GPZ500 No Spark!
Discussion in 'Motorbike Technical Discussion' started by MonkeyBoy, May 18, 2006.
  1. Those batteries were ones that the plates hadn't sulphated. As long as
    a lead acid battery plates are still OK it will indeed draw a lot of charge
    current if it is low on charge.
    Batteries that are low on acid are ones that the plates have partially
    sulphated. Once the plates sulphate it's difficult to impossible to get
    the crystals to dissolve back into the water in the battery and if the
    plates sulphate the battery will not take much charge current, unless
    you jazz up the voltage to many times a safe level (in which case the
    higher charge current won't necessairly force the sulpher back into
    solution,
    it will just be disappated as heat)
    Old-timey batteries like our friend probably had in his air-force shop
    had solid lead plates - with this type of battery it is possible to tear it
    apart, scrub off the lead sulphate, put it back together and put in
    fresh electrolyte and get it going again. With these batteries once
    they were fully charged, additional charge current would start boiling
    the electrolyte, which would increase acid concentration and thus
    require constant watching, and adding water as the electrolyte went
    down. These also could be reawakened by the addition of fresh
    acid if the plates were partially sulphated, along with funny charge
    currents and voltages.
    Modern lead acid batteries use lead plates that are more like sponges,
    plus their electrolyte isn't just plain old sulpheric acid, it has some
    other
    stabilizer chemicals in it to try to force the electrolyte to never boil,
    so that you never need to add water (maintainence free) as well as
    to try to prevent sulphation (if the battery sits for a long time never
    charged) The different plate composition gives them the ability to
    dump -much higher- current with -much smaller- plate area, which is
    important if your a consumer
    who never checks his battery electrolyte level, trying to start a car in
    Minnesota at -20F temperatures, where the designer has been in a space
    crunch on how much space he can allocate to the battery compartment.
    With this type of battery, once the plates sulphate they fundamentally
    change composition, it is not possible to "re-spongify" them, you may
    be able to get some of the visible sulphation to go away, but the battery
    capacity will be permanently ruined. Adding electrolyte is a big no-no
    because it ruins the electrolyte chemistry and causes the other chemicals
    to stop working because the acid is out of balance now.
    If it has been flat for any length of time, like longer than a few weeks,
    it is ruined. Replace it. It does not take a lot of time for lead acid
    battery plates to sulphate once they are discharged. As long as the
    battery is maintained at full charge, the plates won't sulphate. (at least,
    not that fast)
    Well, yes. The electrical formulas dictate that once the bike alternator is
    producing power, that -if- the auto system presents a -lower- resistance
    to the motorcycle alternator than the bike system, then power will flow
    from the motorcycle alternator to the car system.
    If the car battery is -very- discharged, YET is still a "good" battery
    meaning
    it has not sulphated yet, meaning that it has a low internal resistance and
    will
    thus take a high charge current, and the motorcycle battery is a "bad"
    battery
    meaning that it has completely sulphated and thus has a high internal
    resistance
    and thus will not take a high charge current, then power will indeed flow
    from
    the battery to the car.
    But it is pretty difficult to get a situation in a car where the car battery
    is very
    discharged YET is still NOT sulphated, and thus has a low internal
    resistance.
    If you turn on your headlights for 4 hours and draw the car battery down to
    nothing, then jump start the car, well then for the next 20 minutes or so
    you will
    have that situation. Or if your car engine is a big piece of shit and
    requires
    15 minutes of cranking over with the starter to get it fired up, well then
    once it's
    running then immediately after that yes you will have that situation. I
    think
    though that it would be unlikely that once someone jump started a car that
    they would immediately turn around and try jumping some other vehicle from
    that car. Same if their car engine was a POS. So I think those scenarios
    are
    much more contrived than anything else.
    Ted
    Ted Mittelstaedt, May 28, 2006
  2. MonkeyBoy
    FB Guest
    The only zero frequency DC I know of offhand is static electricity and
    DC from a battery.
    Any rotating device that uses copper windings wrapped around pole shoes
    that pass through a magnetic field is going to have a frequency
    depending upon the number of
    pole shoes and the RPM.
    A DC generator puts out AC current that is "rectified" through brushes
    and a commutator, selecting the positive alternation of the armature's
    output. This produces rippling DC which an oscilloscope would show as
    only the positive halves of the sine wave above the zero line.
    An AC alternator produces AC current that is rectified through a three
    phase full wave rectifier bridge made of six diodes. This also produces
    rippling DC which an oscilloscope would show as only the positive
    The peaks of the positive halves of the sine wave are so brief that
    engineers don't rate their device by the peaks. They have a calculation
    called "root mean square" that
    shows the usable part of the alternation to be 0.707 times the peak.
    If you have a solid state device that produces AC current by running an
    oscillator circuit that feeds AC into a rectifier, you may be
    interested in produce a DC with as little ripple as possible, because
    it makes an annoying buzzing sound in audio outputs.
    Solid state power supplies will have large coils to slow the passage of
    current and a bunch of capacitors to absorb voltage surges in order to
    smooth out the DC output.
    The ripple effect of DC current from an automotive alternator is
    reduced by the battery's ability to absorb and block the highest
    momentary voltages.
    FB, May 29, 2006
  3. MonkeyBoy
    FB Guest
    Don't be silly. Automotive and aviation batteries all have spongy lead
    plates in order to maximize the area of contact with the electrolyte,
    thereby reducing their physical size.
    A battery composed of solid plates that could start a car engine would
    be bigger than the engine itself. A solid plate battery capable of
    starting a J-33 engine in an Air Force jet trainer would be so large it
    wouldn't fit in the whole nose of the aircraft.
    A solid plate battery in an Apollo capsule would have weighed more than
    the three crew members combined.
