God Bless Suzuki.
Discussion in 'UK Motorcycles' started by Molly, Apr 20, 2004.
  1. Molly
    I've not actually heard of any others braking.
    Mine had a clutch mod early on cos the clutch was grabbing, and, I
    thought Molly had the same mod done around the same time.
    Champ, Apr 20, 2004
    #41
  2. Molly
    Christ. Well, I reckon an engine out, strip, rebuild and re-fit job
    should be 20 hours at most, which means 50 quid an hour, inc VAT.
    Which is a fucking lot, imo.
    Champ, Apr 20, 2004
    #42
  3. Molly
    Ben Guest
    Same problem as Sorby had with his 750 isn't it? And I've seen a few
    on the forums.
    Must get mine done.
    Ben, Apr 20, 2004
    #43
  4. Molly
    Must be that new-fangled slipper clutch like on the GP bikes.
    ogden, Apr 20, 2004
    #44
  5. What are they, anyway?
    William Grainger, Apr 20, 2004
    #45
  6. Molly
    HooDooWitch Guest
    (William Grainger) somehow managed to post:
    Comfortable, tartan clutches, used by old bikers, in conjunction with
    titanium pipes.
    HooDooWitch, Apr 20, 2004
    #46
  7. Molly
    Clutches that reduce engine braking, or summat.
    ogden, Apr 20, 2004
    #47
  8. Molly
    Molly Guest
    Wow, my first compliment.
    Molly, Apr 20, 2004
    #48
  9. Molly
    Molly Guest
    They won't admit to it in public though. I've spoken to some race
    teams who run Gixxer Thous, one of the first things they do is replace
    the basket.
    Molly, Apr 20, 2004
    #49
  10. Molly
    What, slipper clutches?
    Well, you know that engine braking thing? Well, turns out it's apain
    in the arse at racing speeds. If the back wheel is off the ground (or
    nearly so), you don't want the engine trying to slow it down,
    especially with the sky high compression ratios the MotoGP bikes are
    using (there's a reason they don't bump start them anymore, but use
    starting rollers).
    So, them clever engineers have been trying all sorts of ways to stop
    the braking forces generated by the engine being transferred to the
    rear wheel. A "slipper clutch" is one such way - the clutch slips
    when loaded in reverse.
    <smug>
    Of course, ZXR 750s/ZX7Rs have always had them.
    Champ, Apr 20, 2004
    #50
  11. do you mean on or off the ground here?
    Hardly new thou, are they?
    Clearly not. :)
    Do I remember some big road going bikes (ie not race-reps) having
    them to prevent the wheel locking up on ham-fisted (ie not perfect)
    gear changes? Or did I dream it?
    #51
  12. Molly
    Molly Guest
    I did. But there was a problem with the 750 clutch baskets and it
    seems [1] to have carried over to the very early K1's.. I assume that
    this was one of the reasons why race teams changed the clutch basket.
    [1] Based on what my dealer told me.
    Molly, Apr 20, 2004
    #52
  13. Molly
    Molly Guest
    I did check with my solicitor and she was a little surprised at the
    offer considering it was out of warranty.
    I've a feeling that if I push it I will start to get caught up in a
    legal wrangle and my poor bike will be left untouched for a while.
    After all, I'm getting what amounts to a few grand worth of parts [1]
    TBH, I'm taking the money and running. After it's fixed I will try to
    recover some costs.
    [1] Workshop manager reckons about 2.5K retail. [2]
    [2] I forgot about the new oil pump as well.
    Molly, Apr 20, 2004
    #53
  14. Molly
    Molly Guest
    TBH, I don't think you're far out. I'm assuming about a grand inc
    fluids and VAT.
    Molly, Apr 20, 2004
    #54
  15. Molly
    Molly Guest
    This is basically what my solicitor and hte workshop manger told me.
    TBH, I'm pleased.
    Molly, Apr 20, 2004
    #55
  16. Molly wrote:
    <bangs head on wall>
    now try a solicitor with experience in consumer law.
    Fair enough if you need the bike running and are prepared to pay a grand
    plus to have it fixed. I doubt you'll see a penny after it's up and
    running though.
    Doesnotcompute, Apr 20, 2004
    #56
  17. Molly
    dwb says...
    I was watching some consumer prog on TV the other night. Land Rover have
    a problem with 2.5 TDi engines losing the drive to the oil pump because
    a bolt is undoing itself, resulting in engine failure. Alot of it is
    happening out of warranty. You're looking at the thick end of 6 grand
    for a replacement engine if it happens.
    Apparently it is down to a manufacturing fault from new. Some consumer
    expert was saying that if a bolt fails because it was unfit for the job
    when it was fitted at the factory, then the manufacturer is liable for
    repairs or replacement of the engine unit for up to 6 years, regardless
    of the length of the warranty period
    Lozzo, Apr 20, 2004
    #57
  18. Not the point, surely. You should be entitled to a reasonable life
    expectancy of the part, whether the part is classed as a "consumable" or
    not.
    I would say 6 months is a touch unreasonable for brake disks [1].
    [1] Given standard use obviously.
    Mr. Fantastic, Apr 20, 2004
    #58
  19. Molly
    dwb Guest
    Yes, but not on a 8k mile, 6 month old bike.
    dwb, Apr 20, 2004
    #59
  20. Molly
    Champ says...
    My 1982 VF750Fs had slipper clutches too. Made a fucking /awful/ noise
    when you changed down to 2nd at 110mph and dumped the clutch, but the
    rear wheel never locked.
    Lozzo, Apr 20, 2004
    #60
