GoldWing fettling update #237 - nearly there.
Discussion in 'UK Motorcycles' started by Salad Dodger, Dec 12, 2004.
  1. Salad Dodger
    Salad Dodger Guest
    Apologies in advance - only one "oh, for ****'s sake!" moment included
    this week.
    Decided to re-fit he CD changer, having successfully relocated the
    slidy-door thing on the top. Simple enough, and the control panel,
    having been thoroughly cleaned inside and out, was re-velcroed to the
    fairing side.
    Then decided to fit the heated grips. Daytonas, they are. Dunno if
    they're any good, or not.
    Old grips off easily enough - wiv a knife. Sorted out all the
    wiring[1], via my UberGay chrome switch box, and the then slid the
    grip onto the bars. They're about 1cm shorter than the grips I've
    taken off.
    "O,FFS!"
    Bollocks to it, it'll have to do[2]. Can't put the originals back on,
    that's for sure.
    Also fitted the "Rings of Fire" to the disc covers. That Dremel-o-like
    from Machine Mart is proving to be worth its weight in gold. Flexible
    extensions for drills are the business. Disc covers to go on when
    wiring completed.
    Herself then pointed out that we were out of milk, so, for a laugh, I
    attempted to kick the KH into life. It started second kick, so I spent
    the next 40 minutes getting a carton of milk, the "long way round".[3]
    Top fun, and it even idled properly on my return. The front brake is
    utterly dreadful, though, even worse than I remembered. Looking at the
    marking on the disc (a circle around 1cm wide, all the way round), I
    wouldn't be surprised to find that the pad's gone AWOL.
    It doesn't smoke much, either.
    [1] Properly, with soldering irons and everything.[4]
    [2] Until I source a pair of the right size, obviously.
    [3] I'm getting really odd urges now, having watched this several
    times, all the way through. Common sense is prevailing at the moment.
    I have no reason to suspect that it won't win, either.
    [4] When holding your soldering iron in a vice, don't lean across it
    to retrieve stuff from the other side of the work bench. That funny
    smell used to be a Hackett sweater. Arse.
    | ___ Salad Dodger
    |_\_____/_| ..73063../..17250.../..3180./.19406
    \|^|/ ANORAK#17 IbB#4
  2. That's spolied you stories a bit now - most of us always picture you
    working on the Wing wearing only a leather thong.
    Simon Atkinson, Dec 12, 2004
  3. Salad Dodger
    Salad Dodger Guest
    It was cold, okay?
    | ___ Salad Dodger
  4. Hmmmmm... As long as it was only the pully and a thong...
  5. Salad Dodger
    Klaatu Guest
    Would it be possible to have a gprs(1) phone and small lcd screen fitted inside
    the wing faring, giving you access to the net ?
    That way you could post while riding, telling us what's not fallen off.
    1. is that right ?
    Klaatu, Dec 12, 2004
  6. Salad Dodger
    Salad Dodger Guest
    Given that I can't recall anything that's fallen off[1] in the last
    eight years, I can't see it'd get much use.
    It's a GoldWing, not a fucking Harley.
    [1] Except me, obviously.
    | ___ Salad Dodger
  7. Salad Dodger
    Klaatu Guest
    I forgot it was a Honda, and they never go wrong well mine have never seemed
    to(1)
    It seems I have been caught, over the years by the brand loyalty thing: good and
    bad experiences (of bikes and cars) have embued me with a brand loyalty.
    If, and I am actually, looking at another cheapo commuter, I tend to look for
    little used Honda bikes.
    This occasionaly makes me think - why ? Why am I not checking all available
    relevent bikes ie. within, the correct price range and the corrrect locale.
    Just a couple of thought after a very bizarre evening.
    1. "It's just the little things" (that piss me off - A. Cooper)
    Klaatu, Dec 13, 2004
  8. It was somewhere around Barstow, on the edge of the desert, when the
    And a Batman leather helmet, for some reason.
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Dec 13, 2004
  9. I don't see him in that - it's what I wear to read usenet.
    Vlad the Inhaler., Dec 13, 2004
  10. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Vlad the Inhaler."
    Do you take turns with it?
    GS 850 x2 / SE 6a
