Got Fuel Gauge Wires out of 2002 Lowrider Gas Tank
Discussion in 'Motorbike Technical Discussion' started by Manjo, Aug 16, 2012.
  1. Manjo
    Manjo Guest
    My thaks for the two gas tank schematics. They were right on.
    Turns out the wires run down through a tube in the gas tank that keeps the wires from getting soked in gas.
    I pulled the wires out the bottom.
    I'm now trying to pull the two pins (12 V and grd) out of the AMP MULTITECH 2-pin connector using the directions in the Lowrider HD manual.
    I can't seem to free either pin using the manual's directions.
    Anyone done this? Is there a write-up or some guide as to how to free the two pins? I need to replace the old chewed-up wires with new ones.
    THanks,
    Manjo
    Manjo, Aug 16, 2012
  2. Manjo
    Jeff Guest
    http://mael.rivoal.free.fr/Manuel Buell XB9R/sm_appb1.pdf
    Basically you stick a small tool into the connector alongside the terminal to
    depress the tang to unlock it and hold it there while pulling out the wire.
    Jeff, Aug 18, 2012
