GoldWing wiggling.
Discussion in 'UK Motorcycles' started by Salad Dodger, Oct 11, 2004.
  1. Salad Dodger
    Salad Dodger Guest
    As noted at the EOSM.
    Shock-absorber related, I reckon.
    It only occurs below 10mph, when the shocks extend on acceleration.
    The left one is an oil/spring jobbie, and I reckon it's fecked, after
    73k miles. Especially considering the punishment it's been given.
    The right, of course, is an air shock. Pumping it to 70 psi alleviates
    the problem; but that's 30psi over limit, and transforms the wing into
    a hardtail. Not an ideal solution.
    I've decided on a set of Progressives, but no U.K. retailer sells the
    air pipes and T-piece, it seems. Currently in comms with the importer.
    Looks promising.
    As for the shaft-drive footrest wobble, today's testing revealed that
    it only manifests it self when decelerating from >75mph. Below that,
    nothing. Odd. I shall inspect the arse-end when the shocks go in,
    anyway.
    Next weekend is front fork overhaul time, assuming I can pick up a
    trolley jack, from either Machine Mart, or Halfords.
    Final question: would it be worth changing the head bearings anyway,
    as I'd already have the front to bits?
    | ___ Salad Dodger
    |_\_____/_| ..73063../..16589.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
    '^' RBR-Visited:83 Pts:1800 Miles:6890
  2. Salad Dodger
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10460&item=7927332265&rd=1
    Looks like a pair of air shocks.
    platypus, Oct 11, 2004
  3. Salad Dodger
    Salad Dodger Guest
    I want to have your babies.
    <mwah>
    Adds to watch-list.
    | ___ Salad Dodger
  4. Worth checking and double-checking the throttle synch too. With all
    the throttles closed, if one of them isn't quite and the engine is on
    the overrun perhaps it's that that's causing the vibes?
    Vlad the Inhaler., Oct 11, 2004
  5. Yes, absolutely.
    The Older Gentleman, Oct 11, 2004
  6. Salad Dodger
    <takes coward's way out> *bang*
  7. Salad Dodger
    Robbo Guest
    Sir might like to talk to
    Goldwingsunthings' run by wingers for wingers,on 01793 829777, 07944 007376,
    07958 379972
    also chat to John or Alan at Fiveways Bearings up near Fiveways at Eltham,
    http://www.fiveways-bearings.co.uk/
    0208 857 5208
    Head bearings are taper roller jobbies. I seem to remember paying around a
    tenner for them. But then I was a trade customer so to speak.
    Robbo
    Trophy 1200 (HEHEHEH..IT'S MINE!)
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    FURSWB#1 KotL..YTC449
    PM#7
    Robbo, Oct 11, 2004
  8. Salad Dodger
    Zymurgy Guest
    Salad Dodger wrote
    Eep. You take that thing (wing) to 75 MPH :-0
    Scared the shit out of me at 50 ;-)
    Paul.
    Zymurgy, Oct 11, 2004
  9. Salad Dodger
    Robbo Guest
    Can't remember the numbers but you'll be taking them out anyway and there
    will be numbers on the races so he'll be able to match them for you. If not
    in stock it's usually only a day wait anyway.
    Robbo
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    PM#7
    Robbo, Oct 11, 2004
  10. You must have cleaner pants that me, then.
    I cacked out at 40!
    Whinging Courier, Oct 11, 2004
  11. Salad Dodger
    Salad Dodger Guest
    Does this sound like the kind of thing I need?
    SSH-903 - 26 x 47 x 15 - 30 x 55 x 17
    | ___ Salad Dodger
  12. Salad Dodger
    No, that's your tyres.
  13. Salad Dodger
    Robbo Guest
    Sounds good.
    Ask at Fiveways and see what they got
    Robbo
    Trophy 1200 1998
    BMW K100 RS 1984
    B.O.S.M 2003, 2004
    PM#7
    Robbo, Oct 12, 2004
  14. Salad Dodger
    Salad Dodger Guest
    Yes, absolutely.[/QUOTE]
    <saves post, ready to carve it onto TOG's forehead with a Stanley
    knife>
    | ___ Salad Dodger
    Salad Dodger, Oct 22, 2004
  15. Salad Dodger
    Nigel Eaton Guest
    Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    Oh come on! It's not like it's a difficult job.
    Nigel Eaton, Oct 22, 2004
  16. Salad Dodger
    tallbloke Guest
    <remembers removing lower steering head bearing inner from rickman
    steering stem with much heat, cursing and chisels>
    Hmmmmm.
    tallbloke, Oct 22, 2004
  17. Salad Dodger
    Salad Dodger Guest
    It's done now.
    With the very slight exception of re-routing the self-cancelling
    switch loom down the headstock.
    Imagine the scene:
    You have a headstock, say 10" long.
    You have two pieces of wire, each 5.25" long with a connector block on
    the end. The other ends are fixed.
    Your mission, should you choose to accept it, is to connect the pair
    of them.
    | ___ Salad Dodger
  18. Salad Dodger
    tallbloke says...
    Dremel, YKIMS
    Lozzo, Oct 22, 2004
  19. Salad Dodger
    Nigel Eaton Guest
    Boo! if you're not going to bite, I'm not wasting any more of this high
    quality bait.
    Honda special tool #45633223-659956-54860456(B). Easy.
  20. Salad Dodger wrote
    <waves perfectly formed little fingers>
    Need a 'and guvner?
    steve auvache, Oct 22, 2004
