Gixxer vs ZX10r - Opinion
Discussion in 'UK Motorcycles' started by Molly, Nov 20, 2005.
  1. Molly
    Molly Guest
    It's time for my Gixxer thou and I to finally part company. We have spent a
    fond four and three quarter years together. I really love the bike but it's
    now time to find something a bit physically smaller. I've sat on the current
    crop of litre sportbikes and they all feel small compared to my K1 Gixxer
    with the exception of the RSV which I loved but was far too tall. So what's
    the truth?
    I have done a google search to see if there's a report from Champ but couldn't
    find one. My only disappointment with my Gixxer was some niggly quality of
    finish issues but these paled into insignificance when compared to the total
    package. Also, when my engine went they sorted it out and paid for all the
    parts even though it was well out of warranty. Tyre life was probably what
    you expect from a hamfisted pilot as was fuel consumption. My best was
    almost 60mpg and my worse was less than a Range Rover. The average being
    about 25mpg. For some reason I seemed to wear out the front tyre at a
    similar rate as the rear [2], the lowest mileage a got was 800 miles on a
    set of Rennsports [3] but never bettered 2,000, even in winter. One
    remarkable thing about the Gixxer was how comfortable it was, even though I
    never attempted the mileages that some riders here managed I did frequently
    do more than 500 miles per day. I remember that after one return journey to
    Swansea and back [1] it was such a lovely evening I went out for a ride.
    So how does the current crop compare. FYI, I'm 5'3" and just over 9st.
    [1] 470 miles
    [2] Well close enough to change them both.
    [3] By far the best tyres I used in the dry but I found them unpredictable
    in the wet (hamfisted).
    Molly, Nov 20, 2005
  2. Molly
    Molly Guest
    I just don't have the strength to hold a tall bike up and actually dropped
    the Gixxer when my foot slipped on gravel. An extra inch would have made all
    the difference. Obviously when on the move the size doesn't matter but the
    reality of life is you have to be able to plant a toe firmly.
    Cheers Champ, that's just what I needed, I don't know about the Blade though
    but it's certainly worth blagging a test ride.
    Molly, Nov 20, 2005
  3. From what I understand the K% is a lot lower down or the seat is narrower
    at the front so your feet can reach the ground.
    eric the brave, Nov 20, 2005
  4. Molly
    eric the brave said...
    I found Daz's K5 to be a lot lower than my K1 when I sat on it. I
    thought this was because I have modified rear suspension[1] but after
    fitting the standard shock back into mine, while the Maxton was away
    being rebuilt, I found it even higher than it was before. Overall, I'd
    say as standard the K5 is lots lower than a K1, but the K5 seat is like
    a plank.
    [1] Shorter dog-bones which raise the rear and Maxton shock.
    Lozzo, Nov 20, 2005
  5. Molly
    muddy Guest
    A custom seat from Corbin would give you an inch or so lower too.
    muddy, Nov 20, 2005
  6. Molly
    muddy said...
    Lozzo, Nov 20, 2005
  7. Molly
    muddy Guest
    muddy, Nov 20, 2005
  8. I've sat on both the 10R and the Gixer K4 & K5 and the K5 is
    significantly lower than the other two. I can almost flat foot the K5
    whereas the others I'm definitely on tippy toe.
    Adie
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=4583091887
    Triumph 955iSS / ZX9R / GSF1200 bandit (for sale) / CG125
    Adrienne M Bonwick, Nov 20, 2005
  9. Molly
    Molly Guest
    That's encouraging, you're a bit taller than me but not much. Saying that,
    "Triumph 955iSS / ZX9R / GSF1200 bandit " all these are a bit tall for me.
    Molly, Nov 20, 2005
  10. come round and have a sit on the 10R. Andy is away so we can have a
    nice girlie gossip.
    Adie
  11. Molly
    Molly Guest
    Good idea. I'm playing at the White Horse tomorrow and you're not too far
    from there.
    Molly, Nov 20, 2005
  12. Molly
    Daz Guest
    On Sun, 20 Nov 2005 18:00:54 +0000, Adrienne M Bonwick
    I've owned a K2 and K5. As you can ride a K2 you'll be fine on the K5
    as it's a lot smaller and lighter The lower height mainly comes from
    the much reduced width of the seat. The seat isn't a plank at all,
    seriously. The K2 seat is *sumptuous*, which I think is why Loz
    noticed such a difference.
    Daz, Nov 20, 2005
  13. Molly
    Daz said...
    I must have a delicate posterior
    Lozzo, Nov 20, 2005
  14. which white horse? I've got nothing on, assuming i don't get stuck in
    work i could come along.
    Adie
  15. Molly
    Molly Guest
    Molly, Nov 20, 2005
  16. Molly
    Molly Guest
    You would feel a dried pea under twenty mattresses. ;)
    Molly, Nov 20, 2005
  17. Adrienne M Bonwick, Nov 20, 2005
  18. Molly
    Molly Guest
    Perhaps I could pop over to your house first. [1] I usually get there about
    8:15 to set some equipment up. I'll only be doing 4 or 5 numbers because I'm
    still a bit poorly. I usually do a lot more but I'll have to see how it
    goes. I'll probably use my acoustic 12-string and mic it up. I may also sing
    two originals I wrote while in hospital. It really depends on how I feel, I
    had a tube stuck down my throat for 10 hours and I'm still a bit sore.
    [1] Mail me your address again please.
    Molly, Nov 20, 2005
  19. Using the patented Mavis Beacon "Hunt&Peck" Technique, Adrienne M
    <wanders off for nice cold shower>
    Wicked Uncle Nigel, Nov 20, 2005
  20. Molly
    Even with your bits cut off?
    platypus, Nov 20, 2005
