GPX250R year differences
Discussion in 'Australian Motorcycles' started by BT Humble, Nov 17, 2003.
  1. BT Humble
    I'll have a go, but of course this is all to the best of my knowledge.
    I've been told that the first models imported to Australia in '88 were
    GPX250R-II. These were generally in the familiar black/red colour
    scheme, with two front disks and flush-mounted front indicators[1].
    The orange indicator lenses on either side of the tail light were
    replaced with red lenses, and "outrigger" rear indicators fitted in
    order to pass ADR's[2].
    Grey-import GPX250R-II bikes will usually have both outrigger and
    tail-mounted indicators fitted, like this:
    http://www.motorcycledisposals.com.au/158R G14.jpg
    Grey-import bikes also seem to have a higher gearing internally, since
    when on standard sprockets and tyres The Jackal runs about 1000rpm
    faster at 100kph than nameless Boy. I suspect that's due to the 80kph
    Japanese national speed limit. The igniter box on my '88 is totally
    different to Minx's '94, and doesn't incorporate a rev limiter. Grey
    imports have a different rear mudguard, and don't have that "pope's
    nose" numberplate light.
    Sometime around '92 the handlebar switchgear was changed, and the
    ability to switch the headlight on and off was removed. The parking
    light was also deleted from the headlight housing.
    So far as I know up until about 2001 the only changes were the colour
    scheme. Christian's 2002 model has carburettor de-icing plumbing,
    which probably comes in handy down in Cooma. ;-) I vaguely remember
    reading something about a K-TRIC throttle position sensor on some of
    the newer ones[3], but I've never actually seen it.
    I've heard that the ZZR250 engine is the same internally as the GPX250
    one, but has a different sump fitted. I haven't closely examined a
    GPX and a ZZR to find out. I always thought that the GPZ250R motor
    was the same as the GPX250R one, but while I was scanning the manual I
    discovered that in fact it's substantially different internally, as
    well as having larger carbies and presumably different cams.[4]
    For what it's worth, if I were customising a GPX250 to suit myself I'd
    have an '88 GPX250R-II, with the wheels repainted to match a
    current-model blue fairing. With slightly longer preload spacers in
    the front forks and a GPz500 rear shock. And the newer switchgear,
    it's nicer to use. ;-)
    [1] The same as those fitted to the GPX600R.
    [2] Apparently the standard tail-mounted indicators are 40mm too close
    together.
    [3] Which is used as a sensor input to the igniter box, and apparently
    improves throttle response and emissions.
    [4] The GPZ250 was supposed to have slightly more power and slightly
    less torque than the GPX250, but in practice I doubt that the
    difference would be noticeable.
  2. BT Humble
    Damien Guest
    Customised GPX250's? For what it's worth, I'd say you need to get out more!
    Damien
    GPX250 (stolen) -> CBR600
    Damien, Nov 17, 2003
  3. You posting from a mineshaft? Or your secret lab of doom?
    Hammo
    Hamish Alker-Jones, Nov 17, 2003
  4. BT Humble
    Dale Porter Guest
    In the U.S. customising and even racing GPX250's is very common. They have their own class.
    Dale Porter, Nov 17, 2003
  5. BT Humble
    Damien Guest
    their own class.
    ssshhhh! Don't tell him that - we'll never hear the end of it!
    Damien (writing short messages since 2003)
  6. BT Humble
    Well durr Dale, everyone knows that GPX250s have class! :-D
  7. BT Humble
    Booo! Away with him!
    (For what it's worth, I was in Adelaide on the 24-26/10 and again on
    the 1-2/11, rode to Melbourne last Wednesday, rode back to Jindabyne
    on Saturday afternoon/night, did the Brown/Clyde loop with the gang on
    Sunday, and tomorrow I'm off to Toowoomba/Tweed Heads until next
    Tuesday. I think I'm getting out enough!)
    BT Humble, Nov 18, 2003
  8. BT Humble
    Yep; they used to put "special-kids" in their own classes too.
    Clem
    Knobdoodle, Nov 18, 2003
  9. As long as you know that [1] Big Arsed Terrorists have a very short life
    expectancy, unless they have the right passport.
    Hammo
    BTW, who polishes your pole? Oh commissioner!!
    Hamish Alker-Jones, Nov 20, 2003
  10. Nah, I only know that drugs are baaad, m'kay.
    Hammo
    Hamish Alker-Jones, Nov 21, 2003
