God Bless Suzuki.
Discussion in 'UK Motorcycles' started by Molly, Apr 20, 2004.
  1. Molly
    Salad Dodger Guest
    As did CBR1000Fs, iirc.
    | ___ Salad Dodger
    |_\_____/_| ..64299../..15196.../..3157./.19406
    \|^|/ ANORAK#17
    '^' RBR-Visited:13 Pts: 250 Miles:1237
    Salad Dodger, Apr 20, 2004
    #61
  2. Molly
    curium Guest
    That's probably because its a top of the range bike. They want to keep
    customers like you happy plus they probably make more of a profit on
    GSXR-1000s.
    Doubt they'd be as helpful for a 600.
    curium, Apr 20, 2004
    #62
  3. Molly
    Salad Dodger Guest
    I've just dug out an old invoice -
    when the Wing was serviced, and had its first MOT
    05/04/2000 - HGB were charging £35 + VAT
    | ___ Salad Dodger
    \|^|/ ANORAK#17
    #63
  4. Molly
    Ben Guest
    Quite the opposite I'd have thought. Suzuki will sell a lot more
    small bikes than they will GSXR1000s.
    Ben, Apr 20, 2004
    #64
  5. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember Salad Dodger
    Not quite a slipper clutch, but the XS850, afair, had some sort of weird
    clangdongjoint in the gearbox which slipped if either the engine or
    gearbox seized while you were tootling along, thus reducing the
    possibility of turning into lorryburger.
    GS 850 x2 / SE 6a
    Get rid of your SOC/SOB here http://www.sparesorrepair.co.uk/
    Grimly Curmudgeon, Apr 20, 2004
    #65
  6. It was somewhere around Barstow, on the edge of the desert, when the
    "Goodwill" tends to mean they know the word-of-mouth recommendations
    will spread by whatever means - down the pub, in the bikeclubs, on the
    net, wherever. In among those who get to hear about it will be a few
    future purchasers of gixxer thous or the equivalent at the time.
    A lesson the Ducati importer (as above somewhere) obviously failed to
    learn.
    GS 850 x2 / SE 6a
    #66
  7. Molly
    antonye Guest
    Otherwise known as a "back-torque limiter" which is probably
    a better description but just not as catchy.
    As Champ says, the slipper clutch has an internal mechanism
    which, at a certain load, "breaks" away the engagement of
    the clutch and lets it slip slightly, thus stopping the force
    of the engine from driving the wheel.
    There are many different designs, the most popular and probably
    best being the "ramp & bearing". This consists of two plates
    within the main clutch unit, both with ramps built in that lay
    against each other. In between sits a ball bearing (only about
    6mm on mine) to aid in movement. As you change down through the
    box, the back-torque reaches the point at which it forces the
    two ramps apart and disengages the clutch.
    They're very common on racing twins, coming as standard on the
    homogolation specials from Ducati and Aprilia. They can cost from
    around 500 quid for a basic design through to as much as you want
    to pay for a "single central spring, 48 tooth basket, ramp and
    bearing with titanium post, lightweight action" job. STM and
    Bucci are probably the most common and highly regarded makes -
    also used by factory teams in SBK and probably MotoGP too.
    Most units just replace the standard clutch and will also lighten
    the clutch unit making pickup a bit quicker. You also get coloured
    anodized versions, but you need to make sure you use matching
    alu plates with the alu basket otherwise you get uneven wear
    between plates and basket. Obviously this is only an advantage
    if you've got a dry clutch and get a vented cover for the colour
    to show through ... if you can stand the noise!
    I got one fitted because I kept locking the rear when changing
    down going into slow corners - either on the road or on the
    track. While you can get used to the rear end fish-tailing
    about, I'm sure it looks a bit scary for other road users and
    it's probably not the fastest way round a track either. The
    slipper is noticeable as the lever feels like it's "pulsing"
    which I guess is just the slack being taken up on the ramp
    and bearings. Very weird when you first use it.
