Got me virago now, anyone wanna buy a textile jacket?
Discussion in 'UK Motorcycles' started by CampinGazz, Aug 4, 2004.
  1. CampinGazz
    tallbloke Guest
    Heh, the options for pratting about with the original exhaust are a bit
    limited. For a start one of the silencers is a dummy, and you'll have
    lots of fun rejetting the carb if you mess with the back pressure. Paint
    diesel onto the collector box regularly as they rot like **** and are
    pricey...
    I'll swap you a decent leather for your jacket, where are you?
    tallbloke, Aug 4, 2004
  2. CampinGazz
    Linger Guest
    Is that the one where you wear chaps and touch your toes?
    Linger, Aug 4, 2004
  3. CampinGazz
    CampinGazz Guest
    'cos i like being a noisey anoying **** :)
    Seiorousely they're prolly just fine as they are, i'd have just liked a bit
    more of a deep sound without having to buy a harley,
    Thanks to everyone who has given advise, duly noted, learn to ride smoother,
    i am trying, need to try harder, guess a bit more than 250 miles on a
    schools racer style bike, then 130 miles on a virago isn't enough to get
    used to large engined bikes.. large compared to what i've ridden before.
  4. CampinGazz
    ... and then wear some more chaps, obviously.
    Pip, Aug 4, 2004
  5. Keelworm wrote
    You don't have to fucking imagine anything, you just get on and fucking
    do it. Smooth riding is not controlled by your imagination. That is
    far too limited, especially in your case.
    steve auvache, Aug 4, 2004
  6. CampinGazz
    I'd respectfully suggest that you catchee monkey softly, Gazzhoppa.
    Get some miles in on your bike. Wash it, polish it, bond with it.
    Get out on your own and find out what you can do and what the bike can
    do ... then start thinking about modding it to your taste, once you
    are intimately conversant with it as standard.
    Give yourself a baseline, like.
    The school bike won't have been a "racer" style. School bikes are
    comfy, uprightish affairs, easy for newbies to ride. Race reps seat
    you with all your weight on your wrists, arse up in the air, feet up
    behind your knees - with your upper body spread across the tank like a
    squashed frog and your chin on the filler.
    There are some tips somewhere for taking a pillion; written by
    Christofire I believe. Look here:
    http://www.google.com/groups?q=&rnum=10
    There's a lot of people here with years of experience taking pillions,
    hopefully they will contribute. Ace already has, but perhaps Salad
    Dodger, Colin Irvine, Stritchy, Tuppy, Mike Buckley, Owen or Badger
    may add some tips. I'll give them something to disagree with, eh?
    Smoothness really is the key, not just with a pillion, but riding a
    bike in general. If you are smooth, you don't stress your engine,
    gearbox, brakes or contact patches. Neither will you stress yourself
    or your precious cargo. Particularly with a cruiser, use your rear
    brake rather than the front to bleed speed off and when coming to a
    halt. You want to avoid fork dive, which rattles your passenger
    forward as the bike tips forward, adding to the deceleration forces.
    As Ace says, roll off the throttle a fraction before you change up,
    minimising the jerk as drive is lost and regained. Have your foot
    under the lever, pressing upwards and it should just snick in as you
    ease the throttle - or a whiff of clutch will enable a smooth change.
    Balance revs to road speed before a downchange, ease the clutch in and
    snick down one and she shouldn't even feel it - the revs rise by a
    thousand or so, but that's it.
    Plan ahead - anticipate like ****. As a recently-qualified rider, you
    are in the unhappy position of having too much to do and not enough
    time to do it, right? Planning ahead makes it easier. Try to make
    time for yourself as well as space for yourself. As you get the miles
    in, a lot of what you feel you have to concentrate on at the moment
    will become automatic, giving you more time to deal with riding faster
    and thinking about other stuff.
    Your pillion will need practice too, but she should just sit there
    atm, "like a sack of spuds", leaning as the bike does but remaining
    perpendicular to her seat. As she feels deceleration, she can brace
    and lean back - conversely for acceleration - but this is when lids
    may clash. Use higher gears and try not to have to change too often
    initially would be my advice.
    A bit of communication with the pillion is good - you should come up
    with a drill, a set sequence for getting on and off the bike and
    letting each other know when you are settled without having to yell at
    each other. A tap on the knee before you crack it open is a good
    example of signals when moving - as is you rolling off your seat and
    down the road when you know you aren't going to make the bend. A
    brief cheery wave of farewell is good form on these occasions, so that
    she knows she is on her own ...
