GoldWing wiggling.
Discussion in 'UK Motorcycles' started by Salad Dodger, Oct 11, 2004.
  1. Salad Dodger
    tallbloke Guest
    Not on a hardened bearing centre it don't. FOAD torch and stilson turned it
    in the end.
    tallbloke, Oct 22, 2004
  2. Salad Dodger
    tallbloke says...
    Not even with a grinding wheel attachment? I bought my Dremel
    specifically to remove stuck head bearings from steering stems.
    Well, I would have thought it would.
    Lozzo, Oct 22, 2004
  3. Salad Dodger
    Salad Dodger Guest
    Well, cutting a slice in mine worked just fine - and that was with the
    weedy little cordless one.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    Salad Dodger, Oct 22, 2004
  4. Salad Dodger
    tallbloke Guest
    It'd've taken too long to grind it off. It had an extra thick inner to
    accomodate the slender steering spindle.
    None shall resist the mighty 2 foot stilson.
  5. Salad Dodger
    tallbloke Guest
    Ooh. toys :)
  6. Salad Dodger
    Salad Dodger Guest
    Further reading[1] suggests unclipping the wiring loom from the frame,
    then re-attaching it.
    Obvious, really innit?
    {1} Yes, I know.
    | ___ Salad Dodger
  7. Right. Skin cuts easily.
    The Older Gentleman, Oct 22, 2004
  8. Salad Dodger
    Bah. You have a Dremel now, right?
    Pip, Oct 22, 2004
  9. Salad Dodger
    I was going suggest that it must surely be possible to removed one of
    the "fixed" ends. Would it be too much of an assumption to guess that
    one end goes the LHS switch gear?
    Champ, Oct 22, 2004
  10. "This is a Honda Recorded Message. That part is only available to
    Japanese Honda dealers of 50 years standing that have a chief engineer
    called Scotty. And can moonwalk after 5 bottles of whisky. And have
    those embarassing pictures of the CEO.."
    Phil
    Phil Launchbury, Oct 22, 2004
  11. Salad Dodger
    Salad Dodger Guest
    Hooray!
    | ___ Salad Dodger
    Salad Dodger, Oct 23, 2004
  12. Salad Dodger
    It'll fall off and chafe through in days. Mark my words.
    Pip, Oct 23, 2004