    I didn't realise the ZXR750 had them - or was that just the
    ZXR750K (aka ZXR750RR) ?
    antonye, Apr 20, 2004
    #67
  8. Molly
    Ben Blaney Guest
    Such as your good self?
    fwiw, I think all the "advice" you've given in this thread (except for
    "go to the CAB" - which is fairly elementary) has been pretty far off
    the mark.
    Ben Blaney, Apr 21, 2004
    #68
  9. Molly
    dwb Guest
    Trevor Goodall in Didcot are still at £35p/h :)
    Or should that be :(
    dwb, Apr 21, 2004
    #69
  10. Molly
    Last year Hawk Kawasaki used a Suter item, which they replaced for
    every race. At 6k a pop...
    No, they've all had it, right from the very first 1989 ZXR750H1
    Champ, Apr 21, 2004
    #70
  11. Molly
    Honda PF50 too
    sweller, Apr 21, 2004
    #71
  12. Molly
    giving the amount of fishing you've been doing, it was inevitable that
    it would happen eventually.
    darsy, Apr 21, 2004
    #72
  13. Thanks Lozzo :)
    Doesnotcompute, Apr 21, 2004
    #73
  14. Molly
    Rubbish. Top-of-the-range models are almost never major earners -
    Insurance costs etc. mean that they're a relatively small part of
    overall sales.
    Whereas they sell _shedloads_ of 600s.
    Ace, Apr 21, 2004
    #74
  15. Briefly, I was worrying about why you care what the hell the
    rear is doing if it's not carrying any of the bike's weight.
    I was imagining the following sequence:
    a) hoon towards corner
    b) brake
    c) rear carries no weight
    My immediate thought was "so?" But I had forgotten what comes next...
    d) whilst braking, throttle is almost closed,
    so rear wheel slows down (whilst not connected)
    e) brake released
    f) tipping into corner
    g) almost stationary rear starts sliding across
    fast moving tarmac, nothing to stop it sliding;
    h) low-side or high-side, depending.
    (e,f,g are simulatenous)
    And, looking again at it, this is an extreme case. I'd
    be surprised that with slipper clutch (now that I have
    a mental picture of how it works thanks to ant.e)
    would allow the rear to keep spinning mid-stoppie with
    a closed throttle. But you never rolling stoppie into a
    roundabout^W corner on a racetrack, so there *is*
    some torque on the rear on the track.
    Right. That's enough wibbling.
    Well, some (other) old codgers have mentioned some specific bikes...
    William Grainger, Apr 21, 2004
    #75
  16. So I do remember vagually correctly...
    #76
  17. [slipper clutches]
    Ah! A mental picture. Bargin.
    Oh, and I managed to get to the post office and pick up
    the parcel yesterday (distinct lack of circulating tuits)
    Scart splitter works well, can't see any shadows that are
    going to disturb me.
    Thanks again!
    #77
  18. No - I'm not a solicitor.
    I'm an ex retail manager though - hence I know a little more than the
    average idiot.
    That's your choice, but the facts are there. Warranty is bollocks. SoGA
    isn't (if a little ambiguous sometimes) bollocks. If there is a known
    issue with clutch baskets failing, then it would be a open/closed case.
    If there is an unapproved modification, then that certainly makes things
    more difficult - and it was something I was unaware of until half way
    through the thread.
    #78
  19. Molly
    A quick google shows nothing. I suspect DNC's understanding of KNOWN
    ISSUE, its relationship to sale of goods and reasonable life expectancy
    of a motor vehicle is similar to his understanding of employment law.
    #79
  20. Molly
    IME in the field of labour relations this premise has been the mother of
    many unbelievable fudges and abortions.
    Unrelated I know but, when a negotiator says this is the final offer it
    is. Its not going to get any better or have any less strings if you
    reject it.
    Unless, of course, you're prepared to put your money where your
    industrial mouth is ...
    but I digress.
    #80
