Glowing header pipes ZX9
Discussion in 'UK Motorcycles' started by eric the brave, Mar 10, 2005.
  1. I've just taken the standard pipes with race can off the ZX9-C1 and
    replaced them wit ha full Akrapovic titanium system. When warming it up I
    noticed all the header pipes glowing red. It has a dynojet kit
    fitted. Whats up Doc?
  2. eric the brave
    eric the brave says...
    It sounds like it is running very lean and way too hot. Get the jetting
    checked and sorted asap. I wouldn't ride it like that myself.
    Lozzo, Mar 10, 2005
  3. True enough. I was wondering how Bonwick got on with the Akrapovic Bro
    sold him. If he has the same problem as the system is the same.
    Considering it already has a race can I'm surprised it is running this
    weak. Although saying that, warming the bike up at constant throttle is
    bound to find the weak. I just wondered if there was anything obvious I've
    missed. It has a standard air filter. A bit dirty from summer use so it
    should not be that bad.
  4. It may be OK, actually.
    Standard headers are steel and often double-skinned. A light titanium
    system is likely to have thinner wall tubing and single skins, and I'd
    expect it to get hotter. Many headers glow under, er, stress.
    But I'd do a plug chop to check the jetting, anyway.
    The Older Gentleman, Mar 10, 2005
  5. Thanks Tog. I think you might be right. You can se them start to glow at
    3-4k. If you drop them back down to tick over the pipes stop
    glowing immediately. It was dark so I probable noticed it more.
    As of interest I've had some other feedback:-
    1. Ignition retarded - Is this posible on the ZX9?
    2. Tight exhaust valves - Major service 1k ago. and all ipes are exactly
    the same.
    3. Running lean. - I have a Dynojet fitted.
    4. Shit fuel - Not sure on this. The bike has only done 1k in the last
    year so the fuel could be 10% two stroke oil for all I know.
    5. Bikes f***ed - sell it to me for a fiver :)
    Any other suggestions?
  6. Retarded ignition would make it run cooler. Advanced ignition results in
    hotter running.
    Definitely not this.
    Possible, but a good Dynojet kit, properly fitted, whould be OK.
    Total bollocks.
    OK :)
    Seriously, do a plug chop - if you don't know how, then get it into
    abour fourth gear, and give it full welly, preferably slightly uphill.
    Then hit the kill switch and pull in the clutch at one and the same
    moment. Remove plugs and check the colour.
    I appreciate that doing this on a ZX9 might mean removing half the
    bodywork....
  7. eric the brave
    I had an XBR500 that made one exhaust pipe glow red, after I'd removed
    the cam follower on one exhaust valve. This was at tick over only, and
    didn't seem to affect the running of the bike, except there seemed to be
    a bit more low down grunt, and less top end.
    Muck, Mar 10, 2005
  8. But would it not make the pipes glow red? Mind you having run a fair few
    bikes without exhausts the flames comming out are a bit like a blow torch
    anyway.
    Good. Well I might end up having it set up on a Dyno.
    Not bollocks at all !
    10% oil in the fuel would make it run as weak a f**k. A typical reason why
    two stroke engines hole pistons. More oil in the mix means less fuel.
    Plug chop is OK for full throttle. I'm not at that stage yet. I'm thinking
    of low speed town work at 4k with cherry red pipes.
    Easier to get the work done on a Dyno me thinks. I can get it set up at
    all throttle openings throughout the rev range. THe Akrapovic probably
    deserves it. My ZXR never used to glow red though. But that was like
    having the choke on at low revs.
  9. eric the brave
    Absolutely correct. By adding 2-stroke oil to petrol you effectively
    lean off the fuel/air ratio. We always upjetted strokers to compensate
    for this when going over to premix from oil injection.
    Lozzo, Mar 10, 2005
  10. eric the brave
    Eiron Guest
    Oxymoron alert!
    A plug chop showing the mixture at WFO and high revs will tell you
    absolutely nothing about mixture problems just off idle.
    It's quite possible to be dangerously lean at low revs and too rich
    at full throttle.
    Eiron, Mar 10, 2005
  11. Eiron wrote
    Good enough reason to keep the throttle open then innit.
    steve auvache, Mar 10, 2005
  12. eric the brave
    On my 250, the radiator has to come out to get to the plugs. Not a big
    job, but still a bit of a pain.
    Muck, Mar 10, 2005
  13. Oh yes, agreed. I just meant that it's bollocks that this is likely to
    be the problem in this case.
    The Older Gentleman, Mar 11, 2005
  14. So do more than one plug chop, duh.
  15. It might be. He had MX bikes in the garage. I know the tank was dry
    because he told me he would put some petrol in. The battery was OK because
    of the Optimate.
    eric the brave, Mar 11, 2005
  16. Good point...
  17. Reminds me of a ZX9 and a Hotel in France. :)
    Where did you get the race bike dyno'd ?
  18. eric the brave
    <poised>
    Pip, Mar 11, 2005
  19. eric the brave
    Alex Ferrier Guest
    Slick performance.
    Alex
    BMW R1150GS
    DIAABTCOD#3 MSWF#4 UKRMFBC#6 Ibw#35 BOB#8
    http://www.team-ukrm.co.uk
    Windy's "little soldier"
    Alex Ferrier, Mar 11, 2005
  20. eric the brave
    Basstard!
    Pip, Mar 11, 2005
