spray the manifold to see if it's leaking. Cross
    your fingers that it's not just pickup coils going down hill because
    that's a little harder to diagnose.
    I'm pretty sure that most any of the Japanese four-cylinder bikes will
    run after a fashion with only two good cylinders and can usually be
    started in a couple of tries.
    paul c, Apr 9, 2011
  9. Rabbit
    paul c Guest
    On 08/04/2011 4:56 PM, ` wrote:
    Minor point - at least a few CV carbs do have a 'plate' choke, eg., the
    ones on the 1982 DOHC CB750's.
    paul c, Apr 9, 2011
  10. Rabbit
    paul c Guest
    All good points from what I've seen. (It took me a long time to learn
    to ignore the advice of neighbours to try to start with WOT. Amazing
    how so many people think a high-speed engine throttle setting is better
    for starting which is necessarily done at low speed.)
    Also, with four carb bowls, if they've just been installed after
    cleaning, it can take ten or more start attempts just to get the bowls
    filled with fuel.
    paul c, Apr 9, 2011
  11. Rabbit
    Bill Vanek Guest
    I was talking about engines in general, not motorcycle engines. I was
    an auto mechanic.
    Something changed here. It was not 1920 30 years ago.
    Yes, with solid lifters.
    Can you actually read? It sat for a month, if that. But "I'm not doing
    well", eh?
    One month or less. Like I said, *read* the original post.
    You don't pick your spots too well.
    Bill Vanek, Apr 9, 2011
  12. Rabbit
    Bill Vanek Guest
    So what? I have seen it.
    "Not a chance"? I don't know where you worked, but I worked in
    dealerships (GM), and dealer mechanics see a lot of strange things
    that get worked out before the cars start hitting the independents. GM
    had this issue with one of their SUV's around 2005. I don't remember
    which engine because it was a "foreign" vehicle - Chevy or GMC in a
    Cadillac dealer. We took it in as a favor to the owner, called the
    factory on a no-start problem, and that was the cause. Something to do
    with tight clearances, and gasoline additives.
  13. Rabbit
    Bill Vanek Guest
    Once again, one month or less is not "months".
    It is *an* issue. Or do you just shrug that sort of thing off? I mean,
    what's a couple of dead cylinders, right? There's two more after all.
    I'm sure you do, but probably not with engines & driveability problems
    in general.
  14. Rabbit
    Bill Vanek Guest
    The bike sat for a month. Do any of you actually read the posts your
    replying to? Or do you just fire up the mindless sarcasm when you
    think you see an opening?
    Right. **** the dead cylinders.
    Gee, that hurts.
  15. Rabbit
    Bill Vanek Guest
    Have you replaced the plugs? If they're wet, or carbon tracked, it's
    not going to start. It's more effective to replace than clean.
  16. Rabbit
    ` Guest
    Well, Rabbit's Ninja does have a PRIME position on the fuel tap, so it
    should be no problem to fill the float bowls.
    What I see as the biggest problem here is Neil Murray (TOG) trying to
    shit all over the thread (as usual), and if Rabbit doesn't know that
    Neil Murray is an asshole he will be confused by his spurious
    "adviceis"
    `, Apr 9, 2011
  17. It doesn't have two dead cylinders.
    The Older Gentleman, Apr 9, 2011
  18. It doesn't have two dead cylinders.
    Want a JCB for that hole you're digging?
  19. I did. The mniddle of winter makes it worse. It's now sat for four
    months.
  20. It's the carbs.
