GPZ600R Enginer & Handling Issues - Any Suggestions?
Discussion in 'Motorbike Technical Discussion' started by Rabbit, Aug 14, 2010.
  1. Yes, I took a lap on my friend's 1986 600 Ninja. He was standing at
    the apex of a slow hairpin corner and he threw a liter of water on me
    as I went by because he thought I was riding his precious too hard.
    But he retired the Kawasaki to street use and bought and FJ600 which
    was more stable handling in the high speed Turn 8 at Willow Springs
    where he could go 130 mph.
    He just didn't want to try and ride the Ninja that fast. He had been
    class champion in the 550cc class on his CB550 in the mid-1980's.
    schwarzesonne, Aug 16, 2010
  2. Hey! I've offered help to Dylan before, under totally anonymous
    circumstance, and he was also polite and he thanked me for my help.
    But, you always have to be a sanctimonious asshole.
    What makes you and Dylan so different?
  3. Reading more carefully, I see he did replace the
    swingarm bearings already.
    I guess the other interesting question is how the handling
    problem began. Did it start suddenly, and if so, what changes
    to the bike and riding events immediately preceded it ?
    Any change of tires or bearings or other maintenance just
    before the problem started would be strong suspects.
    Rob Kleinschmidt, Aug 16, 2010
  4. Rabbit
    S'mee Guest
    So? Goatse you have to understnadn something...if you don't have my
    permission then you can't post anywhere. I mean for crying out loud I
    told you to NOT go to sturgis and you stayed hom like the little
    cowardly pedo that you are. So, I'll make it real simple for you. Get
    off of usenet...NOW boy. Or I'll quiet paying your mother and she'll
    just have to do the donkey show for free from now on.
    S'mee, Aug 16, 2010
  5. Rabbit
    S'mee Guest
    Because TOG knows what an uneducated deviant you are.
    S'mee, Aug 16, 2010
  6. Doh. 1984, actually.
    The Older Gentleman, Aug 16, 2010
  7. Oh, one lap. Two years later. Qualifies you to pronounce on it, then.
    Yes.
  8. I'll bet S'mee's goatse ass that the problem is with those squirmy
    dual tread compound BT45's...
  9. Rabbit
    S'mee Guest
    shows what a nonriding fraud like you know...then again I've only
    45,000 miles on BT45's. I couldn't possibly have a clue after riding
    on them in pouring pacific north west rain, desert heat or highly
    abrasive rocky mountain roads how they handle and behave. Oh no I
    couldn't possible know more than a man who has never ridden a
    motorcycle in his life and LIES about owning and riding motorcycles.
    Tells us again why grumman fired you...something about not cleaning up
    LEM 1 as I recall, you said it was womens work.
    S'mee, Aug 17, 2010
  10. Rabbit
    M.Badger Guest
    Crap in the carbs, choked air filter, cleaning rag left in the airbox/near
    the intake. Were all four plugs sooty or just one?
    Head bearings too tight/notched/dry can cause similar, as can poor
    alignment.
    M.Badger, Aug 17, 2010
  11. Nonsense.
    The Older Gentleman, Aug 17, 2010
  12. That's several votes for the head races so far.....
  13. Point being though that problems don't just appear
    by magic. Not always but very, very often, they can
    be traced back to the most recent work done on a
    bike.
    So the question is whether the problem appeared
    when the bike was put back on the road after working
    on it or a longstanding problem that the owner gradually
    became aware of or something that cropped up suddenly
    with no recent work on the bike.
    If a problem cropped up suddenly with no recent work
    I'd worry a lot, but this is pretty uncommon.
    Oddly, this type of information usually gets omitted from
    problem reports.
    Rob Kleinschmidt, Aug 17, 2010
  14. Rabbit
    M.Badger Guest
    We use BT45's on our training bikes, and we used them at my last place too.
    Why?, they are a stable, tractable, predictable tyre that gives a compliant
    ride and thus engenders confidence in our novice riders.
    It may be the OP is noticing new tyres, and previously rode on a different
    brand/profile tyre. It may be the OP is hanging on for grim death and the
    bike doesn't like it. Providing the tyres were fitted the correct way round,
    the pressures are OK, everything is in approximate alignment, then one of
    the last things I'd look at would be the tyres.
    I'd start at the front. No play in the front bearings. No play in the fork
    bushing. Axle nut tightened. 'Bars free to move from side to side with no
    notching and no play. Get a fishing weighing scale and check the turning
    force required. It'll be in the manual somewhere.
    Noving back, check the rear fork for play. It may be the bearings have
    'seated' and need nipping up. Check for play in the rear wheel bearings and
    suspension links.
    Check the static and rider sag. You need sag. You also need controlled boing
    in the suspension, so is it damped.
  15. My ding-meter has just broken.
  16. <G>
  17. Rabbit
    ` Guest
    Well fer chrissakes! Just *look* at the tread pattern on those things!
    Maybe it rains everyday where you ride, but to me, living in arid
    central California, BT45's are *rain tires* with their deep water
    channels and unsupported tread blocks.
    Mix harder compound rubber in the center of the tread and softer
    compound rubber on the sides, and ride on macadam that has been worn
    by the passage of many car and truck tires, and you have a motorcycle
    that's wiggly in a straight line.
    The 600 Ninja was designed for sporty riding on billiard table smooth
    surfaces and it needs *sportbike* tires with fewer water channels and
    larger, supported tread blocks.
    The absolute wiggliest tire I ever rode on was a Cheng-Shin universal
    tread pattern.
    The zig zag pattern had lots of water channels and tall unsupported
    tread blocks that interacted with rain grooves and brushed concrete
    and my girl friend complained that it made her nauseous to ride on the
    back of the bike as the tread pattern tried to align itself with the
    grooved pavement surface.
    `, Aug 17, 2010
  18. They're perfectly good touring tyres. I'll agree they wouldn't be my
    first choice on a full-on sports bike, but they don't squirm like you
    claim they do.
    Try riding on them. You haven't. I, and other sin this thread, have.
    Utter bollocks.
    More utter bollocks. I rode my first one in 1984 and have ridden more
    since, and you're talking shite.
    No
    <snip the usual antique reminiscence>
  19. Rabbit
    M.Badger Guest
    I live and work in Yorkshire. Yes, it rains. A lot.
    I've used BT45's on trackdays too. A Honda Transalp with them, and a GS500.
    Never had an issue with either bike at Cadwell. Well, other than sod all
    straight line speed. Tyres are a personal thing. I prefer Continental tyres,
    but have a pair of Pirelli Diablo Strada on my Bandit at the moment. They
    were cheap, I was skint.
  20. Krusty, to whom you are replying, is noted for trying to dispense his
    own home-brewed wisdom.
    Time was, a few years ago, newbies hung on his every word, believing
    that they were worshipping at the feet of The Master.
    Unfortunately his bluff has been well and truly called and the
    succession of hysterical misinformation that drips from his keyboard is
    properly refuted every time.
    This has turned him into an embittered little man, which is why he
    morphs his identity, in the hope that he can continue to deceive the
    ignorant and credulous.
