Glowing header pipes ZX9
Discussion in 'UK Motorcycles' started by eric the brave, Mar 10, 2005.
  1. Blimey, yes. Does it still work on the KH?
    The Older Gentleman, Mar 12, 2005
    #81
  2. Oh, I daresay it would, were the piston crowns coated in enough
    carbon.[/QUOTE]
    Where's Hoyt when you need hiom?
    Oh, I remember - playing a harp.
    #82
  3. eric the brave
    Salad Dodger Guest
    Blimey, yes. Does it still work on the KH?[/QUOTE]
    It ought to, it's only eight months old.
    Salad Dodger, Mar 12, 2005
    #83
  4. Apparently, WW1 pilots who sat behind rotary engines lubed with castor
    oil (Sopwith Camel being a classic example) were always astonishingly
    'regular'. Who needs All Bran, anyway?
    #84
  5. Detail!
    #85
  6. It was somewhere around Barstow, on the edge of the desert, when the
    drugs began to take hold. I remember "Dr Ivan D. Reid"
    I suppose to turn it off, you inject some Vitamin C?
    GS 850 x2 / SE 6a
    Grimly Curmudgeon, Mar 12, 2005
    #86
  7. eric the brave
    Dan L Guest
    Good point, particularly re premix, but my somewhat simplistic pea brain
    would have assumed that the mechanism for delivering injected oil would have
    been based on a specific viscosity range. It seems odd that the same pump
    and injector works despite one oil being rather gloopy and the other being
    somewhat pissy.
    Dan L (Oldbloke)
    M'boy's bike 2003 Honda NSR125R
    Spare Bike 1990 Suzuki TS50X
    BOTAFOT #140 (KotL 2005), DIAABTCOD #26, BOMB#18 (slow)
    Dan L, Mar 13, 2005
    #87
  8. eric the brave
    I was doing that on BR in the late eighties (and making the wicks)
    although the little glass bowls were brass.
    sweller, Mar 13, 2005
    #88
  9. eric the brave
    Still does on the XS400 and GS550 in my possession.
    #89
  10. eric the brave
    I've got an old Gunson's Colourtune which is pretty useful for proving
    the state of play across the rev range on each cylinder.
    Although I do do a plug chop on sustained high rev hard work just to make
    sure.
    #90
  11. If the bikes are regularly used, they seem to last. It's only when the
    things are laid up for years that they harden and fail, to be honest.
    Memories of Gibbo's XS250 and the Mole grips clamping the fuel line in
    place of a tap. And the look on the face of the sailor in charge of
    securing the bikes on the ferry deck....
    The Older Gentleman, Mar 13, 2005
    #91
  12. Jee-zus!
    On what engines, pray tell?
    #92
  13. I used to have one of those, but the trouble is you can't see them if
    you fit them to many modern bikes because they're hidden under all the
    plastic.
    #93
  14. eric the brave
    Eiron Guest
    I've got an EGO sensor on my exhaust that does the same thing
    but you can read the bargraph display while riding.
    Who was the OP? Has he found the problem yet?
    Eiron, Mar 13, 2005
    #94
  15. eric the brave
    The Older Gentleman says...
    MZ TS150
    Lozzo, Mar 13, 2005
    #95
  16. eric the brave
    Vale of Rheidol (BR class 98):
    http://www.sweller.dynalias.org/images/no7vordb.jpg
    The 08/09 diesel shunters /still/ use the wick and oil lube method but
    they were built in the 50s/60s; I last oiled up an 08 in about 1993,
    although it wasn't really part of our duties at the time. The BR
    Standard locomotives (again built 1950s-1960s) used that method of
    lubrication.
    #96
  17. eric the brave
    Can you guess why I'm immune to this problem?
    #97
  18. Twas I. I think the air vent in the filer cap was blocked.
    eric the brave, Mar 13, 2005
    #98
  19. Utterly amazing.
    Well, if it worked.....
    #99
  20. eric the brave
    Ginge.
    Pip, Mar 13, 2005