    No, when we filled the rebuilt batteries with electrolyte, some of it
    would be absorbed ito the plates and some would be boiled away during
    the charging process. So I had to top up fully charged batteries with
    more electrolyte before putting the caps on and setting them on the
    outgoing racks.
    My GSXR shop manual advises mechanics to top up new batteries with
    electrolyte, not water, after they are done with their initial charge.
    Owner's manuals will tell the rider to only add distilled water, never
    acid, to their battery. They never say anything about adding
    electrolyte. That's probably for produst liability, since some
    do-it-yourselfer might try to mix water into sulfuric acid and get
    splattered by it.
    Electolyte is mixed the other way, the acid is slowly stirred into the
    water by an experienced person wearing rubber gloves, a face shield and
    a rubber apron.
    Cheezus H. Kee-rist! The first old automotive battery I ever took apart
    to see how it worked was half a century ago, and it was a spongy lead
    battery. If it had been a solid plate battery, I would have needed a
    fork lift to carry it home.
    My disappointment was that the plates were not made of solid lead, so I
    couldn't sell it for scrap as I thought I could do.
    FB, May 29, 2006
  4. Actually, I remember a 1970s Cossack owner's manual that told owners, in
    the absence of distilled water (probably the usual state of affairs in
    Communist Russia), that it was permissible to use melted snow.
    "But not from a tin roof"
    Honest.
    The Older Gentleman, May 29, 2006
  5. It just depends on the number of plates and how they are connected
    together. You could easily build a battery with manageable weight and size
    by just putting a lot more plates in it, making them thinner, and connecting
    them
    in parallel.
    The local battery dealer I purchase batteries from has a few old-timey
    wet cell batteries in his display case that use glass jars and ceramic tops
    and they are definitely constructed with solid lead plates.
    I think I thought you were older than you really are, though. :)
    You cannot boil away the chemicals in the electrolyte, only the water.
    All of the motorcycle wet cells that I've bought that came with a separate
    plastic bottle with premixed electrolyte had instruction manuals that said
    the same thing, but only after the initial charge, if the level had gone
    down.
    They seem to put a little extra electrolyte in the bottle for this reason.
    Years ago I worked one summer in a hot tank galvanizing plant, dipping large
    steel beams into molten zinc. The plant had a large heated sulphuric acid
    tank
    that you would dip the steel beams into and let them sit in it until all the
    rust
    had been eaten off the beams, then you would raise the beams, move them
    to a water tank, dip them in that, then raise them again and move them to
    a flux tank, dip them in that, then raise them and dip them into the zinc.
    There was an old fart that worked there who had worked at galvanizing
    operations for years, and he used to dip up a little sulphuric acid and
    clean out his pipe with it every once in a while. Quite a character.
    The acid tank was a real riot though, everthing around it, steel, concrete,
    you name it, was eaten away from the acid fumes. One time the overhead
    sprinker system broke and dumped a thousand gallons of water down on
    the zinc tank over the weekend because of fumes from that tank eating
    up the sprinker pipes. (the damn fool building codes mandated a sprinker
    system in a building that was only steel and concrete and contained no wood
    or anything burnable, with a 800 degree molten zinc tank in it if you can
    believe it) When they built that building they started out with overhead
    electric
    cranes and the acid fumes ate up the conductors, so the cranes would stop
    working right over the acid tank. Later on they used compressed air cranes
    and the acid fumes ate up the steel channel the cranes traveled in so the
    cranes
    would stick and be hard to pull along the channel.
    Of course, if they lost a part in the acid tank, and didn't manage to fish
    it out
    pretty quickly, it disappeared. Parts lost in the zinc tank didn't do this,
    but
    over time they would get soft and deform.
    When we dipped parts in the tank we would hide behind a shield, and
    you would see the tank spattering molten zinc all over the place. If a part
    had a void in it that the water didn't properly drain from, every once in a
    while
    you would get a steam explosion in the zinc tank and a fountain of molten
    zinc would erupt from the submerged part in the tank.
    You could have melted them down and poured yourself some ingots I
    suppose. Of course these days you can get as much lead as you want
    just go to a tire place and they have buckets of old lead weights. The
    cost to haul it is more than the value of the lead, and they aren't allowed
    to toss it into the trash since it's haz mat. Fishermen and Black Powder
    hobbysts often get lead this way.
    There is an interesting story in the biography of Thomas Edison. One day
    when he was a young 20 something pup, he came across a stack of used
    up Gould batteries that were being just thrown away from the telegraph
    company. The telegraph company didn't realize that the batteries contained
    platiinum anodes, but Edison did, and he carted off all of the batteries and
    removed the platinum from them. Rather than selling it, Edison saved it
    for his own use and later on for the use of his company Edison Labs. That
    stash ended up lasting him for the rest of his life, and saved him untold
    thousands of dollars years later.
    Ted
    Ted Mittelstaedt, May 30, 2006
  6. MonkeyBoy
    FB Guest
    We aren't into designing and building batteries here, we're trying to
    educate less knowledgeable motorcyclists about the care and feeding of
    the humble plastic cube directly below their ass.
    We had a large glass cell 240 volt station battery to supply emergency
    power to a large bulk power receiving station where I worked. We got
    power at 500KV and 230KV and transformed it down to 34.5 KV. Since my
    duties did not involve servicing the batteries, I only looked into the
    battery room about twice in all the time I worked there. Each glass
    cell was as big as a 2-drawer filing cabinet.
    Another operator was asking the battery guy about why the electrolyte
    in the cells had a lower specific gravity. The battery dude replied
    that stationary batteries had some much plate area they didn't need a
    stronger electrolyte mix.
    I'm older than a Baby Boomer, but that doesn't make me senile.
    FB, May 30, 2006
