GPS (iPAQ and TomTom)
Discussion in 'UK Motorcycles' started by David Mahon, Oct 29, 2005.
  1. David Mahon
    David Mahon Guest
    I've got an iPAQ 4150 with TomTom Navigator 5 software and a bluetooth
    GPS unit that I use in the car. Since I've already got the expensive
    hardware, seems stupid not to consider fitting it to a bike.
    Has anyone fitted their PDA/GPS to their bike? If so, what did you use?
    I've done a bit of a search and found one set of products:
    http://www.ram-mount.com/products/motorcycles.htm
    http://www.ram-mount-uk.com/handlebar-mounts.htm
    They seem reasonably cheap from http://www.gpsw.co.uk/
    If I fancied riding in the wet, which I don't, you can get an otterbox
    for the system too.
    Anyone used/recommend it?
    Where can I get some cables with bare wires from to power them?
  2. David Mahon
    SteveH Guest
    I stick mine in the top (clear) pocket of my tank bag.
    All depends on what bike you have - tubular bars make mounting dead
    easy, it's a bit harder with clip-on type bars, though
    GPSW sell cables that hook your iPaq up to a fag lighter socket. Just
    wire one of those straight to the battery (remember to use an inline
    fuse) and put the socket either under the seat or drill a hole in a
    fairing panel and mount it there.
    SteveH, Oct 29, 2005
  3. David Mahon
    David Mahon Guest
    Yes please (SV650S is on my list of bikes to consider).
  4. David Mahon
    Christofire Guest
    What's all this jibber-jabber about vibrations damaging the PDA? Do
    you need a bit of foam to sit the PDA on?
    I must admit that if it's too much hassle I'll not use it after a week,
    and I'm already looking for ways to make my car mount easier to use.
    Christofire, Oct 29, 2005
  5. David Mahon
    SteveH Guest
    I've not had a problem with it. Although I rarely use mine directly in
    the map pocket thing on top of the tank. It's usually cushioned from
    vibration by the tank bag.
  6. I have my tom tom 5 on my hp2210 attatched to my r1 with a holder then
    attached to the bike with cable ties that you cant see. My sat receiver is
    in the tail of the bike which is all part of a tracking system I got from
    Samtrac. If you send me your email add ill send you some pics. Works
    fantastic and is very tidy and easy to take the ipaq off.
    Chris
    Chris Bedford, Oct 29, 2005
  7. David Mahon
    David Mahon Guest
    Email address used in this post should work fine.
  8. David Mahon
    Steve Parry Guest
    David Mahon fumbled, fiddled and fingered:
    I've used my similarly equipped pocket pc in my tank bag with an
    earpiece and it works well.
    However, I now use my phone with headset and it works just as well but
    is neater.
    http://www.gwynfryn.co.uk/images/f650gps-a.jpg
    http://www.gwynfryn.co.uk/images/f650gps-b.jpg
    Steve Parry
    K100RS SE & F650
    (not forgetting the SK90PY)
    Steve Parry, Oct 29, 2005
  9. Sent to let me know what you think.
    Hope you get them
    Chris
    Chris Bedford, Oct 30, 2005
  10. David Mahon
    David Mahon Guest
    Arrived. Just having a look.
    David Mahon, Oct 30, 2005
