GPz 750 Pt 3..She runs...
Discussion in 'UK Motorcycles' started by Don, Nov 13, 2005.
  1. Don
    Don Guest
    Sort of. So carbs were taken off yet again, and this time were stripped
    right back. Removed brass tube that main jet screws into (once Id ret the
    HBOL and discovered I didnt need a punch to do so), to find on two of the
    four carbs that it was ganked up, and the little holes blocked. So, that
    little problem being solved, carbs back on bike and a quick squirt of easy
    start and the thing fires into life. Superb!
    Now the glitch is that whilst it will rev, on releasing the throttle, the
    revs take a second or two to drop back down, and then its a little stuttery
    for a second or two (sounds like its getting ready to stall, but doesnt),
    and then ticks over.
    So where should I be looking next? The needle slides seem to be freely
    moving up and down in the carb, but whereas Ive taken apart the odd single
    cylinder carb before, these diaphragm carbs are a bit of an unknown
    territory for me..
    Where should I look next people?...
    Don, Nov 13, 2005
  2. Using the patented Mavis Beacon "Hunt&Peck" Technique, Don
    Erm... How? How was that little problem solved?
    Wicked Uncle Nigel, Nov 13, 2005
  3. Don
    Don Guest
    Very carefully with a can of carb cleaner and a single "hair" from a wire
    brush. And a tiny piece of plastic. Hair used to poke most of crap out,
    and then piece of plastic used to ream out hole (used plastic so didnt
    damage the brass..)
    Don, Nov 13, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Don
    Hmm... Not A Good Idea IMHO.
    An air line is your friend in these situations.
  5. Don
    Guy Fawkes Guest
    many moons ago when I was a devil for foreign touring I ALWAYS carried
    a butane lighter filler, even though I use a zippo dipped in the tank
    to spark up, butane is absolutely ace for cleaning out carbs and oil
    lines, portable air line, and the propellant evaporates, even shrinks
    things temporarily if you have problems.
    Guy Fawkes, Nov 14, 2005
  6. Don
    Don Guest
    Well, an air line was indeed used, but the state these were in, just
    compressed air wasnt going to move it. Some of the gunk was just nasty
    black stuff, but some was verdigris type green stuff, whic wasnt going to
    shift without persuasion....
    I was *very* careful though...
    Don, Nov 14, 2005
  7. Don
    On 13 Nov 2005 16:08:33 -0800, "Guy Fawkes"
    <snip bollocks>
    Where's your attributions, ****?
    Pip, Nov 14, 2005
