GPZ UK vs import
Discussion in 'UK Motorcycles' started by Niv, Oct 27, 2003.
  1. Niv
    Sean Doherty Guest
    So does jacket icing. I had a nice thick ish coat of ice on my jacket
    after my ride this morning.
    Sean Doherty, Oct 28, 2003
  2. Niv
    jsp Guest
    Blame it on the fact that I have some flu bug ATM, shivvers and all.
    I know it was water crystals wot did it.
    I have jelly for brains.
    Ty.
    John
    SV650
    Black it is
    and naked
    jsp, Oct 28, 2003
  3. Niv
    jsp Guest
    No, I didn't, I just have jelly for brains today and shouldn't be
    posting - see reply to Pip.
    I knew that really.
    I knew that too. It was a real bugger on the KH125 I had for a while,
    and just as yousay, it was worst on not quite icy mornings. ****, that
    bike annoyed me. It cut out in the cold, cut out in the rain and
    especially cut out when I was miles from home.
    John
    SV650
    Black it is
    and naked
    jsp, Oct 28, 2003
  4. Niv
    Steve P Guest
    No you won't be able to sell it. Buy mine instead!
    Nothing wrong with em! Well aside from being chick wheels :)
    Steve P, Oct 28, 2003
  5. Niv
    Niv Guest
    Perhaps I'll meet some chicks wanting it then, (hoping).
    Niv, Oct 28, 2003
  6. Niv
    Simian Guest
    Champ :
    Ah, just the chap.
    While we're on carbs, my flatslides have the same carb heating[1] via
    coolant as the CVs do, (a) do yours? (b) is it really worth the extra
    pipework to plumb it in?
    Presumably my first thought "try it without and see what happens" is
    safe enough anyway.
    [1] well, they've got holes where the coolant connectors go on the CVs.
    I'm assuming it's actually possible to fit them, as I haven't tried.
    Simian, Oct 28, 2003
  7. Niv
    pete boyall Guest
    That's how they usually work on aircraft. It's why you shouldn't use
    carb heat on a grass strip if you can avoid it - unfiltered air..
    pete boyall, Oct 28, 2003
  8. Niv
    Simian Guest
    Champ :
    ZX7RR carbs, new, unused, fresh out of the wrapping, including import
    duty and vat and postage 500 quid.
    Don't fit the standard airbox as such, but with a couple of
    modifications (to the airbox) they'll be fine. They have the float bowl
    pressurisation tubes fitted, so I don't need the all encompassing box,
    I'll just plumb them in to the front away from the bell mouths and
    probably add some damping (al la carb tune kits) too.
    Don't worry about it, I'll follow my plan and see how it goes. Plus,
    it's going to be January before I finish it at this rate...
  9. Niv
    Coolio.
    Where did you find them? I'm after a close ratio gearbox...
    Champ, Oct 29, 2003
  10. Niv
    Simian Guest
    Champ :
    US ebay.
    Simian, Oct 29, 2003
