Got a bike, tape measure, & a spare 10 minutes?
Discussion in 'UK Motorcycles' started by Preston Kemp, Jan 17, 2005.
  1. Preston Kemp
    Preston Kemp Guest
    If so, help! My Fantic has currently got a K&N cone filter in the
    airbox connected to the carb with a Ford Escort steering gaitor. This
    is obviously far from ideal for *so* many reasons.
    The original carb-to-airbox boot is long gone, & I haven't got a chance
    in hell of getting an original one. In fact as it's a Hiro 250 engine
    in a Fantic RC125 frame, I don't even know what it would've had
    originally. So I need to find one off another bike that's close enough
    to modify. The dimensions are:
    Carb mouth outside diameter - 63mm
    - This needs to be very close, or maybe a bit larger.
    Airbox hole - 85mm
    - I can increase/decrease this without too much problem.
    Top of airbox hole to top edge of carb mouth - 41mm
    Bottom of airbox hole to bottom edge of carb mouth - 62mm
    - These need to be pretty close - longer's ok but shorter
    probably isn't. The measurements are just to the end of
    the carb i.e. they don't include the bit of the boot that slides
    over the carb inlet. So the total length needs to
    be at least 15mm longer than the above measurements.
    Vertical offset - 0 (i.e. the carb is level with the airbox hole when
    viewed from the side).
    Horizontal offset - 15mm (when you look down from the top, the
    centreline of the carb is approx. 15mm to the left of the centre of the
    airbox hole - so the boot needs to have a kink/bend).
    - It would be nice to get close to these offsets, but I can
    fibreglass over the airbox hole & cut a new one if I have
    to.
    If anyone can spare the time to measure up their bike, it would be
    hugely appreciated. Beer & curry vouchers to anyone who says "SNAP".
  2. Preston Kemp
    Robbo Guest
    Have a word with your local hydraulic hose supplier....Someone like Pirtek.
    A cut-off of convoluted hose might do the trick....
    Robbo
    Trophy 1200 1998
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Jan 17, 2005
  3. Preston Kemp
    tallbloke Guest
    Sounds like you need some 2 1/2" bore tube. Pretty standard stuff, try a
    commercial vehicle scrapyard. Take a hacksaw.
    tallbloke, Jan 17, 2005
  4. Preston Kemp
    JB Guest
    I used a couple of pieces of radiator hose (van or light truck ISTR) from an
    auto factors 'stuff I don't know what vehicle it comes from & I'm never
    going to sell' bin. Ask 'em if you can take a look through their old hoses.
    The ones I got for the Guzzi are approx 65mm ID at one end and have a flare
    out to ~85mm at the other. They were about 300-350mm long when I found them,
    but had to cut them down to about 100mm long so I could get the 38mm
    Dellorto PHM38s on the old Spada.
    JB
    JB, Jan 17, 2005
  5. Preston Kemp
    Preston Kemp Guest
    Do proper old-style scrapyards exist anymore? All the ones I know of
    round here are boxed & shelved parts only - no rummaging round like the
    good old days.
    Preston Kemp, Jan 20, 2005
  6. Preston Kemp
    Preston Kemp Guest
    I've tried the local ones (that I know of) without any luck. Time to
    fire up yell.co.uk methinks.
  7. Preston Kemp
    Pease Pottage, Nr. Crawley.
    sweller, Jan 20, 2005
