Gold Wing brake sticks
Discussion in 'Motorbike Technical Discussion' started by DFW Dot, Feb 1, 2005.
  1. DFW Dot
    DFW Dot Guest
    1982 GW, rear brake sticks the first time I use it on a given day. If I
    persist in riding, it'll let up (or wear down enough pad) after two or three
    minutes. Then it works fine for the rest of the ride. If I park it for two
    hours, same thing happens all over again.
    What do I need to do to fix it before I run out of pad?
  2. DFW Dot
    Silicon Sam Guest
    Best thing to do is do what I did to my '83 Goldwing, which
    essentially has the same rear caliper as yours.
    Remove the rear caliper and leave the hose attached. Use a series of
    spacers and pump the fluid into the caliper until you have both pistons
    removed. You have to use the spacers so that the pistons come out at
    around the same time, and not push one out way before the other. Make
    sure you watch the fluid resevoir. Remove the seals very carefully and
    clean the caliper, clean the groove the seals came from, clean the
    seals, polish the pistons. Reinstall the seals into the caliper. Lube
    the pistons with either brake fluid or silicon grease and reassemble
    the pistons into the caliper. Clean the 2 pins that hold the pads in
    as well. Make sure all is CLEAN and pistons move freely with
    compressed air. When you put the pistons in, used some compressed air,
    installed the pads, and put pressure to the fluid connection, and see
    if the pistons tighten up to the pads, and release when you remove the
    air.
    If I was in the DFW area, I'd help, but I am in Austin.
    Raymond
    Silicon Sam, Feb 1, 2005
  3. DFW Dot
    SAMMMMM Guest
    consider the brake hoses. i've had a problem with them in the past.
    naturally, there are other possible problems. good luck, sammmm
    SAMMMMM, Feb 1, 2005
  4. If I persist in riding, it'll let up (or wear down enough pad) after
    two or three minutes. Then it works fine for the rest of the ride. If
    I park it for two hours, same thing happens all over again.
    Besides cleaning all the crud out of the caliper, check the rear brake
    pedal and any associated linkage for binding and make sure the air
    bleed hole that is in the brake fluid reservoir isn't blocked. The air
    bleed hole is tiny and it can be easily blocked by old brake fluid
    crystallizing in the hole...
    krusty kritter, Feb 1, 2005
  5. What he said - except that generally, it's not necessary to remove the
    pistons altogether and attend to the seals. If the caliper and pistons
    are seriously corroded, then yes, absolutely.
    FWIW, I've just done this job on my Trophy as the calipers were binding
    slightly. I did it exactly as you outlined, including blocking the "not
    to be attended to yet" pistons with spacers (14mm socket head!). Except
    I just moved the pistons out maybe half an inch.
    Pump the piston you're doing partially out, clean round it with a
    toothbrush, get rid of all the crap, apply a thin smear of copper
    grease, push it back, repeat. When the pistons slide back smoothly,
    job's done.
    As the pistons are frequently hollow tubes, rather than solid pillet,
    you can see how deep they are, which means you're unlikely to push them
    all the way out. Just err on the side of caution. The corrosion rarely
    goes more than a couple of millimetres down. If it does, then it's would
    be wise to do the job as Sam says.
    The Older Gentleman, Feb 1, 2005
  6. Nonsense
  7. my 1986 GL1200A, except it was the left front brake (the one not
    connected to the rear master cylinder). The master cylinder was lined
    with a semi-crystalline goo condensed from old brake fluid. With the
    fluid return hole blocked, there was nowhere for the pressure to go, so
    the caliper remained locked, nearly to the point of locking the front
    wheel.
    I learned about the blocked air bleed hole when the front brake lever
    on one of my Suzukis became very hard, and had no play whatever in it.
    The motorcycle had sat unused for about two months in hot weather and
    the brake fluid evaporated, leaving crystals to block the hole...
    How is cheap brake fluid made anyway? Out of animal fat?
    saponify: to convert (as fat) into soap; specifically : to hydrolyze (a
    fat) with alkali to form a soap and glycerol
    hydrolysis: a chemical process of decomposition involving the
    splitting of a bond and the addition of the hydrogen cation and the
    hydroxide anion of water
    glycerol:a sweet syrupy hygroscopic trihydroxy alcohol C3H8O3 usually
    obtained by the saponification of fats and used especially as a solvent
    and plasticizer
    But, what happens when the lighter fractions of the polymer boil off?
    You apparently get some sort of alkaline glycerin crystals, and
    crystals don't flow through hydraulic systems very well...
  8. DFW Dot
    Silicon Sam Guest
    I am glad I removed the pistons, because it gave me a chance to polish
    the pistons and clean the seal grooves which had accumulated a bunch of
    crud. Plus the rear caliper had about a teaspoon of crud laying in the
    resevoir behind the piston. So why not take them out and do it right?
    Raymond
  9. Depends how old the bike, how long the brakes have been crappy, how
    serious the corrosion, etc etc.
    When I did the rear brake on my old Kawasaki I did it the proper way -
    new seals, clean everything out (and yes, there was a lot of crap behind
    the piston there as well).
    On a 1982 Wing, it'd probably be a good procedure.
  10. Kawasaki I did it the proper way - new seals, clean everything out (and
    yes, there was a lot of crap behind the piston there as well).
    Besides the buildup of brake pad dust, corrosion caused by salt, rubber
    wearing off the seals, there's another problem with disk brakes that
    can cause the piston to stick. It's the uneven wear from the rear of
    the pad to the front of the pad...
    The rear of the pad gets more wear because the rotor rubs it first.
    The pad wears at a slight, but noticeable diagonal. The steel backing
    plate pushes the caliper piston inward at a very slight angle. But the
    piston is almost an interference fit in its bore, you can hardly slide
    a piston into its bore even with the seal removed...
    So the piston will stick for that reason...
    Diagonally worn brake pads can be reversed, swapping the inner pad with
    the outer pad to even out the wear if you happen to have the rear wheel
    off for any reason, it only takes a few extra minutes to do that
    operation...
  11. Now *there's* a neat tip which never occurred to me.
    Thanks.
  12. DFW Dot
    DFW Dot Guest
    Thanks to you all for your help.
    I'll let you know how it goes.
    DFW Dot, Feb 2, 2005