    Relax, get the miles in and get smooth.
    Pip, Aug 4, 2004
  7. CampinGazz
    Missing apostrophe there, methinks...
    Ace, Aug 4, 2004
  8. CampinGazz
    ... and then wear some more chaps' old chaps ...
    Is that better?
    Pip, Aug 4, 2004
  9. CampinGazz
    prawn Guest
    <snip excellent advice>
    As Pip says, smoothness is the key. I've done <counts> 18 years of
    riding with SWMBO as pillion. All I can think of to add is:
    1) Always get on the bike first and off last :)
    2) After *lots* of joint experience on a familiar bike, your pillion
    will get used to when you change up through the box and, after some
    time, you can be a *little* less smooth when getting away. However,
    braking, cornering should always be done smoothly.
    prawn, Aug 4, 2004
  10. CampinGazz
    Yupp.
    Ace, Aug 4, 2004
  11. CampinGazz
    HooDooWitch Guest
    Wot Ace says, but in heavy traffic on the MWay it can be a little
    un-nerving, especially given your evident experience. Put a stop to
    it, early. SWMBO had never really been on a bike before I took her on
    mine. She went from "hunched up grip of terror" to "where's my fucking
    tissue" wriggling pretty rapidly. ...
    .... she's now so well trained she just sits neutral. I have to keep
    lifting my left hand to check in the mirror[1] that she's still there.
    Of course, the slight tug on the autocom lead would also be a clue.
    <some really sensible stuff snipped>
    [1] She rides[2] with RH on the grab rail and left hand resting round
    my waist.
    [2] Obviously not this year, given her pregnancy.
    HooDooWitch, Aug 4, 2004
  12. CampinGazz
    Lady Nina Guest
    Porl, are you feeling all right?
    You really aren't well are you?
    <cancels medical appointment> That's better.
    Lady Nina, Aug 4, 2004
  13. CampinGazz
    So people have time to safely pull over and park, maybe have a roast
    dinner or two, or even build a replica Spitfire or three before your
    Virago goes past?
    Muck, Aug 4, 2004
  14. CampinGazz
    Lady Nina Guest
    Agreed, though substitute daughter for wife. It was the smoothest I've
    ever been and if I'm being a bit hasty I just imagine she is on the
    back and everything smooths out.
    Pre warmed these Avons?
  15. CampinGazz
    Hairy Arse Guest
    Wot kind of decent leather jacket mate?? i'm after a retro/cruiser kinda
    type, tassles are optional :)
    I guess something with armour in it, back protector is a must as my back is
    fucked as it is, don't want to finish it off if the worst happens,
    I still havent looked what size my jacket is yet, it's either large of extra
    large.. i'm not a fat bloater, but not slim either,
    trouser size is 36 to 38 (changes weekly due to having colitis) but i really
    don't have a clue of my chest size.. breast size is prolly 36b tho :)
    Anyhoo, i'm in Grantham, lincs, but going to matlock bath this weekend most
    likely, then up the A1 towards scotland in the next few weeks, (eventually
    making it to jon o groats, but going in the motorhome with the bike on the
    trailer.. when i've made it that is)
    RE: the exhausts.. both my pipes are real ones, tho the top one does look to
    not get all of the gasses, they are yamaha ones, the slash cut type,
    Just inside the slash bit is a closing plate with a pipe exiting with a
    slight curve.
    Prolly an inch in diamiter, i was thinking of making that larger, but then
    it'd be obviouse what i'd done.
    I know there's a place that modify's the drag star stock pipes to make em
    louder, but not the XV ones, if i could find out exactly what they do, i
    could do the same,
    Some have said to just drill a few holes in the collector box, don't think i
    will tho.
    Duly noted the paint the bugger with diesel bit, i imagine it's there as a
    balance box, and i'd deffo need a re-jet if i were to remove the collector
    box and weld on some pipes to make the headers mate with the end pipes
    directly???
    Hairy Arse, Aug 4, 2004
  16. CampinGazz
    tallbloke Guest
    Have a spare lancer style jacket but no armour or tassles. Buy new and
    have done with it.
    Yep. You will lose performance if you bugger about with the standard
    setup. You might gain some noise or a couple of mph at the top end, but
    at the expense of a whopping flatspot somewhere in the rev range.
    tallbloke, Aug 7, 2004
