Go-Peds
Discussion in 'UK Motorcycles' started by Whinging Courier, Oct 15, 2003.
  1. Whinging Courier
    So where do electric assisted bicycles fall in then Eh? I've never seen the
    manufacturers quoting those requirements.
    Hog, Oct 15, 2003
  2. Fairy nuff. I was referring back to someone ele's reference to
    pavements. I just thought your statement that you needed no licence,
    insurance etc meant that you could ride one on public roads without all
    that gubbins....
    The Older Gentleman, Oct 15, 2003
  3. IIRC you have to be aged 14 to ride them, and I *think* you need
    insurance. That's it, though.
    Where's JP when you need him?
  4. Whinging Courier
    pete boyall Guest
    <snip>
    I don't think you require insurance, provided it is limited to less
    than a certain output, around 200W and a max speed under power of no
    more than 15mph.
    Googled :
    http://www.whycycle.co.uk/electric.htm
    Not an authority, but good enough?
    pete boyall, Oct 15, 2003
  5. Stu wrote
    A Good Idea anyway.
    steve auvache, Oct 15, 2003
  6. Yup
    The Older Gentleman, Oct 16, 2003
  7. In uk.rec.motorcycles, Whinging Courier said:
    Cheers peeps. I thought for a while I'd still get my kicks but on the
    cheap. The consensus seems to be to buy a bicycle, good advice that I'd
    completely overlooked!
    Whinging Courier, Oct 16, 2003
  8. Whinging Courier
    Cab Guest
    Swot I thought. There was something in the papers, years ago, about an
    electric bike. At the time, they said that the bike would needed to
    have been registered, MOTed, taxed, etc, etc and you'd have to wear a
    lid.
    Cab, Oct 16, 2003
  9. Whinging Courier
    Cab Guest
    Ah, I didn't see this. Honest.
    Cab, Oct 16, 2003
  10. Whinging Courier
    Alan Crowder Guest
    I think this guy is right, i asked the local plod about a 25cc goped and was
    told i needed insurance the lot, and if i used it home from the pub i would
    get dun like a kipper. There is some information on the Gov web sites (go
    google) about the laws, something to do with outputs if i remember, my 15
    yera old daughter wanted one as well untill she asked about insurance,
    that put her off.
    Alan
    Alan Crowder, Oct 16, 2003
  11. Whinging Courier
    athomik Guest
    But then again, on private ground it's ok for a 12year old to drive a
    Chieftain tank, artic or whatever else takes their fancy.
    athomik, Oct 16, 2003
  12. Whinging Courier
    WorkTOG Guest
    There *is* no dividing line. If you use a mechanically propelled
    vehicle on UK roads, then it must conform to all the construction &
    use regs for its class (two, three, four or more wheels), and you must
    have insurance and (if applicable) road tax/MoT.
    Engine capacity has nowt to do with it (beyond the proviso that under
    50cc is usually - but not always - classified as a moped). You just
    aren't allowed to use these things on public highways, and that's it.
    WorkTOG, Oct 16, 2003
  13. Whinging Courier
    I thought they were still completely illegal to use on public roads,
    though?
    Ace, Oct 16, 2003
  14. There isn't a speed limit on those. Well, they've just introduced one
    in the mall in MK. It was on the news last night. fascinating. If you
    hire a Shopmobility motorised wheelchair, they're restricted to 4mph,
    but if you're not a pikey and bring your own, yours might be able to
    reach 8mph. And as they pointed out, you can do a marathon in 3 and a
    quarter hours at that rate!
    Power Grainger, Oct 16, 2003
  15. Whinging Courier
    On Thu, 16 Oct 2003 17:32:42 +0100, Power Grainger
    [powered wheelchairs[
    Also on the news last night was a silly season feature, showing a
    bloke who has grafted a 100cc motor into a shopping trolley. He sits
    in the wire basket and controls it with a set of modified pushbike
    handlebars. He reckons on going for a Book Of Records entry, as it
    will do 40 mph ... although he had a leetle deeficulty stopping last
    night ;-)
    **** that, I'll bung a Bandit 12 motor in one of Tesco's finest and go
    for it - should be good for 150 with the right gearing ...
    Pip, Oct 16, 2003
  16. Whinging Courier
    JP Guest
    Here!
    Gopeds are no different to mopeds and require all the same
    requirements.
    Electrically assisted pedal cycles (electrically assisted pedal cycle
    regs 1983) are defined as fitted with pedals, kerbside weight less
    than 40kg, motor cuts out above 15mph and power output not exceeding
    0.2kw (0.25kw for a tandem) and have to have their power output plated
    on it. You have to be 14years to ride one.
    They are specifically *not* to be classed as motorvehicles (but are
    still mechanically propelled). That means that you still have to abide
    by road traffic law (as you would on a bicycle) but you still come
    under a lot of other road traffic law (such as unfit to drive,
    dangerous driving and requirements if you have an accident except for
    insurance)
    JP, Oct 16, 2003
  17. Whinging Courier
    JP Guest
    I was just about to answer this one until I read the rest of the
    thread!
    JP, Oct 16, 2003
  18. <Makes Sign of Holy Highway Code>
    Thanks.
  19. Whinging Courier
    Salad Dodger Guest
    Piccie on the back of the latest ClassicKawasakiClub mag, of a
    minibike with a tuned H1 lump in it.
    Looks like fun. =8-0
    | ___ Salad Dodger
    |/ \ GL1500SEV/CBR1100XXX/KH500A8/TS250C/exTS185C
    _/_____\_ ..61036../..13743.../..3157./.19406/.fecked.
    |_\_____/_| IMC#4 TPPFATUICG#7 YTC#4 DIAABTCOD#9 PM#5
    (>|_|_|<) BOTAFOT #70 two#11 Ignoramus #0001
    |__|_|__| BOTAFOF #09 IbW#0 & KotIbW# OSOS#07
    \ |^| / WG* BotTOS #6 GP#4 ANORAK#17 FTB#14
    \|^|/ 2003 RBR landmarks:99 points:2100 miles:8000
    Salad Dodger, Oct 16, 2003
  20. Whinging Courier
    Badger Guest
    Ah, so that's everything except, let's see if I can get this right
    from memory, speed limits, traffic lights, no entry signs, keep left
    signs, um, erm, oh bugger, I've forgotten the rest :(
    Badger, Oct 16, 2003
Similar Threads
Loading...
