GoldWing breakdown update.
Discussion in 'UK Motorcycles' started by Salad Dodger, Sep 10, 2005.
  1. Salad Dodger
    Salad Dodger Guest
    Re-fitted a fully Optimated battery.
    Check voltage across terminals. 11.94V.
    Start engine. 11.8V
    Rev engine. 11.7V
    Turn on all the other lights, CD, etc. 11.5V
    Pull on front brake. 11.3V
    Rev engine again. 11.25V
    Now, I'm no auto-electrician, but that's not good, right?
    Where to look next? Alternator connections? I only suspect this
    because it had to be removed/refitted when the clutch was changed, and
    there's a funny "whiny" noise on the overrun, which I haven't heard
    before. There were only two connections, but both were secured by a
    10mm nut.
    | ___ Salad Dodger
    _/_____\_ GL1500SE-V/CBR1100XX-X/CBX1000Z
    |_\_____/_| ..78868.../...19540.../..30836.
    (>|_|_|<) TPPFATUICG#7 DIAABTCOD#9 YTC#4
    |__|_|__| BOTAFOT #70 BOTAFOF #09 two#11
    \|^|/ ANORAK#17 IbB#4 PM#5 WG*
    '^' RBR Clues: 29 Pts: 485 Miles: 1967
  2. Salad Dodger
    It's not charging. This is down to defective regulator, alternator or
    supply wiring.
    My money's on "expensive".
    sweller, Sep 10, 2005
  3. Salad Dodger
    dwb Guest
    How much did you rev the engine? Don't they only start charging over a
    certain RPM?
    dwb, Sep 10, 2005
  4. Using the patented Mavis Beacon "Hunt&Peck" Technique, Salad Dodger
    "Houston, we've had a problem. We've had a main B bus undervolt."
    When you say it had to be removed, do you mean just the connections, or
    the alternator itself? Have you disturbed the windings? In other words,
    is it possible that you've fucked up the clearance between the
    alternator stator and the windings?
    I'm not even sure that's possible on a 'Wing, BTW. But it might account
    for the noise and the low voltages.
    and Ducati Race Engineer.
    Wicked Uncle Nigel, Sep 10, 2005
  5. Salad Dodger
    Salad Dodger Guest
    Wiring passes all the tests detailed in ch.17pp5-7
    Regulator is *inside* the alternator.
    Investigation continues.
    Ebay has a High-Output alternator as BuyItNow item USD 490.
    I think you could be right.
    | ___ Salad Dodger
  6. Salad Dodger
    R obbo Guest
    For a start I would reasonably expect over 12.2v for a charged battery in
    good order.
    IIRC the output from the alternator should be 13.8-14.2v at/over 1500 rpm.
    Also the rear bearing on the GL 1500 alternator can wear prematurely, the
    first sign of this is when a warble/hum is heard at around 2,000 to 3,000
    rpm. If ignored damage may reach the point where the bearing spins and
    damages the alternator casing. The bearing is a NSK 6000DU, cheap as chips
    from most bearing shops.
    Check the earth at the battery and also frame and obviously the connections
    at the alternator. .
    Voltage drop across the ranges you stated shows reduced charge at the
    battery, possibly brushes on the stator sticking or need replacing. Not a
    hard job, just time consuming and fiddly. I did mine when I had the 'Wing in
    bits after the roadsign incident.
    R_O_B_B_O
    Trophy 1200 1998
    B.O.S.M 2003, 2004, 2005
    FURSWB#1 KotL..YTC449
    PM#7
    R obbo, Sep 10, 2005
  7. Salad Dodger
    Get the old one rebuilt by an alternator specialist. They can strip and
    rebuild an alternator quickly and cheaply. I had the bearings and
    brushes done on a car one for less than £20.
    Muck, Sep 10, 2005
  8. Salad Dodger
    Muck's right. I had the Guzzi starter motor rebuilt by the local auto
    electrician for £60 which was nice given an OE part is £330. Oh, and no
    it's not a Fiat item...
  9. Salad Dodger
    Salad Dodger Guest
    The alternator itself, but that was months ago, and it worked fine up
    until last Saturday.
    | ___ Salad Dodger
  10. Salad Dodger
    Salad Dodger Guest
    Engine out job to replace it, though, innit?
    Seem okay.
    Do you have to remove the four bladed coupler? The manual's a bit
    vague, but I can't see how to get the alternator apart if you don't.
    If I haven't got a "holding tool" can I stick it in a vice, and undo
    the centre nut like that?
    | ___ Salad Dodger
  11. Salad Dodger
    Salad Dodger Guest
    It's supposed to pump out 40A all the way from 2000rpm to the redline.
    That Compufire I'd spotted earlier (as had Robbo) puts out 60A at
    idle.
    1.3KW - I'd have to buy some more lights.
    | ___ Salad Dodger
  12. Salad Dodger
    Salad Dodger Guest
    I shall investigate. Ta.
    | ___ Salad Dodger
  13. Salad Dodger wrote
    What is it, 740 Watts a Horse Power?
    That is 2Hp times inefficiencies in generation being robbed from your
    motor just to keep the lights on. Disgraceful I calls it.
    steve auvache
    750 VT Shadow (something for the weekend)
    Bindit 600 (was lost and now is found)
    GS500E (small but perfectly formed)
    mongvan (dehydrated)
    steve auvache, Sep 10, 2005
  14. Salad Dodger
    Salad Dodger Guest
    http://www.zyworld.com/GoldWingProductReviews/EngineElectronics.htm
    | ___ Salad Dodger
  15. Salad Dodger
    Take the alternator unit to your local auto electrician (Yellow Pages)
    for testing/repair. It'll save a lot of heart ache amd hassle.
  16. Salad Dodger
    R obbo Guest
    Nope.
    You can get the Alternator out without removing the donkey
    Tight and clean? ( the alternator, not your wallet!)
    IIRC the brushes are the other end.
    Must admit I did have the advantage of an air nut gun. I have been able to
    hold the outer using a filter wrench before. Use a couple of bits of
    aluminium in the vice to save damaging the alternator
    R_O_B_B_O
    Trophy 1200 1998
    PM#7
  17. Salad Dodger
    Having just been there I can only agree.
    Pip Luscher, Sep 10, 2005
  18. Salad Dodger
    Salad Dodger Guest
    Sound advice, Mr W.
    <googles>
    | ___ Salad Dodger
  19. Salad Dodger
    deadmail Guest
    Often it's just the brushes that have gone (on alternators) IME but when
    you try to buy brushes you can't get them. If you're lucky you can get
    a combined regulator/brush assembly these days.
    Domestic appliance shops often have a selection of inexpensive brushes
    that can be cut to size though.
    deadmail, Sep 10, 2005
  20. Salad Dodger
    I did this to a mates tired BMW alternator. We bought some brushes that
    almost fitted from a local motor factor, then shaped them to fit and
    soldered them in.
    Muck, Sep 10, 2005
